POV-Ray : Newsgroups : povray.general : How to get spline tangent Server Time
3 Nov 2026 10:27:15 EST (-0500)
  How to get spline tangent (Message 1 to 17 of 17)
Subject: How to get spline tangent
Date: 21 Feb 2002 05:04:57
Message: <3C74C67A.3010207@itam.cas.cz>
Hello,
   is it possible to get tangent of spline for my use in scene?
   (In MegaPOV (my perfered now, because I'am heavily using PVM),
   or POV 3.5)
Thanks
Disnel
Subject: Re: How to get spline tangent
Date: 21 Feb 2002 05:54:22
Message: <3C74D1D3.35DE926B@namtar.qub.ac.uk>
To get the tangent at some point A on your spline, get the value of the
spline at A and some other point B which is very close to A. The values
you get we call spline(A) & spline(B).
The vector T=spline(B)-spline(A) gives the direction at the point A if B
is very close to A on the spline (check vlength(T) to find out how close
they are)
Don't forget to translate your object to spline(A) after aligning it
along T, since T is only a direction.
signature{
Date: 21 Feb 2002 08:20:27
Message: <3C74F40E.47318ADA@namtar.qub.ac.uk>
Actually, since splines are nice and smooth (after all, that's what
they're there for!), if you make sure vlength(T) is very small (say
1e-10 for example), then this method should give you a very good
approximation to the tangent; easily good enough for any purpose I can
think of anyway.
Disnel wrote:
> Thanks, but this is not exact way. My ask was, if there is any hidden
> way how to get thi vector from POV ;-). But is must be sufficient..
> Regards
> Disnel
signature{
Date: 21 Feb 2002 09:35:23
Message: <3c7505ab@news.povray.org>
Grey Knight <s16### [at] namtarqubacuk> wrote:
: Actually, since splines are nice and smooth (after all, that's what
: they're there for!), if you make sure vlength(T) is very small (say
: 1e-10 for example), then this method should give you a very good
: approximation to the tangent; easily good enough for any purpose I can
: think of anyway.
  Beware of possible floating point inaccuracies with such small numbers.
Date: 21 Feb 2002 09:35:55
Message: <3c7505cb@news.povray.org>
Of course the more mathematically oriented people would like an exact
result instead of just an approximation... :)
Date: 21 Feb 2002 09:39:54
Message: <3c7506ba@news.povray.org>
:   Of course the more mathematically oriented people would like an exact
: result instead of just an approximation... :)
  By the way, I think that this gives a better approximation:
  Suppose that we want to calculate the tangent of the spline at the
time value T.
  Take a small value, which we will call Epsilon (could be for example
10e-5 or something similar).
  The approximated tangent will be:
  TangentVector = Spline(T+Epsilon)-Spline(T-Epsilon)
  This given a better approximation because the resulting vector will be
closer to the true tangent, and could even be exactly the tangent.
'Spline(T+Epsilon)-Spline(T)', however, can never be exactly the tangent.
Date: 21 Feb 2002 12:23:07
Message: <3C752D2A.9030503@itam.cas.cz>
Thank to all, you are right and I think, that it will be sufficient.
But I wanted to ask if there is some way to get exact tangent (another
than reimplementing POV spline in POV language, of course ;-) The answer
is probably not.
Regards
Disnel
Date: 21 Feb 2002 13:37:58
Message: <3C753E7B.A78CC2@namtar.qub.ac.uk>
I'm gonna reply to all your posts in one go, since you were carrying on
such a little conversation with yourself ;)
This is why your method is better (because the tangential vector is
longer :. less scope for FPI)
Well, the only limit on the accuracy is that imposed by the system
itself (specifically FPI as you pointed out), so a more accurate
solution would probably have no further benefit anyway?
Yeah, it does.
> time value T.
Which we do. ;P
> My constants.inc has EPSILON=1e-7, but of course it doesn't matter so long as it's
small.
Yeah, this method *is* better. I think the only reason I thought of the
other one was because the pure mathematical definition of the tangent
comes from that (with EPSILON -> 0), which makes the maths easier.
Of course, we can't use EPSILON=0 here, so obviously your method works
better.
signature{
Date: 21 Feb 2002 13:40:00
Message: <3C753EF5.5D86488B@namtar.qub.ac.uk>
But this method returns values about as close to the exact tangent as
you could probably get in a computer anyway, so FAPP it *is* exact.
signature{
Date: 21 Feb 2002 18:32:08
Message: <3C7582F0.903B5AB1@hotmail.com>
I guess you mean: For All Practical POV Purposes  ;)
Tor Olav
Date: 22 Feb 2002 05:01:02
Message: <3C7616D3.E8780A40@namtar.qub.ac.uk>
> Tor Olav
What other type of purpose is there? ;)
signature{
Date: 22 Feb 2002 05:08:12
Message: <gv5c7u0a3ai9m7sjsfrf8ks9p51o8qv0sn@4ax.com>
On Fri, 22 Feb 2002 10:00:51 +0000, Grey Knight <s16### [at] namtarqubacuk>
Of course Scientifical/Theoretical POV Purposes ;)
ABX
Date: 22 Feb 2002 15:25:58
Message: <3C76A953.114C3838@spiritone.com>
I tried this with my bezier curve include file. Of course you just need
to find the derivitave of the spline function, it should give you the
tangent direction. Of course this is a lot harder than it sounds. I've
wasted half a ream calculating the derivitave of a bezier function.
Josh English
eng### [at] spiritonecom
http://www.spiritone.com/~english
> is probably not.
> Regards
> Disnel
Date: 24 Feb 2002 14:18:29
Message: <3c793c85$1@news.povray.org>
POV is powerful enough for getting all the piecewise polynomial coefficients
from declared spline. For cubic spline we can calculate four points on every
time interval, get all four coefficients from this 4x4 linear system and
then get exact tangent function for every time interval. These coefficients
can be used outside POV.
Of course, this will be approximation too, because of limited accuracy. The
best way is just to find out these figures directly from original set of
points, but it seems that in this case we need to solve linear systems of
higher order, than 4(still possible with SDL, however).
"Disnel" <dis### [at] itamcascz> wrote in message
news:3C7### [at] itamcascz...
> is probably not.
Date: 24 Feb 2002 18:29:39
Message: <3C7976C9.AD9DA3D8@hotmail.com>
I have some (slow) POV macros that will solve
linear systems with N equations and N unknowns.
Tor Olav
Date: 25 Feb 2002 07:44:36
Message: <3c7a31b4@news.povray.org>
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:3C7976C9.AD9DA3D8@hotmail.com...
In this particular case speed is not so important,
because all calculations should be done only once for given spline.
Gleb
Date: 25 Feb 2002 19:52:27
Message: <3C7ADBB9.942767EE@hotmail.com>
Ok then -
If there's anyone that is working out these
tangent functions, just tell me if you want
me to post some of my matrix macros.
Tor Olav
