I have been using POVray for a while but one thing that really mystifies
me is the media function. Are there any good tutorial out there? At this
point I can't even get a glowing sphere.
Mike
Michael DiDonato, PhD
The Scripps Research Institute
Department of Molecular Biology
Maildrop MB4
10550 North Torrey Pines Road
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
http://www.scripps.edu/~didonato
Three words: trial and error.
Tim Cook
Version: 3.12
Michael DiDonato escribió en el mensaje de noticias
3DC### [at] scripps edu...
/* Try this. It's a macro made by Warp to create
glows. Study it and change some settings in the media
statement to see the effect */
#macro Glow(GlowColor, Scale)
sphere
{ 0, 1 hollow no_shadow
pigment { rgbt 1 }
interior
{ media
{ emission 1/Scale
density
{ spherical density_map
{ [0 rgb 0][.5 rgb GlowColor*.5][1 rgb 1]
samples 1,1 intervals 1 confidence .1 // quite fast settings
method 3
scale Scale
camera { location -z*10 look_at 0 angle 35 }
plane { y,-2 pigment { checker rgb 1, rgb .5 } }
light_source
{ <-1.5,1,0>, <1,.5,0>
looks_like { Glow(<1,.5,0>, .5) }
light_source
{ <2,.5,0>, <0,.5,1>
looks_like { Glow(<0,.5,1>, 1) }
object { Glow(<0,.5,1>, 1) translate 0 }
// Bye
Michael DiDonato <did### [at] scripps edu> wrote in news:3DC9B0EA.7060408
@scripps.edu:
> Mike
There are a couple here:
http://users3.ev1.net/~povstudy/i_tut1.htm
Surely in the n-dimensional space defined by the relevant variables there
are "hot spots" that can be used as starting points?
I wonder if this is true of all function parameter sets?
The trick is to find a good way of describing and classifying these hot
spots or attractors. A way of breeding and mixing them would be a very
powerful tool! Imagine the libraries that could be added to the next povray
distribution if a few of the experts started to map out some of this
parameter space.
Your connection failed because: The POP server is out of Coke
Thanks, this helps alot.
Mike
s
s
> sphere
> pigment { rgbt 1 }
> interior
> { media
> { emission 1/Scale
> density
> method 3
> scale Scale
> #end
> light_source
> light_source
> // Bye
Maildrop MB4
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
