POV-Ray : Newsgroups : povray.general : How to get spline tangent Server Time
12 Jul 2025 22:22:26 EDT (-0400)
  How to get spline tangent (Message 1 to 10 of 17)
Subject: How to get spline tangent
Date: 21 Feb 2002 05:04:57
Message: <3C74C67A.3010207@itam.cas.cz>
Hello,
   is it possible to get tangent of spline for my use in scene?
   (In MegaPOV (my perfered now, because I'am heavily using PVM),
   or POV 3.5)
Thanks
Disnel
Subject: Re: How to get spline tangent
Date: 21 Feb 2002 05:54:22
Message: <3C74D1D3.35DE926B@namtar.qub.ac.uk>
To get the tangent at some point A on your spline, get the value of the
spline at A and some other point B which is very close to A. The values
you get we call spline(A) & spline(B).
The vector T=spline(B)-spline(A) gives the direction at the point A if B
is very close to A on the spline (check vlength(T) to find out how close
they are)
Don't forget to translate your object to spline(A) after aligning it
along T, since T is only a direction.
signature{
Date: 21 Feb 2002 08:20:27
Message: <3C74F40E.47318ADA@namtar.qub.ac.uk>
Actually, since splines are nice and smooth (after all, that's what
they're there for!), if you make sure vlength(T) is very small (say
1e-10 for example), then this method should give you a very good
approximation to the tangent; easily good enough for any purpose I can
think of anyway.
Disnel wrote:
> Thanks, but this is not exact way. My ask was, if there is any hidden
> way how to get thi vector from POV ;-). But is must be sufficient..
> Regards
> Disnel
signature{
Date: 21 Feb 2002 09:35:23
Message: <3c7505ab@news.povray.org>
Grey Knight <s16### [at] namtarqubacuk> wrote:
: Actually, since splines are nice and smooth (after all, that's what
: they're there for!), if you make sure vlength(T) is very small (say
: 1e-10 for example), then this method should give you a very good
: approximation to the tangent; easily good enough for any purpose I can
: think of anyway.
  Beware of possible floating point inaccuracies with such small numbers.
Date: 21 Feb 2002 09:35:55
Message: <3c7505cb@news.povray.org>
Of course the more mathematically oriented people would like an exact
result instead of just an approximation... :)
Date: 21 Feb 2002 09:39:54
Message: <3c7506ba@news.povray.org>
:   Of course the more mathematically oriented people would like an exact
: result instead of just an approximation... :)
  By the way, I think that this gives a better approximation:
  Suppose that we want to calculate the tangent of the spline at the
time value T.
  Take a small value, which we will call Epsilon (could be for example
10e-5 or something similar).
  The approximated tangent will be:
  TangentVector = Spline(T+Epsilon)-Spline(T-Epsilon)
  This given a better approximation because the resulting vector will be
closer to the true tangent, and could even be exactly the tangent.
'Spline(T+Epsilon)-Spline(T)', however, can never be exactly the tangent.
Date: 21 Feb 2002 12:23:07
Message: <3C752D2A.9030503@itam.cas.cz>
Thank to all, you are right and I think, that it will be sufficient.
But I wanted to ask if there is some way to get exact tangent (another
than reimplementing POV spline in POV language, of course ;-) The answer
is probably not.
Regards
Disnel
Date: 21 Feb 2002 13:37:58
Message: <3C753E7B.A78CC2@namtar.qub.ac.uk>
I'm gonna reply to all your posts in one go, since you were carrying on
such a little conversation with yourself ;)
This is why your method is better (because the tangential vector is
longer :. less scope for FPI)
Well, the only limit on the accuracy is that imposed by the system
itself (specifically FPI as you pointed out), so a more accurate
solution would probably have no further benefit anyway?
Yeah, it does.
> time value T.
Which we do. ;P
> My constants.inc has EPSILON=1e-7, but of course it doesn't matter so long as it's
small.
Yeah, this method *is* better. I think the only reason I thought of the
other one was because the pure mathematical definition of the tangent
comes from that (with EPSILON -> 0), which makes the maths easier.
Of course, we can't use EPSILON=0 here, so obviously your method works
better.
signature{
Date: 21 Feb 2002 13:40:00
Message: <3C753EF5.5D86488B@namtar.qub.ac.uk>
But this method returns values about as close to the exact tangent as
you could probably get in a computer anyway, so FAPP it *is* exact.
signature{
Date: 21 Feb 2002 18:32:08
Message: <3C7582F0.903B5AB1@hotmail.com>
I guess you mean: For All Practical POV Purposes  ;)
Tor Olav
