POV-Ray : Newsgroups : povray.general : Announce: IsoCSG include file 0.2.1 Server Time
3 Nov 2026 09:15:27 EST (-0500)
  Announce: IsoCSG include file 0.2.1 (Message 1 to 14 of 14)
Subject: Announce: IsoCSG include file 0.2.1
Date: 13 Mar 2002 08:36:40
Message: <3C8F55E7.77E12712@gmx.de>
I fixed a few problems since i posted the first version in p.b.s-f.  Also
wrote some documentation and an add-on for the Povray 3.5 insert menu.
http://www.tu-bs.de/~y0013390/pov/ic/index.html
Last updated 13 Mar. 2002 _____./\/^>_*_<^\/\.______
Subject: Re: Announce: IsoCSG include file 0.2.1
Date: 13 Mar 2002 09:14:22
Message: <bemu8u8rn9l1oif9knjjlvun120e62aihc@4ax.com>
On Wed, 13 Mar 2002 14:36:39 +0100, Christoph Hormann <chr### [at] gmxde>
Can I have feature request ?
I think it could be interesting to somehow add automatic calculation of
bounding/container box. I mean making pairs:
IC_Box (V1, V2) and IC_BBox (V1, V2)
IC_Sphere(Center,R) and IC_BSphere(Center,R)
IC_Cone(V1,R1,V2,R2) and IC_BCone(V1,R1,V2,R2)
and so on.
All macros with B letter can internally call those without B but additionally
also create real object. For example IC_BBox(V1,V2) can looks like
  #macro IC_BBox(V1,V2)
    IC_Box(V1,V2) , box{V1,V2}
Note this important comma as part of RValue. Now CSG operations with bounding
consideration can look like:
#macro IC_BDifference2( F1 , B1, F2 , B2 )
  IC_Difference2( F1 , F2 ) , difference{ B1 B2 }
Also additional transformation macros should be added such IC_BScale etc.
And finnally you can split that result into function and container:
#macro IC_Extents( F , B , Min , Max )
  #declare Min = min_extent( B );
  #declare Max = max_extent( B );
  function{ F(x,y,z) }
Having corners of container somebody can easly increase/decrease it with some
margin to consider deformations and apply it to the isosurface.
Was this proposition understable ?
ABX
Date: 13 Mar 2002 09:34:27
Message: <3c8f6373$1@news.povray.org>
Great work and documentation, I'm sure this took some time. I'm eager to
find out if there's a way to BLOB those mixed primitives? I suppose this
can't be done, at least with sharp-edged objects like boxes.
Hugo
Date: 13 Mar 2002 09:45:11
Message: <cdpu8u0765jf7l51r3p8c20firf0m4aq3s@4ax.com>
Blobed isosurfaces are described in 3.5 documentation.
ABX
Date: 13 Mar 2002 10:28:04
Message: <3C8F7004.C189E475@gmx.de>
Yes, but i'm not sure if i will add this, you won't be able to declare
things like:
#declare fn_1=IC_BBox(-1, 1)
And this would lead to a lot of confusion i think.  I might add some
global variables to manage the relevant extends of each macro call.  This
way you could easily design the function as now and just use these global
variables in the 'contained_by{}' statement afterwards (or i could provide
a 'Create_Container()' macro doing this automatically).
Date: 13 Mar 2002 10:31:04
Message: <3C8F70B8.5A1C54CC@gmx.de>
As ABX said this is described in the 3.5 docs.
It is on my list for future extensions of the include file.
Date: 13 Mar 2002 10:49:42
Message: <1ksu8u87s2if4j2vbp9jhh2tfo12e64i2u@4ax.com>
On Wed, 13 Mar 2002 16:28:04 +0100, Christoph Hormann <chr### [at] gmxde>
> things like:
when you want function then you call
#declare fn_1=IC_Box(-1, 1); // without B
when you want function with container then you call
#declare fn_1=IC_Extents( IC_BBox(-1, 1), V1, V2 );
All user have to convert statement made in your set of macros is to add letter
B in all names and enclose whole function in IC_Extents call.
IC_Extents gets 4 parameters but 2 of them are returned from IC_BBox
With good documentation you can avoid it
> I might add some
Note that my example maintained bounding objects instead extents. In
particular when you apply hundreds of small rotations into object then
bounding stored as Min,Max corners can grow up while bounding stored as object
is still the same size.
> This
In this case it could be better to name it Get_Container() then direct create
contained_by{} statement. Coordinates are useful for further modifications.
ABX
Date: 13 Mar 2002 11:11:13
Message: <3C8F7A1F.44247447@gmx.de>
All right, this would work.
But i want to keep it as simple as possible, doubling the number of macros
and having several additional helpers macros would not exactly simplify
things.  Also the CSG macros (difference, etc.) right now can take any
other function too.  The 'B' version would be more restrictive.  And
infinite shapes (only 'plane' right now) would lead to nonsense results.
Date: 13 Mar 2002 12:02:27
Message: <kuuu8us2iruhj6454g91o8h4abavr3kjsl@4ax.com>
On Wed, 13 Mar 2002 17:11:11 +0100, Christoph Hormann <chr### [at] gmxde>
> things.
You can stay as is with your iso_csg.inc include file and not change anything
in your set of macros neither documentation. In fact I did everything for you.
Take a look what was changed (after moment in povray.binaries.scene-files - be
carefull - not tested). If user want simple version then he use your script as
"iso_csg.inc" if he want automatic container then he add b in letter of
include file, macro names, and addional IC_Extents call. I think it is simple
enough.
