POV-Ray : Newsgroups : povray.general : Closest points on two circles Server Time
2 Nov 2026 11:21:45 EST (-0500)
  Closest points on two circles (Message 1 to 25 of 25)
Subject: Closest points on two circles
Date: 25 Mar 2003 07:22:37
Message: <3E804D3B.3070301@alphalink.com.au>
If this has been covered before then mea culpa, but I have searched the
links collection and the internet at large to no avail.
Does anyone possess a macro for calculating the points defining the
shortest path between two circles (not discs, circles) given the normal,
centre and radius of each circle, or some algorithm/formula from which
such a macro may be easily derived?
I am led to believe that the calculations involved in solving this
problem are reasonably difficult, so don't knock yourselves out trying
to work out a solution for me, unless you enjoy that kind of thing :?)
I'm really just hoping that someone happens to have the appropriate
information just lying around.
Thanks, Ed.
Subject: Re: Closest points on two circles
Date: 25 Mar 2003 08:47:40
Message: <3e805dfc$1@news.povray.org>
To get the vector for spheres:
#declare centerA=<10,5.0,-5.50>;
#declare radiusA=3.1415;
#declare centerB=<1.0,-45.0,15.50>;
#declare radiusB=0.1415;
#declare 1stpoint=  centerA+ radiusA*vnormalize(centerB-centerA);
#declare 2ndpoint=  centerB+ radiusB*vnormalize(centerA-centerB);
Then the vector in question is between 1stpoint and 2ndpoint.
A treatment for "circles"  is the same as that for spheres with coplanar
centers.
Date: 25 Mar 2003 08:53:44
Message: <3E806296.6090201@alphalink.com.au>
> centers.
Thanks, but my purpose requires a solution for pairs of circles with any
orientation and position relative to one another, not just coplanar circles.
Date: 25 Mar 2003 08:57:22
Message: <3e806042$1@news.povray.org>
To find the closest points on any pair of circles, simply draw a line from
center to center.  Then locate the points on each circle that the line passes
through.
Cheers!
Chip Shults
Date: 25 Mar 2003 08:57:59
Message: <fqn08vov70hujm7t7ihaepp17kaerr6kpl@4ax.com>
On Tue, 25 Mar 2003 08:47:08 -0500, "Greg M. Johnson" <gregj:-)565### [at] aolcom>
No. Being in 2D consider circle located at <0,0> with radius 2 and circle
located at <3,0> with the same radius 2. Closest points between circles are
located in intersections which are not between centers.
ABX
Date: 25 Mar 2003 09:00:27
Message: <3E80642A.3040301@alphalink.com.au>
> through.
This only works when both your circles are sitting on the same plane,
not when they may take any orientation in 3D space.
Date: 25 Mar 2003 09:03:38
Message: <3E8064E7.1090800@alphalink.com.au>
> ABX
Quite so, and furthermore my circles are not in 2D space, they are in 3D
space. However I'm happy enough not to consider cases where they
intersect one another.
Date: 25 Mar 2003 09:09:15
Message: <0do08v0h6ucslf7mli0f0dfo1q8lv4eoo9@4ax.com>
On Wed, 26 Mar 2003 01:14:02 +1100, Edward Coffey <eco### [at] alphalinkcomau>
You have to define distance as function and then find where it has minimum.
http://mathworld.wolfram.com/Minimum.html
ABX
Date: 25 Mar 2003 09:10:23
Message: <3E80667D.9040506@alphalink.com.au>
Sorry, I should have been more clear - when I specified that I was
dealing with circles not discs I did not mean to imply that I was
working in a 2D space, only that the path had to connect to the
circumference, not to any point within a disc.
My circles exist in 3D space and may take any position or orientation
relative to one another.
Date: 25 Mar 2003 09:19:19
Message: <3E806895.2050008@alphalink.com.au>
Yes, but as I stated in my original post, the mathematics of this is
quite complex, it's not as though you're finding the minimum of a
quadratic equation with one variable. Certainly the mathematics of it is
quite beyond my abilities, which is why I haven't asked anyone to solve
it, simply that if they happen to have access to a solution (or if
they're math mad and really want to create their own solution) to post
it here.
