POV-Ray : Newsgroups : povray.general : animation question Server Time
29 Oct 2026 03:46:14 EDT (-0400)
  animation question (Message 1 to 9 of 9)
Subject: animation question
Date: 18 Jan 2002 18:22:53
Message: <3C48AE4C.DE9AADC2@scripps.edu>
I have a newbie question regarding animations.  I have a POV scene which
contains a complex model (actually a 3D protein structure).  I would
like to make an animation which rotates the entire molecule around in a
defined way.
What is the best way to do this? I have considered rotating the camera
around the object but then the lighting gets messed up in certain
places.  Second, it is not easy to describe the motion around the object
in 3D.
Is there a way to rotate the entire object as one?  The protein model is
composed of many tubes, spheres and triangles.  How do I refer to the
whole thing as one object?
Any suggestions would be appreciated.
Mike
Michael DiDonato, PhD
The Scripps Research Institute
Department of Molecular Biology
Maildrop MB4
10550 North Torrey Pines Road
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
http://www.scripps.edu/~didonato
Download 'us-ascii' (2 KB)
Subject: Re: animation question
Date: 18 Jan 2002 18:38:44
Message: <3C48B27F.C6728D6B@helix.nih.gov>
> which contains a complex model (actually a 3D protein structure).  I
> would like to make an animation which rotates the entire molecule
> around in a defined way.
> object in 3D.
> is composed of many tubes, spheres and triangles.  How do I refer to
> the whole thing as one object?
> Mike
> Maildrop MB4
> La Jolla, CA, 92037
> Tel: (858) 784-9261
> FAX: (858) 784-2277
Not sure how your scene is  structured but one thing that comes to mind
would be to put all your objects into a union like
union {
   sphere ...
   triangle ...
    //  up to here are your objects
   rotate  clock * y
Read the part about animation in the manual of povray. There is a clock
variable that can be set and if you use povray's animation feature this
variable is increased
with each new frame.
Of course one could mention that there are macromolecular graphics
programs that support animation with povray in one form or other.
Hope this helps.
 Lothar.
Dr. Lothar Esser
NIH / NCI
Tel. 301-435-6163
email les### [at] helixnihgov
Date: 18 Jan 2002 19:14:50
Message: <3C48BA7A.B612C665@scripps.edu>
> union {
>    sphere ...
>    triangle ...
>    rotate  clock * y
> Hope this helps.
>  Lothar.
> Dr. Lothar Esser
> NIH / NCI
> Tel. 301-435-6163
Do you know of any?
Maildrop MB4
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
Date: 18 Jan 2002 22:19:11
Message: <3C48E5F4.1A518291@pacbell.net>
> > Hope this helps.
> Do you know of any?
http://www.ks.uiuc.edu/Research/vmd/
Ken Tyler
Date: 19 Jan 2002 06:02:01
Message: <3c495229$1@news.povray.org>
Put all the objects into a union, then all the following lines to your
QUICKRES.INI file:
[x frames, y by z]
Width=y
Height=z
Initial_Frame=1
Final_Frame=x   ;set x to the number of frames
Cyclic_Animation=on   ;so that the last frame isn't identical to the first
Then add this line to the union:
rotate <0,clock,0>  // move clock into the desired axis
Hope this helps.
__________________
Chris Howie
cra### [at] yahoocom
http://winimizer.virtualave.net
Date: 19 Jan 2002 06:59:17
Message: <3C495FC2.470A0742@sw-tech.com>
That's the second time I've seen that particular rotate used in this
thread.  Well, the first one was "rotate clock * y".  In neither case was
there a Start_ or End_Clock mentioned.
Am I a complete idiot for using "rotate <0, 360*clock, 0>", or did two
people make the same mistake?  Both of these options?  Neither?
Deaken (who has set followups, since this is not a unix question)
Date: 19 Jan 2002 12:00:35
Message: <3C49A6AF.4F4C8B8C@helix.nih.gov>
>> Hope this helps.
> Do you know of any?
VMD, Ribbons, Dino, pyMol and well glr ( shameless promotion of my
program :)
L.