> other function too.
Not, you still can use any other function, just add additional parametr as
container of this function.
> And infinite shapes (only 'plane' right now) would lead to nonsense results.
Sure, but author can aware about it in documentation ... ;-)
ABX
Date: 14 Mar 2002 08:31:23
Message: <4a919u88sccs10t78e21ssgf4aimjlm1s0@4ax.com>
Here is proposition of IC_Box macro with function returning linear distance to
the box shape.
#macro IC_Box( Start , End )
  #local Start=Start+<0,0,0>;
  #local End=End+<0,0,0>;
  #local Cx=max(Start.x, End.x);
  #local Cy=max(Start.y, End.y);
  #local Cz=max(Start.z, End.z);
  #local Dx=min(Start.x, End.x);
  #local Dy=min(Start.y, End.y);
  #local Dz=min(Start.z, End.z);
  #local Inside=function{pattern{object{box{ Start , End }}}};
  function(x, y, z){
    select(
      Inside(x,y,z),
      0,
      f_r(min(x-Dx,max(x-Cx,0)),min(y-Dy,max(y-Cy,0)),min(z-Dz,max(z-Cz,0))),
      max(x-Cx, y-Cy, z-Cz, Dx-x, Dy-y, Dz-z)
ABX
Date: 14 Mar 2002 17:57:10
Message: <3C9129E6.373D4186@hotmail.com>
Christoph, I have had a look at the
code in the iso_csg.inc file.
And below are some of my suggestions
for simplifications of those macros.
I'm not sure, but from a very brief
test on my slow P100 PC at home, the
iso_csg_test02.pov file seems to
render a little bit faster with these
changes.
I have not tested all the macros below,
because I do not have patience to do
further tests with this PC (~150 PPM).
I have also added to more macros:
IC_Reorient() and IC_AxisRotate()
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#macro IC_Transform(Fn, Trans)
  #local fn_T = function { transform { Trans inverse } }
  function {
    Fn(
      fn_T(x, y, z).x,
      fn_T(x, y, z).y,
      fn_T(x, y, z).z
#end // macro IC_Transform
#macro IC_Translate(Fn, pTranslate)
  IC_Transform(
    function { Fn(x, y, z) },
    transform { translate <0, 0, 0> + pTranslate }
#end // macro IC_Translate
#macro IC_Scale(Fn, vScale)
  IC_Transform(
    transform { scale vScale }
#end // macro IC_Scale
#macro IC_Rotate(Fn, vRotate)       // Rotate Degrees
  IC_Transform(
    transform { rotate <0, 0, 0> + vRotate }
#end // macro IC_Rotate
#macro IC_RotateR(Fn, vRotate)      // Rotate Radians
  IC_Transform(
    transform { rotate <0, 0, 0> + vRotate*180/pi }
#end // macro IC_RotateR
#macro IC_Reorient(Fn, vAxis1, vAxis2)
  IC_Transform(
    transform { Reorient_Trans(vAxis1, vAxis2) }
#end // macro IC_Reorient
#macro IC_AxisRotate(Fn, Angle)
  IC_Transform(
    transform { Axis_Rotate_Trans(vAxis, Angle) }
#end // macro IC_AxisRotate
#macro IC_Matrix(Fn, Mtrx)       // not equivalent to the matrix transform!
  IC_Transform(
    transform {
      matrix <
        Mtrx[0][0], Mtrx[0][1], Mtrx[0][2],
        Mtrx[1][0], Mtrx[1][1], Mtrx[1][2],
        Mtrx[2][0], Mtrx[2][1], Mtrx[2][2],
                 0,          0,          0
#end // macro IC_Matrix
Date: 16 Mar 2002 10:30:16
Message: <3C936501.FB97AE41@gmx.de>
Sorry for the late reply, i had difficulty keeping track of all postings
recently.
I tested the 'transform' version of the macros some time ago and found no
measurable difference.  I have the tendency to prefer the 'discrete'
version since you can actually see what happens... ;-)
The 'special' transforms will be added in the next release.
Date: 18 Mar 2002 07:20:32
Message: <8plb9uge30bck8h0q12g3ljh6imkt4t9tj@4ax.com>
Thank You, Chris. Your include files opened my eyes for simplest morphing I
have ever seen. Perhaps this was used somewhere before but I feel like
discoverer at this moment :-) Check povray.binaries.animations after moment.
All things I had to do were:
1) prepare initial appearance of object as (ISO)CSG
2) prepare final appearance of object as (ISO)CSG
3) write isosurface functions as
      (1-clock)*POV(x,y,z) + clock*v35(x,y,z)
   where  POV and v35 are isocsg combinations
Adventages:
1) Shape is desiagned as previously as simple CSG
2) No trace, interpolate, arrays, loops were involved
3) Morphing is pretty smoth
Disadventages:
Only speed probably but since inly simple functions are involved this
limitation is controled by complexity of CSG
Now I started to dream about
1) from desert to mountains landscape like in Walking With Dinosaurs
2) from seed to tree - with morphing of surface of bark
3) from youth to old age with morphing of wrinkles on the face
4) and so on
ABX
Date: 19 Mar 2002 08:32:35
Message: <h9fe9u0s1he7l8lgamkb45q29f6cdbr6l1@4ax.com>
Could it be possible to remove optional "(x,y,z)" from all functions
declaration ? This stops from direct inlining into isosurface.
ABX
