POV-Ray : Newsgroups : povray.general : Partial sweeping around an axis Server Time
23 Aug 2025 07:16:19 EDT (-0400)
  Partial sweeping around an axis (Message 1 to 10 of 11)
Subject: Partial sweeping around an axis
Date: 4 Dec 2002 13:38:22
Message: <3DEE4B86.30200@att.net>
Is there a way with SOR and lathe objects to limit the sweep to an arc
of x degrees, where 0 < x < 360 ? -- WITHOUT differencing of any kind?
--Thanks
MMW
Subject: Re: Partial sweeping around an axis
Date: 4 Dec 2002 14:01:00
Message: <chrishuff-0E0D77.13575704122002@netplex.aussie.org>
In article <3DE### [at] attnet>, Mark M Wilson <mrm### [at] attnet>
Well, you could use intersections instead...not what you want, I think.
There is no way to do that without some kind of CSG or clipped_by.
http://tag.povray.org/
Date: 4 Dec 2002 14:10:50
Message: <3DEE531E.4060409@att.net>
It seems like it _should_ be possible, considering how verbally easy the
idea is to convey -- not that there's necessarily a correlation between
the way an idea is expressed in words rather than equations! :-)
Maybe a feature for a future version?
--Mark
Date: 4 Dec 2002 14:41:51
Message: <chrishuff-21DA39.14384804122002@netplex.aussie.org>
It would be very easy to do, and maybe it will someday be
implemented...but there is already an easy way to do it, using CSG or
clipped_by, and it is a very special-purpose feature, so there probably
isn't much interest.
Date: 4 Dec 2002 16:24:23
Message: <3dee7287$1@news.povray.org>
The math behind it would be exactly the same as the math behind a CSG.
Why can't you use a CSG?
 - Slime
[ http://www.slimeland.com/ ]
Date: 4 Dec 2002 16:24:29
Message: <3DEE7295.9040707@att.net>
Since you had replied to my earlier posting about efficiency of CSG op's
and bounding, you may have gathered that I'm "on a mission" to root out
inefficiently coded CSG's, so I suppose I'm a little overzealous now in
trying to find the most efficient ways of describing some of my scene
elements. :-)
--MMW
Date: 4 Dec 2002 16:28:14
Message: <3DEE7377.8040202@att.net>
I've nothing against CSG's; see my reply to CJH's posting (12-04-02,
2:38 pm) on this thread.
--MMW
>  - Slime
Date: 4 Dec 2002 16:31:49
Message: <chrishuff-7370E3.16284704122002@netplex.aussie.org>
In article <3dee7287$1@news.povray.org>, "Slime" <slm### [at] slimelandcom>
Not really. An intersection or difference with 2 planes does quite a bit
more than necessary for this, there are a lot of possible optimizations
that could save some processing power. It is too little for too much of
a special case to get anyone excited about it though...
Date: 4 Dec 2002 16:48:21
Message: <3dee7825@news.povray.org>
"Mark M Wilson" <mrm### [at] attnet> wrote in message
news:3DE### [at] attnet...
>  I'm "on a mission" to root out inefficiently coded CSG's,
> elements. :-)
> --MMW
Then code what you can as a mesh approximation, and stop top posting. A
partial lathe mesh would be simple. I'm sure that some have done it, and
there is likely an example somewhere in p.b.s-f.
 -Shay
Date: 4 Dec 2002 16:59:40
Message: <3DEE7AD4.DE47D1A5@att.net>
What's "top posting?"  Whatever it is, it seems to really bother you!
Mind your tone.
> A partial lathe mesh would be simple.
Sorry, not for this newbie. ;-)
--Mark
