POV-Ray : Newsgroups : povray.general : Radiosity champions, here's something for you ! Server Time
11 May 2026 23:29:41 EDT (-0400)
  Radiosity champions, here's something for you ! (Message 1 to 10 of 74)
Subject: Radiosity champions, here's something for you !
Date: 12 Dec 2001 13:46:10
Message: <3C17948E.828FFFDE@skynet.be>
Look here :
 http://www.cgtechniques.com/~sibenik/
That guy is setting a GI-engine competition, giving some Roman church
model to render.  POV-Ray is on his list, but nobody has yet
submitted something.  I think that POV-Ray highly deserves its place
in the "contest", so, if some radiosity expert with some time on
his hands (not my case) listens...
Fabien.
Subject: Re: Radiosity champions, here's something for you !
Date: 12 Dec 2001 14:01:36
Message: <slrna1faci.8ft.ron.parker@fwi.com>
I notice that many of the entries are "freestyle."  That seems just
wrong to me.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 13 Dec 2001 05:37:20
Message: <3c1884e0@news.povray.org>
Why don't you give it a try?
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
> wrong to me.
a-z)R(a
T)merge{
3-T}}}#end
Date: 13 Dec 2001 05:39:02
Message: <3c188546@news.povray.org>
I made an entry. Nothing really fancy, just a quick render.
Date: 13 Dec 2001 07:40:52
Message: <slrna1h8el.b94.ron.parker@fwi.com>
Because I write better C code than POV code, mostly.
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 13 Dec 2001 08:54:45
Message: <3c18b325$1@news.povray.org>
Some important contrast and brightness adjustements could gretly enhance
the image.  Keep in mind that all these so-called "high-end" softwares
have some built-in "exposure" taken into account.
I opened the file in 3DS Viz we have here, but couldn't find a light
source !  Maybe you could guess it by looking at other pictures.
Did you use a sky sphere ?
Fabien.
Date: 13 Dec 2001 09:07:11
Message: <3c18b60e@news.povray.org>
fabien <fab### [at] skynetbe> wrote:
: Some important contrast and brightness adjustements could gretly enhance
: the image.
  Please tell me how to enhance contrast in the image. I tried. I failed.
: I opened the file in 3DS Viz we have here, but couldn't find a light
: source !  Maybe you could guess it by looking at other pictures.
  The direction of the light source is well defined in the rules page.
: Did you use a sky sphere ?
background { rgb 1 }
Date: 13 Dec 2001 09:41:57
Message: <3C18BE35.D0069D77@gmx.de>
Most important would be to decrease 'error_bound' in the radiosity
settings, of course you will have to raise 'count' to avoid artefacts and
everything will get much slower.  Another thing that might help is to
reduce recursion_limit to 2, this can lead to better contrasts too.
As a side note, i think this kind of scene is not particularly well suited
for POV-Ray, With procedural textures and CSG instead of meshes the
appearance could be much improved and would suffer less at higher
resolutions (in some of the other renders the mesh facets are really
strongly visible).
How did you convert it BTW?
Date: 13 Dec 2001 11:28:25
Message: <3c18d729@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
: Most important would be to decrease 'error_bound' in the radiosity
: settings, of course you will have to raise 'count' to avoid artefacts and
: everything will get much slower.  Another thing that might help is to
: reduce recursion_limit to 2, this can lead to better contrasts too.
  Reducing the recursion_limit hit the spot (although I realized that before
reading your suggestion). The render time also reduced from 1.5h to 1h.
  I made a second entry which looks much better.
: As a side note, i think this kind of scene is not particularly well suited
: for POV-Ray, With procedural textures and CSG instead of meshes the
: appearance could be much improved and would suffer less at higher
: resolutions (in some of the other renders the mesh facets are really
: strongly visible).
  Well, speedwise I think that meshes and imagemaps are quite ok. If that
same scene would have made with primitives and procedural textures, the render
time could perfectly be several hours...
: How did you convert it BTW?
  3DWin4 did a damn good job at converting the 3ds file given in the page
to mesh2's (with the original uv-information, of course; without that it would
have been impossible to render the scene).
  As the 3ds file didn't have the actual imagemaps, I had to search and
set the proper images in proper places, but that wasn't too difficult.
Date: 13 Dec 2001 11:32:44
Message: <3c18d82c@news.povray.org>
By the way, if anyone is interested in the scene, I can put it somewhere
to download.
