POV-Ray : Newsgroups : povray.general : Calculating the normals of a triangle Server Time
2 Nov 2026 21:46:08 EST (-0500)
  Calculating the normals of a triangle (Message 1 to 14 of 14)
Subject: Calculating the normals of a triangle
Date: 11 Sep 2002 08:03:19
Message: <3D7F30C8.9030800@fritschy.de>
i wrote a simple triangulation algo for a noise program to generate
something like a hieghtfield, and i wanted to use this with
smooth_triangles, does anybody knows how to calculate the normals of the
three points from the known triangle?
greetings, Marcus
Subject: Re: Calculating the normals of a triangle
Date: 11 Sep 2002 08:36:12
Message: <qvdunu4kj2h82glmf0i9l824m2t65gov8v@4ax.com>
On Wed, 11 Sep 2002 14:02:16 +0200, Marcus Fritzsch <m### [at] fritschyde> wrote:
It is averaged addition from normals of all triangles in this vertex.
Be aware it can be weighted with angle/area:
http://news.povray.org/povray.binaries.images/13313/
ABX
Date: 11 Sep 2002 08:40:51
Message: <3d7f39d3@news.povray.org>
  There are basically two ways:
  1. If you know the function which was used to generate the mesh and you
can derive the function with respect to x, y and z (or x and y in the
case of a heightfield function f(x,y)), then you can use the gradient
of the function (ie. <df(x,y)/dx, df(x,y)/dy>) to calculate the normal
vector at any point of the function.
  2. If you don't know the function, or the function is not differentiable
(or it's just too difficult to do so), then you can use an approximation
which works quite well for (almost) any mesh: The normal vector at a vertex
point is the sum of all the normal vectors of the triangles sharing that
vertex.
  (The normal vector of a triangle can be calculated with the cross-product
of two of its edges. According to empirical tests, *not* normalizing these
normals gives the best result in the sum described above (because the
dot-product of the two edges of a triangle gives a normal vector which
length is equal to the area of the triangle, and not normalizing this
vector means that a larger triangle has more effect in the normal of the
vertex than other smaller triangles sharing that same vertex, which
reportedly gives better results).)
Date: 11 Sep 2002 09:54:08
Message: <3D7F4AC0.4090901@fritschy.de>
this was exactly what i searched!!
>   1. If you know the function...
Hmm, i guess i don't know the function...
> (or it's just too difficult to do so)...
I'll try this way!
thx a lot :o)
regards, Marcus
Date: 11 Sep 2002 10:20:03
Message: <web.3d7f50003836a27fedbc6d4c0@news.povray.org>
>vertex.
I guess you meant to write 'cross-product' here ;)
Tor Olav
Date: 11 Sep 2002 10:24:43
Message: <3D7F51EA.3080804@fritschy.de>
Hi again...
I have some problems with this part, first you told me about
cross-product of
the edges, than, 2 lines below of the dot-product of the 2 edges...
which one
is right? my maths aren't enough to understand this before have it used
it and
seen the result...
greetings, Marcus
Date: 11 Sep 2002 10:27:18
Message: <3d7f52c2@news.povray.org>
  Yes.
Date: 11 Sep 2002 10:28:15
Message: <3d7f52ff@news.povray.org>
> cross-product of
> which one
> is right?
  Writing "dot-product" was a mistake. It should have been "cross-product".
Date: 11 Sep 2002 10:30:01
Message: <3D7F532A.4080802@fritschy.de>
Hi, :o)
>>cross-product of
>>which one
>>is right?
oops, i wrote my message while the other was postet... :o) ok, now i
know it, thx!
mfg Marcus
Date: 11 Sep 2002 10:45:13
Message: <web.3d7f566a3836a27fedbc6d4c0@news.povray.org>
Warp wrote:
>(because the
Its length is equal to twice the area of the triangle.
