POV-Ray : Newsgroups : povray.general : Changing POV render priority... Server Time
23 Oct 2026 11:22:54 EDT (-0400)
  Changing POV render priority... (Message 1 to 4 of 4)
Subject: Changing POV render priority...
Date: 23 Feb 2002 18:32:43
Message: <3C78269C.3BF4ABAB@scifi-fantasy.com>
...doesn't seem to change my render speed significantly.  Whilst I
was rendering my animation, it took approx. 20 seconds per frame
on lowest, and approx. 20 second per frame on highest.  Why is
that?  I have a Pentium IV/1.8 GHz with 512 MB DDR RAM running
WinXP.
Tim Cook
Version: 3.12
Subject: Re: Changing POV render priority...
Date: 23 Feb 2002 18:56:42
Message: <3C782C41.EA09DF42@pacbell.net>
> WinXP.
You will only notice a difference if you are running other programs
while rendering. It is a multi-tasking switch which gives priority
to one program over another to use of the processor.
Ken Tyler
Date: 24 Feb 2002 03:26:27
Message: <3C78A3BE.75622D66@gmx.de>
In addition, a significant change is only noticeable with way
longer tracing times (around some minutes to my experience).
20 seconds isn't that much for raytracing, and half a second
more or less isn't obvious, as well as it doesn't make a huge
difference unless your tracing 100+ frames (100*.5s=50s)...
Tim Nikias
Date: 24 Feb 2002 23:52:27
Message: <3C79DE47.5D5EE478@joplin.com>
It maybe a windows 'thing'.
I did tests on priority with a file that took around 9 minutes and the highest
priority took the the same as the lowest.
Here is the result of three different files
lowest   41s  ---  3.26m  ---  9.26m
lower    41s  ---  3.26m  ---  9.17m
normal  40s  ---  3.26m  ---  9.26m
higher   42s  ---  3.25m  ---  9.19m
highest  41s  ---  3.24m  ---  9.26m
Have Fun!
