POV-Ray : Newsgroups : povray.general : Filled Height field Server Time
22 Oct 2026 06:56:06 EDT (-0400)
  Filled Height field (Message 1 to 11 of 11)
Subject: Filled Height field
Date: 30 May 2003 18:14:00
Message: <3ED7D7A8.10509@hotpop.com>
   I need to make a filled height field, that is, a height field which
has an interior beneath the top surface.
I've been looking and the height_field cannot do this in my
understanding, possibly an isosurface could, but you can probably
compare my skills to a newbies'!
If not possible I was thinking on tracing the hf and put a sphere and a
cylinder from there to y=-1...  this would be extremely memory exaustive
and would probably end up being impossible with my hardware.  I need a
very big precision hf, I could possibly then try with a low res hf, make
the same thing with cylinders in a blob and then apply a normal texture
or a bump_map of some sort to give more precision?
But I really don't know what is the best thing I should do!
Thanks for any help!
   Xilo
Dedicated to audio/visual and interactive artwork.
http://www.geocities.com/simonlemieux/
Subject: Re: Filled Height field
Date: 30 May 2003 18:35:12
Message: <3ed7dca0@news.povray.org>
  You should be more specific about this. You description does not really
tell what is what you need.
  Can you, for example, post a small scene showing the unwanted effect and
then describing how you would like that image to look like?
Date: 30 May 2003 18:42:27
Message: <cjameshuff-D68B6D.17440330052003@netplex.aussie.org>
In article <3ED### [at] hotpopcom>,
A height_field object does have an interior, as I recall it extends from
the surface infinitely in the -y direction. It just doesn't have any
sides, which makes it tricky to use for things like media.
I don't know what you're talking about here, but it sounds like you are
making things much too complex. Just use an intersection of the height
field with a box...scale and translate the height field to slightly
overlap the sides of the box (to avoid precision problems), and you will
get a shape with the sides of the box and the upper surface of the
height field.
http://tag.povray.org/
Date: 30 May 2003 18:50:25
Message: <3ed7e031@news.povray.org>
news:3ed7dca0@news.povray.org...
Well, CSG difference from a box could be the answer. That gives a solid
object to work with. But I agree that the Xilo's message confused me when it
came to the cylinders and blobs and bump mapping.
Bob H.
Date: 30 May 2003 19:32:13
Message: <3ED7E9FE.1080101@hotpop.com>
Ok, I'll post what I mean in p.b.images as "Fill Height field"
Xilo
Date: 30 May 2003 20:20:50
Message: <3ed7f561@news.povray.org>
  Perhaps you mean the intersection of the heightfield and a box { 0,1 }?
Date: 30 May 2003 22:08:26
Message: <cjameshuff-8388B4.21100230052003@netplex.aussie.org>
I didn't say to scale the height field to overlap the box just to make
it more challenging. The speckles should be a dead giveaway: you are
seeing an equivalent to the coincident surface problem, sometimes the
sides of the box are "inside" the height field, sometimes they are
"outside", depending on how the precision errors turn out.
intersection {
    box { <-0.5, -0.5, -0.5>, <0.5, 1, 0.5>}
    height_field { png "Heightfield.png" smooth
        scale < 1.02, 0.1, 1.02>
        translate <-0.51, 0, -0.51>
    pigment {rgb 1}
> // or perhaps: plane { <0,1,0>, 3 }
No, that will not work. You are adding sides, a plane doesn't have sides.
Date: 30 May 2003 23:21:35
Message: <3ed81fbf@news.povray.org>
news:3ed7f561@news.povray.org...
No, I meant difference alright, I just spoke too soon. That would require a
box having an inverse keyword added to it. CSG intersection doesn't always
seem to do what I think it's going to do so I just acquired a habit of
avoiding it if I think there might be confusion. My mistake to suggest CSG
difference.
Glad scaling was also told of concerning this, as I read elsewhere, I had
neglected to mention it. Although, I am not sure anyone said scaling of a
box {0,1} will leave three sides unaffected due to the <0,0,0> corner.
Bottom, left and front, as viewed with a typical camera. The height_field
and box should be centered on <0,0,0> to make that easier preventing the
coincident surfaces.
Bob H.
Date: 31 May 2003 07:41:44
Message: <3ED894FD.5000804@hotpop.com>
> intersection {
>     pigment {rgb 1}
Ok, but I changed the box to look like this:
box { <-0.6, -0.5, -0.6>, <0.6, 1, 0.6>}
And the picture was exactly the same...
Well, I just want it filled so I can do difference on it and carve
things into my height field...
Thanks,
   Xilo
Date: 31 May 2003 15:14:00
Message: <cjameshuff-7024C4.14154031052003@netplex.aussie.org>
I doubt that...you avoided the coincidence problem by putting the box
sides outside the height field, exactly the opposite of what will work,
so you probably didn't even get the speckled sides at the back. Try
following the instructions given. Jeez, I even gave you working example
code...
As explained, the height field is already a solid object, it just
doesn't have sides. If you want solid sides instead of just the upper
surface, you need to intersect it with a slightly smaller box so the
sides of the box will be used. The plane you used doesn't have any
surfaces that can be used for the sides, so intersecting with it will
not work. In fact, it didn't have *any* surfaces that intersected the
height field, so the only effect would have been to make the height
field render slower. You could intersect with 4 planes perpendicular to
the height field, one for each side, but this will be both slower and
more work to set up.
Date: 31 May 2003 16:46:11
Message: <3ED91492.2000209@hotpop.com>
> code...
I'm sorry Christopher, I did not understand what you were talking about
at first glance, though Mike Williams answered my question in p.b.images
and correct my mistake the exact way you were talking about, you were right.
I've succesfully intersected the hf with a box and everything is
perfectly in order now, thanks!
Xilo