Tor Olav
Date: 11 Sep 2002 10:50:11
Message: <web.3d7f578b3836a27fedbc6d4c0@news.povray.org>
Marcus Fritzsch wrote:
>Hi,
This post (and thread) relates to the suggestions by ABX and Warp:
http://news.povray.org/povray.binaries.images/22677/?mtop=157723&moff=33
Tor Olav
Date: 11 Sep 2002 14:45:09
Message: <web.3d7f8d183836a27fc7e287770@news.povray.org>
>Hi,
>greetings, Marcus
to get the normal (N) of a straigh triangle, if your vertexes points are V0,
V1, V2,
#declare N= vcross(V1-V0,V2-V0);
the to make it a unit vector (Nu) try,
#declare Nu = vnormalize(vcross(V1-V0,V2-V0));
For a smooth Triangle each vertex will have a differant normal, in that case
you'd have to find two vectors that are tangent with the surface at the
vertex (just as  V1-V0 and V2-V0 are).  If you know of two other points
close to the vertex then you could get a normal that is close.   Best is to
take the derivites at the vertex (which is what the others are talking
about).
Tony
Date: 11 Sep 2002 19:19:21
Message: <3d7fcf78@news.povray.org>
>>(because the
  Oops, you are right. What was I thinking?
  (Well, it doesn't matter with respect to the sum of all normals...)
Date: 18 Sep 2002 23:15:08
Message: <web.3d893fea3836a27f8c441f020@news.povray.org>
 >>Hi,
 >>greetings, Marcus
V0,
 >V1, V2,
 This is almost correct. A more complete description would be:
 To obtain the normal at any vertex, take the cross product of the two
 vectors defined by the two adjacent sides. That is, for V0, V1 and V2,
 labeled clockwise, you would obtain the normals N0, N1 and N2 thusly:
    N0 = vcross(V2 - V0, V1 - V0);
    N1 = vcross(V0 - V1, V2 - V1);
    N2 = vcross(V1 - V2, V0 - V2);
 Of course, since a triangle is a planar object, all three normals would
 point in the same direction and would be parallel lines (except for the
 degenerate case. Of course, if this were true, you could not obtain the
 vector cross product). Note: It does not matter if you use a left-handed
 or right-handed coordinate system as long as the same system is used for
 all the vector operations on any single object. I also do not think the
 handedness has any relation to POV-Ray's left-handed coordinate system.
 This is true, but may not be what is desired. When grouping triangles
 together into a mesh, keeping the magnitude of the cross product instead
 of normalizing it will lend bias for each of the triangles' normals that
 share a common vertex. This information is lost in the normalizing process.
 The definition of a vector cross product C = A X B is: The magnitude of the
 resulting vector equals the product of the magnitudes of the two vectors to
 be crossed times the sine of the angle between them. The direction of the
 result is perpendicular to the plane containing the two vectors. It points
 in the direction determined by the order and the handedness of the system.
 Hence, A X B does not equal B X A. The magnitudes are the same, but the
 directions are opposite. Switching handedness reverses this relationship.
 So, for small sides and small angles (or very obtuse angles), the effect
 may be small. For angles that are nearer to perpendicular and long sides,
 the effect may be large. YMMV. This may be what is desired.
case
to
 >about).
 The way POV-Ray obtains many of its surface effects is not by actually
 changing the shape of the object (blob, height_field and some newly added
 primitives excepted), but by changing the NORMAL to the surface at the
 point of intersection with a ray. If you put waves on a plane and look at
 that plane end on, all you will see is a line (if anything). The third
 dimension does not exist. If you made a sphere out of smooth triangles,
 like a geodesic dome, as the number of vertices is reduced the straight
 edges would become apparent even though the shading might not look that
 bad. Manipulating the surface normals to affect the incident and/or
 reflected and/or refracted ray(s) is how the  effects are obtained, and
 the results are somewhat illusory. So it really does not make sense to
 determine the tangent(s) or derivitive(s) explicitly at any given point.
 (Actually, the tangent IS the derivitive at any point, but in the case
 of an object that is not smooth, as in the case of boxes, triangles and
 the results of some CSG objects, the edges are sharp and the derivitive
 at some arbitrary point along those edges does not exist.)
 What you probably want is to determine the cross product (normal) for
 each triangle that meets at a specified vertex, average all of those
 vectors, normalize them and then use that result for the normal of
 each smooth_triangle that contains that vertex. It can be a lot of
 calculation, but the results are probably more in line with what you
 want. I wrote an include file several years ago to produce the threads
 of a machine screw that used this technique. If anybody wants it, just
 send me an email. I am listed in the community in the USA area if my
 email address can't be found here.
 Tip: Be VERY meticulous about keeping track of all the signs and order
 of all the vectors, as a single error might ruin the object and the
 cause can be VERY hard to find. Be sure of what you are doing and debug
 as you write.
 I hope this helps.
