POV-Ray : Newsgroups : povray.general : Help changing background light intensity Server Time
2 Nov 2026 19:43:00 EST (-0500)
  Help changing background light intensity (Message 1 to 18 of 18)
Subject: Help changing background light intensity
Date: 10 Oct 2002 17:46:40
Message: <3DA5F540.F2B3FA6E@ufl.edu>
I'm able to change the  intensity, but only if I also change the color.
Is there a way that I can change ONLY the intensity of the background?
Thank you for help ahead of time.
Subject: Re: Help changing background light intensity
Date: 10 Oct 2002 19:43:34
Message: <3da610a5@news.povray.org>
  You don't give enough information to give a proper answer.
  Are you talking about the background {} feature or the ambient_light
feature, or perhaps something else?
  Anyways, in order to change the intensity of a color, just multiply it
with a float.
Date: 10 Oct 2002 20:04:16
Message: <Xns92A414D28B47Eraf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3da610a5@news.povray.org
> with a float.
or use hsv2rgb macro (is that correct spellig ?)
btw.
how about ne future - types of colors interpolating :
colors_rgb
colors_hsv ?
i.e.
gradient color_map{[0 rgb <1,0,0>][1 rgb <0,1,0>] colors_rgb}
will give : red dirty-red dirty-yellow dirty-green green
gradient color_map{[0 rgb <1,0,0>][1 rgb <0,1,0>] colors_hsv}
will give : red red-yellow yellow yellow-green green
I will write try to implement this futre, do You think it would be usefull
Date: 10 Oct 2002 21:20:03
Message: <web.3da626df23ad0e644b26c9670@news.povray.org>
Take a big sphere instaed of a background {...} or a sky_sphere.
Then you have a finish definition also to play with. But it is not possible
to rise the ambient level and to not change the background color impression
imho.
Norbert
Date: 11 Oct 2002 03:18:58
Message: <fgucqu4mhn13aldspfkk016iom072qtuf3@4ax.com>
On 10 Oct 2002 20:04:16 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> > with a float.
CHSV2RGB(Color)
> btw.
> colors_rgb
> colors_hsv ?
Why ? If it is easy possible with macro (already included in official package)
then no need to waste time for coding. There will be no difference between
macro and builded feature. It have to be always converted to rgb internally.
No :-)
ABX
Date: 11 Oct 2002 08:18:27
Message: <3da6c192@news.povray.org>
  Why? That just slows down the rendering...
Date: 11 Oct 2002 15:40:42
Message: <chrishuff-7DF4DD.15370511102002@netplex.aussie.org>
In article <fgucqu4mhn13aldspfkk016iom072qtuf3@4ax.com>,
I think he is talking about different blending methods...currently,
color_maps do a linear interpolation of RGB colors, and will return <
0.5, 0.5, 0> with a pattern value of 0.5 with that color map, the user
might have expected < 1, 1, 0>. Doing a linear interpolation in HSV
space would give a very different blend...it would make it possible to
specify two colors with maximum brightness and saturation and get a
rainbow of hues all of the same brightness.
However, it would be slower. Not by a lot, the conversion of the color
entries could be done at parse time (assuming you will never want to
access the color entries directly, with something like an array syntax),
but it still has to convert back to RGB space. It may be faster to just
use an RGB map with more entries.
I have considered doing something related to this, along with different
interpolation types like cosine and cubic interpolation. Color maps are
very similar to splines in some ways, I've been thinking it might be
better to merge them into the spline feature.
Basically, all the *_map keywords would be replaced with "blend", the
parser would be smart enough to figure out what kind of blend is needed.
The color_map feature would be replaced with the spline feature.
Pigments would be vector functions. Something like that code could be
written as:
#declare colorSpline =
spline {
    [0, rgb2hsv(< 1, 0, 0>)]
    [1, rgb2hsv(< 1, 1, 0>)]
#declare theTexture =
    pigment hsv2rgb(colorSpline(bozo(x, y, z)))
Maybe an in-line syntax for splines too:
    pigment hsv2rgb(
        spline {//linear would be default
            [1, rgb2hsv(< 0, 1, 0>)]
        }(bozo(x, y, z))
Ok, that looks a bit wierd, but is much more flexible and could be
backwards compatible, it doesn't have to replace the existing syntax.
One thing I don't like, you have to watch for the differences between
code run at parse/scene setup time and code run at render time, but the
same problem exists now and it doesn't cause much trouble.
http://tag.povray.org/
Date: 12 Oct 2002 15:10:05
Message: <Xns92A5D713E8B18raf256com@204.213.191.226>
ABX <abx### [at] abxartpl> wrote in
news:fgucqu4mhn13aldspfkk016iom072qtuf3@4ax.com
>> btw.
>> colors_rgb
>> colors_hsv ?
> package) then no need to waste time for coding. There will be no
> difference between macro and builded feature. It have to be always
As Christopher pointed out, I was talking about different blending method.