Date: 25 Mar 2003 09:33:18
Message: <3e8068ae@news.povray.org>
"Edward Coffey" <eco### [at] alphalinkcomau> wrote in message
news:3E8### [at] alphalinkcomau...
Does the solution need to be proper math, and does the result have to be
perfect?
For a kludge, IMHO it shouldn't be too hard to write a macro that will return
the two points using a brute force approach. i.e. (approx. code, won't parse)
#declare Len = 10000000000000
#declare R1 = 0
#while (R1 < 360)
    #declare R2 = 0
    #while(R2 < 360)
       #if(distance between R1 on 1st circle and R2 on 2nd circle < Len)
            Len = that distance
        #declare R2 = R2 +1
    #declare R1 = R1 + 1
Date: 25 Mar 2003 09:36:38
Message: <3e806976$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3e8068ae@news.povray.org...
That should have been (sort of)
                BestR1 = R1
                BestR2 = R2
             Len = that distance
Date: 25 Mar 2003 09:49:54
Message: <3e806c92$1@news.povray.org>
Then you will have cases where you *cannot* find a closest point on the
circumference.  How do you define that case where the circles' planes may be
perpendicular?  There is no solution then for one of the circles, because *all*
points on one will be equidistant to the most extended point on the other.  And
what about coplanar circles with perpendicular centers, such as occurring on a
cone or cylinder?  Then *neither* will have a closest point!
    You can do some simple geometric tests to throw those cases out, then
proceed to construct a truncated conic section that contains the two circles as
limits.  That is, as long as the circles to not intersect!  Now you open a new
can of worms.
    If you have the circles on a single plane, the solution is obvious- draw a
line from center to center as long as they are no concentric.  If they are
non-coplanar and non-intersecting, construct a conic section using the two
circles as caps, and the shortest path on the surface will yield your answer.
    For more than two dimensions, the ways this process can go wrong are
numerous.  For 4 dimensions and up, I can visualize that there could be more
than one solution.  In 3 dimensions, you can always treat any two non-coplanar
planes as you might any two non-colinear lines in a plane.  They will always
have an angle of intersection, which can be seen as being between 0 and 90
degrees.  In some such cases, you might have one closest point on one circle and
*two* closest points on the second- think of one circle passing through the line
of intersection of the two planes.
    This is a mathematically non-trivial problem.
Cheers!
Chip Shults
Date: 25 Mar 2003 10:05:04
Message: <1dr08v84tdvdfssmiiu40ikec3sqqa542j@4ax.com>
On Wed, 26 Mar 2003 01:32:53 +1100, Edward Coffey <eco### [at] alphalinkcomau>
> quite complex
I would go for approximation. If it has to be calculated once you probably can
use approximation as Tom Melly suggested. Otherwise I think there is possible
fast approximation using functions. Consider your circles as toruses with minor
radius = 0. Then construct two functions which represent your circles
  #declare torus1=function(x,y,z){...}
  #declare torus2=function(x,y,z){...}
using transformations and shapes available in IsoCSG library. Then define space:
  #declare space=function(x,y,z){torus1(x,y,z)*torus2(x,y,z)};
I imagine the edge with nearest distance has probably lowest possible values
larger than 0. IIRC there are some analyze methods for finding that path but I
can't recall exact names.
ABX
Date: 25 Mar 2003 10:16:43
Message: <3E807610.2040208@informatik.uni-freiburg.de>
> perfect?
If approximations suffice, I would go the following way:
1. Choose some point X on circle A
2. Choose some (the) point Y on circle B closest to X
3. Re-choose X to be closest to Y
4. Re-choose Y to be closest to X
5. Continue, until you are happy with the precision.
Caution: This is not yet guaranteed to find the optimum.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 25 Mar 2003 10:31:10
Message: <3E807973.4070206@informatik.uni-freiburg.de>
> For 4 dimensions and up, I can visualize [...]
Tell me more. I never quite managed to visualize 4D.
 > [...] that there could be more than one solution.
