POV-Ray : Newsgroups : povray.general : Macro assist? Server Time
22 Oct 2026 21:53:04 EDT (-0400)
  Macro assist? (Message 1 to 4 of 4)
Subject: Macro assist?
Date: 12 Aug 2002 03:36:11
Message: <3D57656A.1070600@scifi-fantasy.com>
Ok, I have a program in BASIC that I'm using to generate
random numbers for a sphere_sweep, that looks like:
randomize timer
for n=1 to 23
   theta%=(rnd*36)*20
   r = rnd*0.24
   x = r*COS(theta%)
   y = r*SIN(theta%)
   z = (rnd*0.5)+1.25
   ? USING "X = +#.#####  Y = +#.#####  Z = +#.#####";x,y,z
next n
now, instead of running this program and entering the
values by hand in my sphere_sweep, how do I make a
macro in POV to generate a series of n points for the
sphere_sweep?
Tim Cook
Version: 3.12
Subject: Re: Macro assist?
Date: 12 Aug 2002 03:51:30
Message: <eppelu09kja01hgcgq9uha0crolk5c90d1@4ax.com>
On Mon, 12 Aug 2002 03:36:10 -0400, "Timothy R. Cook"
<tim### [at] scifi-fantasycom> wrote:
> randomize timer
#declare Seed=seed(SeedNr);
> for n=1 to 23
#declare N=1;
#while(N<=23)
>     theta%=(rnd*36)*20
#declare Theta=rand(Seed)*36*20;
>     r = rnd*0.24
#declare R=rand(Seed)*24;
>     x = r*COS(theta%)
#declare X=R*cos(Theta);
>     y = r*SIN(theta%)
#declare Y=R*sin(Theta);
>     z = (rnd*0.5)+1.25
#declare Z=rand(Seed)*0.5+1.25;
#debug concat(
         "  X = ",str(X,0,-1),
         "  Y = ",str(Y,0,-1),
         "  Z = ",str(Z,0,-1),
       "\n")
> next n
#declare N=N+1;
Is it readable and sufficient or do you need some addition ?
ABX
Date: 12 Aug 2002 04:02:30
Message: <3D576B93.8070000@scifi-fantasy.com>
Should work...let's see...wow, I made a typo; that was 36*10,
not 36*20...but I can change it to 360...yep, this works fine.
Thanks!
Tim Cook
Version: 3.12
Date: 12 Aug 2002 04:14:19
Message: <3D576DBE.9080806@b0n541.net>
> randomize timer
> for n=1 to 23
>   theta%=(rnd*36)*20
>   r = rnd*0.24
>   x = r*COS(theta%)
>   y = r*SIN(theta%)
>   z = (rnd*0.5)+1.25
> next n
I don't know BASIC very well, so maybe I changed the formulas a bit. But
this is a fast hack for a macro:
#macro makeASphereSweep(numberOfPoints, splineType, startSeedValue)
	sphere_sweep
	  #switch (splineType)
                 #case (1)
		  linear_spline
   		#break
   		#case (2)
		  b_spline
   		#break
   		#case (3)
   		  cubic_spline
   		#break
		#else
		  linear_spline
	  numberOfPoints, // No. of spheres
	  #declare random = seed(startSeedValue);
	  #declare n = 0;
	  #while (n < numberOfPoints)
	    #declare theta = (rand(random) * 36) * 20;
	    #declare r = rand(random) * 0.24;
	    #declare x_val = r * cos(theta);
	    #declare y_val = r * sin(theta);
	    #declare z_val = (rand(random) * 0.5) + 1.25;
	    #if (n < numberOfPoints - 1)
	      <x_val, y_val, z_val>, r,
	    #else
	    #declare n = n + 1;
		pigment
			color rgb 1
And then call your macro with:
makeASphereSweep(50, 1, 123)
Hope that helps a bit...
So long,
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
