POV-Ray : Newsgroups : povray.general : POV-Tree 1.0 Server Time
2 Nov 2026 10:33:40 EST (-0500)
  POV-Tree 1.0 (Message 1 to 14 of 14)
Subject: POV-Tree 1.0
Date: 22 Apr 2003 03:05:09
Message: <3EA4E7EC.C4BB99B2@mail.com>
The final version of POV-Tree (Java-based tree generator) is available
here:
http://propro.ru/go/Wshop/tools/tools.html
The source files are available as well.
The final version has interactive tree editor and supports UV-mapping.
See README.txt for details.
Gena.
Subject: Re: POV-Tree 1.0
Date: 22 Apr 2003 13:19:06
Message: <Xns9365C4F8E552Fseed7@povray.org>
Thank you!
Ingo
Date: 22 Apr 2003 14:45:36
Message: <3ea58dd0$1@news.povray.org>
Thank you!
You might want to post to  povray.binaries.utilities  too, unless
that violates cross-posting rules.
"Gena Obukhov" <obu### [at] mailcom> wrote in message
news:3EA4E7EC.C4BB99B2@mail.com...
> here:
> Gena.
Subject: RE: POV-Tree 1.0
Date: 22 Apr 2003 16:32:48
Message: <3ea5a6f0@news.povray.org>
Harold <bai### [at] 3dculturecom> escribió en el mensaje de noticias
3ea58dd0$1@news.povray.org...
> Thank you!
Not only to p.b.u. but also to povray.news-submission, I think it's
a great new and should be in the povray webpage.
A fantastic program, thank you very much Gena, .
Bye
Txemi Jendrix
http://www.txemijendrix.com
Date: 22 Apr 2003 17:06:54
Message: <3ea5aeee@news.povray.org>
I should have checked it first  :-(
Date: 23 Apr 2003 19:01:44
Message: <3ea71b58@news.povray.org>
> here:
> Gena.
It's be really nice if it could generate actual POV output...
It's always seemed really wasteful to me to 'build' the tree every render.
Date: 23 Apr 2003 20:38:46
Message: <3EA73219.68F96704@mail.com>
What do you mean?
You can export tree in mesh format. This way you don't have
to 'build' tree every render. You have to do that only if you
save tree as include file for TOMTREE macro. In order to
reduce parsing time in this case you can use modified version
of tomtree macro which I posted in p.b.s.-f. some time ago.
It works about 6-7 times faster.
Gena.
Date: 23 Apr 2003 20:45:25
Message: <cjameshuff-80E482.20452223042003@netplex.aussie.org>
In article <3EA4E7EC.C4BB99B2@mail.com>,
> here:
Seems to work well under Mac OS X 10.2.5. That's a huge number of
options though...maybe it needs a tree-generator-parameters generator,
to produce slightly different trees of specific types.
http://tag.povray.org/
Date: 24 Apr 2003 00:50:35
Message: <3EA76B61.35BAA905@mail.com>
You can play with 'randomness' parameter for different tree elements
to change their distribution.
Gena.
Date: 24 Apr 2003 09:50:46
Message: <3ea7ebb6@news.povray.org>
> What do you mean?
> Gena.
Ahh, okay, I'll have to try that. As for meshs, I try to avoid them when
possible, they just seem... un POVlike.
Date: 24 Apr 2003 09:57:54
Message: <cjameshuff-8363EC.09573624042003@netplex.aussie.org>
In article <3EA76B61.35BAA905@mail.com>,
Not quite what I meant...I was thinking of things like "height",
"bushyness", "health", and so on.
Well, I'll have to do something like this when I get Amber up and
running.
Date: 24 Apr 2003 13:14:44
Message: <3EA81B88.BBC1419C@mail.com>
You can adjust mesh accuracy to make the surface smooth. Just
remember that high accuracy will increase the number of triangles
and parsing time as a result of that.
Gena.
Date: 24 Apr 2003 13:20:25
Message: <3EA81CDD.A3B5A669@mail.com>
I was about to implement smth. like wizard which would guide
you through several steps where you could define those parameters
which you mentioned. As usual the problem is a lack of time :)
If anybody has enough time to do that you are welcome - the
source files are open :)
Gena.
Date: 3 May 2003 00:21:02
Message: <3eb343ae$1@news.povray.org>
"Tyler Eaves" <tyl### [at] cg1org> wrote...
Come on... don't be so hard on meshes.  They are definitely one of the most
efficient methods (memory-wise) of creating trees and plants in POV, because
you can duplicate them many times with only marginal memory use for each
additional copy.  You can't do that with any other object.  Plus, they store
their textures slightly more efficiently than other objects.  Oh, and POV
usually renders them amazingly quickly!
-Nathan