HSV and even splines color map doesn't need to be slower, IF we would
optimize it - and i.e. precalculate 256 (with can be done even now - with
macro), or 4096 (or more) colors.
bozo color_map{[...][...] hsv_blending precalculate {4096}}
I have some more ideas for it, I will do some tests and post full hmm CFF
(Call For Feature ? maybe RFD ? is there some name for that documents :)
in near future :)
Date: 12 Oct 2002 15:12:10
Message: <Xns92A5D76E7C263raf256com@204.213.191.226>
"Norbert Kern" <nor### [at] t-onlinede> wrote in
news:web.3da626df23ad0e644b26c9670@news.povray.org
> possible to rise the ambient level and to not change the background
> color impression imho.
no,
background rgb A
sky sphere rgbf <B,B,B,f>
is same (but slower) as :
background rgb A*(f)+b*(1-f)
Date: 12 Oct 2002 15:40:59
Message: <Xns92A5DC51D488Fraf256com@204.213.191.226>
Christopher James Huff <chr### [at] maccom> wrote in news:chrishuff-
7DF### [at] netplexaussieorg
>     pigment hsv2rgb(
>         }(bozo(x, y, z))
IMHO I think that this syntax is wierd [1], better would be to extend
color_map by new keywords.
[1] this time it's me who is criticizing :P no offence :)
Date: 12 Oct 2002 19:45:51
Message: <chrishuff-15F703.19404512102002@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
Well, yes, it does look wierd at first. The point is that it is far more
flexible...a pigment is just a function that returns an RGB color
vector, a color map is just a vector spline, which is also a function.
If you want interpolation in a different color space, just convert back
to RGB for the final value. If you want your own custom function instead
of a color map, no problem. It can express any existing POV texture, and
much more, without being much longer if at all.
Adding a special color map feature just adds bulk to an already
redundant feature.
Date: 12 Oct 2002 20:56:07
Message: <Xns92A61D9BB8D4Eraf256com@204.213.191.226>
15F### [at] netplexaussieorg
> redundant feature.
I can't agree, in same way we can say that sphere,box,etc are redunant
versions of i.e. isosurface.
I alsow realy like SDL, but if we will continue to implement everything
possible in SDL istead of C we will end with parse-times longer then
renders ;-/ and with straaange syntax.
My sugesstion(s) : (PS. I think that some of this realy can be usefull
maybe for a change try to find something good instead of criticize each-
other's ideas :)
  bozo
  color_map {
    [0 rgb x]  // #1 blend to next entry using global blend type
    [0.1 rgb y blend_rgb] // #2 blend to next entry  RGB
    [0.2 rgb z] // #3 blend to next entry using global blend type
    [1 rgb x+y] // #4 blend to next entry using global blend type
    blend_hsv // set global entry (used for 1,3,4)
    precalc {4096} // precaluate 4096 RGB values to optimize speed
---Explanation step by step---
typical rgb colormap:
  color_map {[0 rgb x][1 rgb x+y]}
hsv blend colormap:
  color_map {[0 rgb x][1 rgb x+y] blend_hsv}
  <1,0,0> - <1,1,0> will be interpolated as HSV
hsv blend colormap with more entries
  color_map {
     [0 rgb x][0.1 rgb y][0.2 rgb z][1 rgb x+z] blend_hsv }
  <0,0,0>-<0,1,0> interpolate as global (set here to HSV by blend_hsv)
  <0,1,0>-<0,0,1> interpolate as global (set here to HSV by blend_hsv)
  <0,0,1>-<1,1,0> interpolate as global (set here to HSV by blend_hsv)
  <1,1,1>-<0,0,0> interpolate as global (set here to HSV by blend_hsv)
hsv blend colormap with more entries and exception
  color_map {
     [0 rgb x][0.1 rgb y blend_rgb][0.2 rgb z][1 rgb x+z] blend_hsv }
  <0,1,0>-<0,0,1> interpolate as RGB (set only here by blend_rgb)
same, with precalcuate
  color_map { ...
    precalc{4096}
Date: 12 Oct 2002 21:03:50
Message: <Xns92A61EEB092C7raf256com@204.213.191.226>
And btw. no offence but - Christopher, how about implementing photons using
trace() that runned in recursive loop will create an big union of very
small spheres with filter (that will look like photon dots) and remove at
least this bulky and redunant Photnos{} blocks ;) ? Syntax will be very
nice, someting like :
  ADD_PHOTON_OBJ( box{...}, 1,1) // 1=reflection 1=refraction
  SHOOT_SDL_PHOTONS(50000) // 50000=count = please come back tomorrow
Date: 12 Oct 2002 21:53:42
Message: <chrishuff-60F10B.21483712102002@netplex.aussie.org>
No, you can't...the isosurface object uses a completely different way to
solve for the shape, takes a different kind of input, etc. A color map
is a linear spline with some limitations...it can only take color
values, and can only have 256 elements. Instead of removing the
limitations and adding features, my suggestion is to replace it with the
existing spline feature and add features to *that*. Instead of a color
map with options for things like cubic blending, just have a color
spline with the same syntax as any other spline.