Already in 3D you can have exactly 2 solutions:
Circle A: center 0, normal y, radius 1
Circle B: center 0, normal z, radius 2
Date: 25 Mar 2003 12:02:21
Message: <3e808b9d@news.povray.org>
My two cents to this topic:
Find a parameterization of the circle in 3D (the one in u and the other in
v). Then you can formulate the distance between the circles in the two
unknows u and v: d[u,v] = ... All you have to do then is to minimize this
function. You can either do this mathematicaly (partial deriviatives in u
and v have to be 0) or numerically using something like steepest descent.
The hardest part is to find the general parameterization in 3D.
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Date: 25 Mar 2003 12:47:11
Message: <3e80961f$1@news.povray.org>
Some things I can do in 4D, a trick I learned as a child when first
confronted with the possibility.  I read Abbot et al and a couple of other
fascinating stories, then tried the graphing and model constructing.  It seemed
pretty clear after a few days of tinkering.
    The real helper was the N-dimensional packing algorithm for spheres.  It is
closely related to information encoding and how to specify the maximum number of
clearly distinct messages that you can put into a given number of bits (which
relates to the dimensions, n).
    Yes, there are two solutions for the cases that are most easy to see in 3D,
but there are infinitely many cases where there are an infinite number of
solutions (or no solutions) for either or both circles.
Cheers!
Chip Shults
Date: 26 Mar 2003 02:17:21
Message: <3E815732.4020104@alphalink.com.au>
Thanks for the suggestions everyone, looks like I'll just try to
approximate it.
Date: 29 Mar 2003 02:35:06
Message: <web.3e8548abe86bfd1834dff4bb0@news.povray.org>
>approximate it.
You know, this has been bugging me, because it just seems like there's got
to be a way to do it with straight vector math, without resorting to
sin/cos parameterizations and taking partial derivatives (with respect
to each parameter) to find local minima.
The best I've been able to come up with so far is this.
Take two circles, centers at C and D, with respective normals M and N.  Pick
two points, one on each circle, P on circle C, and Q on circle D.
In order for point P to be the closest point on circle C to point Q, the
plane defined by triangle CPQ must contain the normal vector M.  Put
another way, the triple product (is that what it's called?) of (CPxPQ).M
must equal zero.  That is, CP cross PQ is perpendicular to the plan CPQ,
and that vector dotted with the normal M (which is in CPQ) should be zero.
Ditto for (DQxQP).N=0
The only problem is how to find points P and Q.  So far I am still stuck
with parameterizing the circles.  I want something prettier involving the
center, normal, and radius, and maybe some cross products or something...
But I'm still drawing a blank.
But the advantage is, to find an exact solution, you don't need to take the
partial derivatives of the distance function between points P and Q
(i.e. take the partials of an ugly function involving sines, cosines,
and square roots).
You don't need derivatives, you just need to find the matching zeroes of two
vector problems (which reduce to scalars because of the nature of the
triple product).
So I know it's not an equation, but maybe for those still interested in a
better method than trial and error, it's a step in the right direction.
This will continue to bug me for days, so I might be back with more later.
Date: 30 Mar 2003 19:15:08
Message: <web.3e87880ae86bfd1834dff4bb0@news.povray.org>
>The best I've been able to come up with so far is this...
Okay, I think I may have a fast and much more accurate approach than most of
the others mentioned.  First of all, it will be a numerical approximation
approach, so no derivatives.
Instead of finding parameterizations of the two circles, and going through
all 360 degrees of both circles and comparing the distances (which leads to
360*360 comparisons), we will simply pick an "arbitrary" point P1 on circle
C, and find the closest point on circle D to that point; call it Q1.  Then
we find the closest point on circle C to Q1, and call that P2.  Repeat
until desired accuracy is found.
So how do we pick our arbitrary point P1.  I say just pick the center, C.
There's a complicated reason why point C is a really good point to start
with.  And yes, I realize that technically it's not on the circle.  Don't
worry, it still works.  The only drawback is it throws off your first
distance measurement, if you care to take it.
Anyway, once we have a point on one circle, to find the closest point on the
other circle to that point, we simply do the following.
