and my calculation returns the following values:
< -1.#IND000,-1.#IND000,-1.#IND000 >
can anyone help me make sense of this?
Bottom line, I just need to know how to test for these and give them a
skip when they occur.
Jim Charter wrote in message <3C7### [at] aol com>...
Without seeing the code you are using, I can't tell you for certain.
The -1.#IND means that a recent calculation had an undefined result. I'm
guessing you're dividing by zero somewhere. Do your calculations normalize
the vector?
Mark
> the vector?
> Mark
Thanks Mark, as it turns out it is not really a show stopper
I tested: #if ( Norm.x = -1 & Norm.y = -1 & Norm.z = -1 )
don't use Norm
crude, I know, but good enough in this case
AFAIK
-1 != -1.#IND
btw: I didn't found any place in 3.5 documentation where "#IND" is noted
and/or explained. It can confuse newbies.
ABX
In article <vo2s7uc355p2c5e52bea9uva2ibjbqcndt@4ax.com> , W„odzimierz ABX
Skiba <abx### [at] babilon org> wrote:
> AFAIK
> -1 != -1.#IND
It is an artifact of the C library used. Results may be different for
different C libraries and thus this cannot be noted in the documentation.
Further, checking for NANs and other invalid floating-point values was not
part of the C standard until C99, so many compilers don't support those recent
improvements yet. For this reason, it remains the users' responsibility to
only feed valid input into the various floating-point calculations in order to
get valid output...
Thorsten
e-mail: tho### [at] trf de
Thankyou again for the explanation. My SDL was not well-formed and the
bad input was most likely do to sloppy loop control. Since it happened
at the end of a loop, it was just as easy to drop the offending
calculation.
Thorsten Froehlich wrote:
> In article <vo2s7uc355p2c5e52bea9uva2ibjbqcndt@4ax.com> , W"odzimierz ABX
>>AFAIK
>>-1 != -1.#IND
> get valid output...
> Thorsten