The other stuff, the color space functions and pigment-as-function, were
just a much more flexible and more consistent way of accomplishing the
same result, interpolating in a different color space, as well as much,
much more.
This wouldn't have any impact on parse time. It might slightly slow
render time, but it would be more capable than a vast array of
hard-coded features.
> pigment {
>   bozo
>   color_map {
This is really crying for the old (and currently deprecated) blend
syntax, which gave each end of a range as well as the color of each end:
pigment {bozo
  color_map {
    blend_hsv
    [0.0, 0.1 rgb x, rgb y]
    [0.1, 0.2 rgb y, rgb z blend_rgb]
    [0.2, 1.0 rgb z, rgb x+y]
    precalc 4096
But I still don't think this syntax is necessary...that function syntax
I proposed would handle it just fine for those cases where it is needed.
That precalc idea...I don't think I like it. For one thing, it would
only help a few cases, and would hurt a lot of others. It would be
required so rarely that it could easily be coded as a loop instead. And
the differences between per-range and per-map blending modes would
complicate things unnecessarily and cause confusion, its main advantage
would be reducing typing.
Date: 12 Oct 2002 22:16:50
Message: <Xns92A62B4B681A2raf256com@204.213.191.226>
60F### [at] netplexaussieorg
Hmm ok... but I don't understand, how can I use this spline to get HSV
blend beetwen :
  [0  rgb <1,1,0>]
  [.5 rgb <1,0,0>]
  [1  rgb <.3,1,.3>]
I was talking in generaly about Your's approach "why hard code while we can
do it in SDL"
> pigment {bozo
>   color_map {
>     blend_hsv
>     precalc 4096
You realy doesn't like changes ;) IMHO :
a) users that don't use it - will not notice it
b) users with do use it - will appriciate this possibility.
Btw. it can be used along with Yours spline idea (if I understand it
correctly).
only if we add function color_map_value_at(float,COLOR_MAP)
but hmm I do agree :) maybe just code this function instead.
Hmm in fact this is where I woulud agree alsow that using SDL is good.
#macro color_map_at_value(_v,_cmap) - make function i.e. gradient x at
return it's color at <_v,0,0>
hmm what was full syntax for it ?
Date: 13 Oct 2002 12:10:08
Message: <chrishuff-5D0470.12050613102002@netplex.aussie.org>
That is a rediculous analogy. I suggest you look into how photons really
work...
Date: 13 Oct 2002 12:19:14
Message: <Xns92A6BA1E2EA0raf256com@204.213.191.226>
news:chr### [at] netplexaussieorg
>> Syntax will be very nice, someting like :
> I suggest you look into how photons really work...
I did that already... and ? Yes to make it work SDL should be informed
about lights, and about ALL scene objects that might block photons.
But this is only a joke :)
Date: 13 Oct 2002 12:47:59
Message: <chrishuff-993526.12422113102002@netplex.aussie.org>
> blend beetwen :
>   [0  rgb <1,1,0>]
>   [.5 rgb <1,0,0>]
>   [1  rgb <.3,1,.3>]
hsv2rgb(spline {
    [0.0 rgb2hsv(< 1, 1, 0>)]
    [0.5 rgb2hsv(< 1, 0, 0>)]
    [1.0 rgb2hsv(< 0.3, 1, 0.3>)]
}(tVal))
It is just basically a spline function declared at the time it is used:
spline {ENTRIES} (T-VALUE)
The same would exist for things like transform or pattern functions,
just a way to use them in-line without having to declare them.
This approach is infinitely flexible, here's a "color map" that always
results in a color with a length equal to 1:
declare Foo = function (t){vnormalize(spline {...}(t))}
And here's one that always results in a color where the maximum
component is equal to 1: (function variable syntax still being worked
out)
declare Bar =
function (t) {
    def col = spline {...}(t);
    col/max(col.red, col.green, col.blue)
pigment Foo(bozo(x, y, z))
pigment Bar(radial(x, y, z))
It reflects the actual arrangement of things: the color map is a
function with the pattern result as input, and gives you great control
over computation.
> do it in SDL"
In general, hard coding is bad because it increases complexity and
reduces flexibility, but there are times it is necessary. In this case,
it is more "why add one specific feature when adding a more general
feature does the same thing and more".
> correctly).
Right, the syntax is distinct enough that the parser can easily
determine what is desired. I just don't think it would be required often
enough.
No reason for that. We don't have or need "array_value_at()" or
"spline_value_at()".
I haven't covered what I want to do to the other blend types...there
would be an "associative array" or "map" data type, splines and blends
would be based off of this. "MyTextureMap[3]" would return the third
element, "MyTextureMap(0.3)" would evaluate the textures and return the
blended result (I haven't figured out how the intersection information
would be handled, maybe a new intersection type that would be passed
along).