Given point P1 (C in this case), find the vector U1 = P1-D.  Assuming N is a
unit normal, make U1 perpendicular to N as follows:
U1 = U1 - N*(U1.N)
But we need U1 to have a length of R2 (we're on circle D), so Q1 = U1 * R2 /
sqrt(U1.U1).  I know, a pesky square root.  in POV-Ray, vlength(U1) =
sqrt(U1.U1).  Oh, and of course, we have to make sure that Q1 is centered
at D, so Q1 = Q1 + D.
Now rinse and repeat :)
//arbitrary circles for testing.
#declare C = <-1, 6, 3>;
#declare Rot1 = <25, 15, 50>;
#declare R1 = 1.2;
#declare M = vrotate(y, Rot1);
#declare D = <6, 3, 4>;
#declare Rot2 = <-55, 0, 30>;
#declare R2 = 1.5;
#declare N = vrotate(y, Rot2);
//Here's the formula itself
#declare Iters=5;
#declare P1 = C;
#while (Iters>0)
  #declare U1 = P1-D;
  #declare U1 = U1 - N*vdot(U1, N);
  #declare Q1 = D + U1 * R2 / vlength(U1);
  #debug concat("Distance is: ", str(vlength(Q1-P1), 5, 9),"\n")
  #declare V1 = Q1-C;
  #declare V1 = V1 - M*vdot(V1, M);
  #declare P1 = C + V1 * R1 / vlength(V1);
  #debug concat("Distance is: ", str(vlength(P1-Q1), 5, 9),"\n")
  #declare Iters = Iters-1;
Notice with the debug messages that three or four iterations should be
plenty, but five or six should give you very, very good accuracy.  In the
sample above, on my machine the accuracy maxes out at 10 significant digits
after the first part of the fifth iteration.
Like any of the formulas, there are probably scenarios that break this
formula, causing divide by zero errors or whatever.  But in general, it is
very, very fast.
Date: 30 Mar 2003 21:45:08
Message: <web.3e87aaf8e86bfd1834dff4bb0@news.povray.org>
>very, very fast.
Well, some combinations may require ten or fifteen iterations: if the
circles come close to touching, but at very oblique angles.
Date: 30 Mar 2003 23:05:29
Message: <3E87C1C0.7080301@alphalink.com.au>
Thanks for the code, that's pretty much the approach I was looking at,
but hadn't got around to implementing it yet.
Date: 31 Mar 2003 12:45:06
Message: <web.3e887e86e86bfd1834dff4bb0@news.povray.org>
I said there were probably scenarios that break my code, and I found one.
Take two circles, where the plane containing points C and D and vector M
also contains or very nearly contains vector N.  I.e. N ~= M + a*(D-C),
where a is arbitrary.  The easiest example is if M=N.
Now assume that the distance between C and D is less than (R1+R2), and that
the two circles are in very close parallel planes.  If this is true, then
the first point found by my algorithm, Q1, will lie roughly on a line
between C and D.  But the closest points (two of them) will be where the
circles would intersect if they were in the same plane.
If you moved point Q1 just a degree to the left or right, the algorithm
would eventually get one of the closest points.  But in this example, it
would bounce back and forth between two points on the line between the two
centers.
The only way I can think of to efficiently get around this is to make three
tests.  Start with a point between the centers C and D, and bail out when
the change in the distance is less than 1 part in 10^6 or 10^8 or whatever.
Then try two other starting points, at 90 degree angles to the original
starting point.  The easiest way to find these points would be to find:
Q1 = D-(Nx(Q1-D)) and Q1 = D+(Nx(Q1-D))
in this case, x means cross product.  Since N is a unit vector, the new
vector should still have a length of R2 (should... I haven't tried it yet).
These other two starting points should move much more quickly toward an
answer.
Also, since there can be two closest points, or two almost equally close
points, the original method might find a "local minimum" that is actually
not the minimum, so using this three point approach (or hell, just do the
two 90 degree off-center points, that might be even better) should
guarantee that you get the "most closest" point.
Date: 31 Mar 2003 18:48:42
Message: <3E88D711.5060606@alphalink.com.au>
Thankfully my circles are very well behaved. They never touch one
another, never lie in parallel planes and always have exactly one pair
of closest points.
