I just wonder how much work it would take to add two features which I
would find great in the windows editor of WINPOV:
1 - Highlight matching braces. When the cursor is close to { or }, the
matching one is highlighted. It would be much easier to understand the
code in deeply nested objects, CSG, ..... Most unix editors have this
feature.
2 - Expanding keywords : When the beginning of a keyword is written in
the editor (ie 'ligh'), the user should be given the choice of the
possible matching keywords ( 'light_source' or 'light_group'.
If only one keyword matches (ie 'cam'), the editor should complete that
keyword ('camera').
Scite does this.
If you want clear examples, both features are implemented in my Linux
POV-RAY editor at :
http://pyvon.sourceforge.net see screenshots
You have to have Python installed first.
> that keyword ('camera').
Type "cam" and press tab. Type "ligh" and press tab a few times.
Also read the sections 1.5.5 and 1.5.6 of the documentation for even
more options.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
> feature.
I'm pretty sure if you put the cursor near a brace and press ctrl+], it will
go to the matching brace. I might have the shortcut wrong... check the
menus.
- Slime
[ http://www.slimeland.com/ ]
"Slime" <slm### [at] slimeland com> wrote in message
news:3d168081@news.povray.org...
will
> menus.
The shortcut is correct. However you can't perform it on every keyboard...
if this is a problem, you can always change it to what you like by doing
menu: Editor/Editor Preferences... [Alt+Enter].
Povingly,
Philippe
I guess this feature is new on POV 3.5. I have not tried it yet on
Windows. ( I don't want to download 6.5 Meg (twice) every week or so).
In that case sorry for the mistake.
Fabien
> Fabien
By the way would not it be more convenient just to have the executable
to download for those who just want to play with POV 3.5. I know that
the POV team does this to have all the files (help, demos, includes)
properly updated, but still....
6.5 Meg to 1.5 would make a difference.
>>feature.
> menus.
> - Slime
That's the point : Why press Ctrl+] while an automatic highlight is
possible ? It does not drain out computer resources to do that.
Fabien
Once you download and install 3.5 for windows once, you can download the
VC++ compile which is just the executable.
-tgq
And then p.beta-test gets filled of bug reports which are actually
caused because of not using updated include files?
