POV-Ray : Newsgroups : povray.general : Half-toning Server Time
23 Oct 2026 12:18:39 EDT (-0400)
  Half-toning (Message 1 to 15 of 15)
Subject: Half-toning
Date: 3 Feb 2002 01:03:59
Message: <3C5CD30B.981909BC@engineer.com>
First try at artistic half-toning. Interesting possibilites POV-Ray has.
http://lightning.prohosting.com/~lf/amidala.jpg
http://lightning.prohosting.com/~lf/amidala_hq.jpg
_____________
Kari Kivisalo
Subject: Re: Half-toning
Date: 3 Feb 2002 03:34:44
Message: <3c5cf624$1@news.povray.org>
Wow. I'm impressed. Explain how you did that.
Does using POV scripts give you more possibilities than Photoshop?
It would be great to see this applied to a POV picture: one could come up with a true
piece of Art from within POV.
Jonathan.
> _____________
> Kari Kivisalo
Date: 3 Feb 2002 04:28:03
Message: <vg0q5uo5g54e5jhohj8ern19c1lctu867a@4ax.com>
  How did you accomplish this?
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
Date: 3 Feb 2002 04:59:47
Message: <Xns91AA70210BA2Eseed7@povray.org>
Very interesting!
Ingo
Date: 3 Feb 2002 10:15:35
Message: <3C5D5450.CFC594A6@engineer.com>
The easy part was to sample the image and put a pen stroke (cylinder)
at that location modifying length and width with the sample intensity.
The interesting part is how to orient the pen strokes. I used blurred
image as hf and with trace found the direction of the contour line at
that point. Add some randomness to position and rotation  and place
brush. I used a cylinder because transparent png had some problems.
There can be several brushes with alpha channel. Several colors...
http://www.pp.htv.fi/kkivisal/ht/
More interesting stuff can be done if the range data is available
for the image like in pov. First render a scene as normal image.
Then output depth image, blur it and use as hf. The brush strokes
should follow the surfaces or something like that.
_____________
Kari Kivisalo
Date: 3 Feb 2002 10:35:45
Message: <3c5d58d1@news.povray.org>
> I used blurred image as hf and with trace found the
> direction of the contour line at that point.
I *knew* a heightfield was involved! ;)
How many cylinders in the scene? Render time? AA settings? And were all the
cylinders black or did they very in color dependent on intensity?
BTW, I'd be interested in seeing the result if you rotated all the cylinders
by 90 degrees. Would make for a less harmonic and more spiky image I'm sure.
45 degrees might also be interesting. :)
> is available for the image like in pov. First render
> a scene as normal image. Then output depth image,
> blur it and use as hf. The brush strokes should follow
I don't think that would be as visually interesting. The great thing about
the current image is that it looks very hand-crafted, like it wasn't made by
a computer. Something difficult to obtain.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
Date: 3 Feb 2002 11:24:00
Message: <3C5D645B.53231290@engineer.com>
> And were all the
300x300 sample grid makes it 90000 cylinders. All black. Maybe 2 minutes
+am2 +a0.5.
_____________
Kari Kivisalo
Date: 3 Feb 2002 11:41:26
Message: <3c5d6836@news.povray.org>
> All black. Maybe 2 minutes +am2 +a0.5.
Sounds great!
(But a render time should always be followed with a processor specification.
> > rotated all the cylinders by 90 degrees. Would make
Thanks! the 90-degree one is just like I imagined, the 45 degree one not as
interesting. But the best one is still your original one. I definitely must
play around with this sometime...
Rune
Date: 3 Feb 2002 14:31:25
Message: <3c5d900d$1@news.povray.org>
"Kari Kivisalo" <ray### [at] engineercom> wrote in message
news:3C5D5450.CFC594A6@engineer.com...
> that point.
Excuse my ignorance, but what is a contour line on a height-field? Are you
referring to the normal at that point, or some other characteristic with
which I am unaware?
 -Shay
Date: 3 Feb 2002 14:33:44
Message: <3c5d9098$1@news.povray.org>
Replying to myself.
I bet youre talking about a line perpendicular to the surface normal and +y.
Am I right?
"Shay" <shi### [at] houstonrrcom> wrote in message
news:3c5d900d$1@news.povray.org...
> > that point.
> which I am unaware?
>  -Shay
Date: 3 Feb 2002 14:49:23
Message: <3C5D9480.75EB0FBD@engineer.com>
Same as elevation lines in topographic map.
_____________
Kari Kivisalo
Date: 4 Feb 2002 19:53:45
Message: <3C5F2D1A.DADFD9B4@scifi-fantasy.com>
> POV-Ray has.
Phagh, ANYBODY slaps a filter over an image on computer
and calls themselve le artiste...REAL half-tone art, be
it pen/ink or zipotone, is done by hand!
Tim Cook
http://personal.lig.bellsouth.net/lig/z/9/z993126
Version: 3.12
Date: 5 Feb 2002 05:27:36
Message: <3c5fb398@news.povray.org>
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3C5F2D1A.DADFD9B4@scifi-fantasy.com...
Yes, but can anyone write a half-toner in POV? (or did you miss that part?)
Date: 5 Feb 2002 05:52:03
Message: <q7ev5ucahc1roo91at08c9cr4007oggv6o@4ax.com>
On Tue, 5 Feb 2002 10:27:35 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
http://news.povray.org/slrna07gqe.mu2.ron.parker%40fwi.com
ABX
Date: 5 Feb 2002 08:24:08
Message: <slrna5vn7p.349.ron.parker@fwi.com>
Ah, but he's not just anyone.  He's weird.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
