Subject: Partial sweeping around an axis
Date: 4 Dec 2002 13:38:22
Message: <3DEE4B86.30200@att.net>
Is there a way with SOR and lathe objects to limit the sweep to an arc
of x degrees, where 0 < x < 360 ? -- WITHOUT differencing of any kind?
--Thanks
MMW
In article <3DE### [at] att net>, Mark M Wilson <mrm### [at] att net>
Well, you could use intersections instead...not what you want, I think.
There is no way to do that without some kind of CSG or clipped_by.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
It seems like it _should_ be possible, considering how verbally easy the
idea is to convey -- not that there's necessarily a correlation between
the way an idea is expressed in words rather than equations! :-)
Maybe a feature for a future version?
--Mark
It would be very easy to do, and maybe it will someday be
implemented...but there is already an easy way to do it, using CSG or
clipped_by, and it is a very special-purpose feature, so there probably
isn't much interest.
The math behind it would be exactly the same as the math behind a CSG.
Why can't you use a CSG?
- Slime
[ http://www.slimeland.com/ ]
Since you had replied to my earlier posting about efficiency of CSG op's
and bounding, you may have gathered that I'm "on a mission" to root out
inefficiently coded CSG's, so I suppose I'm a little overzealous now in
trying to find the most efficient ways of describing some of my scene
elements. :-)
--MMW
I've nothing against CSG's; see my reply to CJH's posting (12-04-02,
2:38 pm) on this thread.
--MMW
> - Slime
In article <3dee7287$1@news.povray.org>, "Slime" <slm### [at] slimeland com>
Not really. An intersection or difference with 2 planes does quite a bit
more than necessary for this, there are a lot of possible optimizations
that could save some processing power. It is too little for too much of
a special case to get anyone excited about it though...
"Mark M Wilson" <mrm### [at] att net> wrote in message
news:3DE### [at] att net...
> I'm "on a mission" to root out inefficiently coded CSG's,
> elements. :-)
> --MMW
Then code what you can as a mesh approximation, and stop top posting. A
partial lathe mesh would be simple. I'm sure that some have done it, and
there is likely an example somewhere in p.b.s-f.
-Shay
What's "top posting?" Whatever it is, it seems to really bother you!
Mind your tone.
> A partial lathe mesh would be simple.
Sorry, not for this newbie. ;-)
--Mark
"LibraryMan" <mrm### [at] att net> wrote in message
news:3DEE7AD4.DE47D1A5@att.net...
> Mind your tone.
Top posting is typing a reply above another person's message, and leaving
the entire post to which you are repling, whether relevent or not, hanging
at the bottom.
Don't be so sure. It really depends on how efficient you want your mesh to
be. PoV-Ray does all of the math for you. Just keep rotating a column of
points with vrotate and connect the columns with triangles. Just like a tile
floor, but in a circle.
-Shay
