There's no unicode support! All I get are question marks!
(keep in mind I have the same bone to pick with several other
apps, but...I want unicode support!)
Tim Cook
http://personal.lig.bellsouth.net/lig/z/9/z993126
Version: 3.12
(Of course, this might be a bug with moray, in which case
THAT needs to be fixed. Ideally both.)
Tim Cook
Version: 3.12
On Sat, 27 Apr 2002 11:15:06 -0400, "Timothy R. Cook" <z99### [at] bellsouth net>
Where ? In 3.5 ? Have you verified syntax and script with documentation ?
There are better places for discussions about Moray.
ABX
> documentation ?
I take character map and copy a unicode character to clipboard.
Paste in POV. Get '?'. So is a POV problem.
Tim Cook
Version: 3.12
(looking in docs I see unicode supported as \u####, but that is
a bit of a pain when I can just cut and paste the character
itself in most other apps)
Tim Cook
Version: 3.12
On Sat, 27 Apr 2002 12:10:40 -0400, "Timothy R. Cook" <z99### [at] bellsouth net>
Have you noticed "We suggest you use a text editor with the capability to
export text to UTF8 to generate input files." ? Are you sure you have used
such editor ?
ABX
I don't know how your apps and OS cut and paste things, but does the term
'portability' ring a bell?
Last updated 26 Apr. 2002 _____./\/^>_*_<^\/\.______
On Sat, 27 Apr 2002 12:06:09 -0400, "Timothy R. Cook" <z99### [at] bellsouth net>
POV-Ray is raytarcer not editor. Editor is just a GUI. GUI writes script to
file before parsing. Parser takes script from file not from editor. Have you
verified that there are unicode codes inside script during parsing ?
ABX
> does the term 'portability' ring a bell?
So what you're saying is Windows XP's way of doing things
is completely incompatible with the rest of the world, even
though it uses the same word for what it's doing, as usual.
*grumble*
Tim Cook
Version: 3.12
