Three TrueType fonts are given with POV, but accented characters are not
available therein. I have tried to use other TT fonts from my Macintosh,
but they produce errors.
Where can I find TT fonts that would have the right headers and tables
to be used in POV?
How can I write my name using POV Text feature?
François de Dardel
http://mapage.noos.fr/dardelf/
Utilisez mon adresse sur noos seulement
Use only my noos e-mail
> to be used in POV?
You can find various fonts with nonstandard characters on:
http://www.slovo.info/unifonts.htm
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
> > to be used in POV?
See also section "6.11.6 Charset" in the docs.
Ken Tyler
ot
h,
>>>to be used in POV?
Thanks for the responses, I have tried several things:
1) Downloaded a new TTF from the above link (Vera Humana 95 Bold). Using
it, however, produces the same problem as with the 3 POV fonts:
"non-ASCII character replaced by space". It took me quite some time to
verify if the font did or did not contain "é" or "ç". Finally, I foun
d
it did contain these characters. I can use the font in MegaPOV, but I
can't get it to accept the accented characters. Trying to use it in MS
Word, the accented characters are replaced by a "_" (underscore). I
repeat I am on a Macintosh, with MacOS 10.2.6.
2) I found the "Global_charset" item in the POV doc, but not in the
MacMegaPOV doc. I am using MacMegaPOV since yesterday because there is
no current POV for the Mac.
I inserted a Global_Charset command in my POV file:
global_settings{charset ascii}
and got the same warning message as without this command:
"Non-ASCII character has been replaced by space character"
If I use
global_settings{charset URF8}
I get
"Character 142 (0x8E) not found in Macintosh HD:Images:POV
files:Include:verahb:ttf"
and this time I get a rectangular box instead of a space. Same problem
with the timrom.ttf font.
If I use
global_settings{charset sys}
I get
"Parse Error: cannot convert system specific text format to Unicode."
In my test, the "faulty" letter is "é". Looking at the glyph catalog in
the Mac character palette, it has the Unicode number 00E9 and decimal
112, so it is not even the same as reported by POV.
What else can I try ? It looks like the fonts are not fully compatible
with the Mac OS, and I can't use the Mac OS specific fonts...
François de Dardel
In article <3EB### [at] netscape net> , François de Dardel
No, there is no version that runs (well) native under Mac OS X, which does
not mean you can't use 3.5 under Classic.
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
> verify if the font did or did not contain "é" or "ç". Finally, I found
If you have problems using non ASCII characters in POV-Script just use the
unicode transcription: "\uXXXX" where 'XXXX' stands for the code. "é" is
00e9 and "ç" is 00e7.
g
und
>>it did contain these characters. [...]
the
" is
You're a genius, Christoph !
Now it works with that Vera Humana font (not with timrom.ttf, where
these characters are probably missing). Initial settings are
global_settings{charset utf8}
It is not a very practical way to write in French or German, but at
least I can achieve what I was intending to do.
Many thanks, you saved my day...
François de Dardel
the
" is
And here is the result:
http://perso.wanadoo.fr/caroline.burnand/tip0305d.html
François de Dardel