Date: 19 Jan 2002 12:15:11
Message: <3C49AA1C.FE8A1D4@helix.nih.gov>
rotate clock * y is an alternative to rotate <0,clock,0> as y = <0,1,0> .
Yes and you are right that I did not mention start and end. I don't have the
exact commandline syntax or the stuff that you put in the .ini file in my
head right now which is why I said look it up in the manual. Of course if
you plan to have say n images with the first and last being identical one
should  use something like this
rotate clock * 360  / n * y   //  where clock goes from 0 to n. Unless I am
mistaken the user can assign any real value to clock and it will go from
start to end; so you can use integral values that match the frame number or
fractions from 0 to 1.  Talking so much about it I looked it up : the
command line switch is +k and in the .ini
file it would be clock=### where ### is a start value.  Look at povray 3.1
documentation like  pov115.htm#_Toc449951170.
L.
Date: 19 Jan 2002 12:27:24
Message: <chrishuff-143206.12281619012002@netplex.aussie.org>
In article <3C495FC2.470A0742@sw-tech.com>, Deaken <dwy### [at] sw-techcom>
That is actually probably the best way to do it...if you write all your
scenes to work with the default [0, 1] range, you will have an easier
time moving code between them. It could also get harder to control when
you modify the clock range.
It's probably a matter of personal prefrence, though making the clock
run from 0 to 360 just for a rotation seems like a bad idea...what if
you then want to add translation by 1 unit over the course of the
animation?
Date: 19 Jan 2002 13:48:04
Message: <3c49bf64$1@news.povray.org>
    No, yes, no, no.
Date: 19 Jan 2002 19:50:42
Message: <3c4a1462$1@news.povray.org>
"Deaken" <dwy### [at] sw-techcom> wrote in message
news:3C495FC2.470A0742@sw-tech.com...
If you're asking whether or not clock by itself will rotate 360 degrees,
then no.  Not necessarily anyway, unless you specify a Intitial_Clock=1 and
Final_Clock=360 for INI file.
If you asked if rotate clock * y is same as <0,clock,0> then the answer is
yes.  Or in your example, rotate 360*clock*y.
bob h
Date: 19 Jan 2002 20:12:21
Message: <3C4A19A2.115686BF@sw-tech.com>
Right.  I'm sorry, I was unclear in my question.  My point was not that the
individual x/y/z names are shorthands for the vectors, it was that some
people multiply by the clock, whereas I multiply by (the clock times 360).
In fact, I had originally written "y*360*clock", but changed it for the sake
of clarity.
The general form of what I use.  I am not good enough to generalize the
method and use clocks that are not simply 0-1.
Deaken
Date: 19 Jan 2002 20:16:39
Message: <3C4A1AA4.2AB969B9@sw-tech.com>
Actually, I was asking if my belief (that this was incorrect) was correct.
I think that means the same thing as what you said...
Deaken
Date: 20 Jan 2002 14:16:53
Message: <3c4b17a5@news.povray.org>
No, you're right.  It escaped me again.  360*clock IS correct.
Sorry about the error.
__________________
Chris Howie
Date: 20 Jan 2002 23:10:40
Message: <3C4B94F2.54415E25@sw-tech.com>
Oh, no need to apologize.  Being a rank amateur, I wanted to make sure that
I wasn't  doing something that merely LOOKED like it was working, or
overworking the problem (a major fault of mine), or something along those
lines.
Deaken
Date: 3 Mar 2002 23:21:47
Message: <3c82f65b@news.povray.org>
Try this:
http://www.mol.biol.ethz.ch/wuthrich/software/molmol/
d.
  "Michael DiDonato" <did### [at] scrippsedu> wrote in message
news:3C48BA7A.B612C665@scripps.edu...
mind
    union {
       sphere ...
       triangle ...
       rotate  clock * y
clock
this
    Hope this helps.
     Lothar.
    Dr. Lothar Esser
    NIH / NCI
    Tel. 301-435-6163
  Do you know of any?
Maildrop MB4
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
Download 'iso-8859-1' (3 KB)
Date: 20 Jan 2002 14:19:21
Message: <3c4b1839@news.povray.org>
(Sorry about the multiple-postings... didn't realize he sent it to multiple
groups.)
__________________
Chris Howie
