POV-Ray : Newsgroups : povray.general : What abilites should a particle system have? Server Time
4 Nov 2026 17:32:17 EST (-0500)
  What abilites should a particle system have? (Message 1 to 16 of 16)
Subject: What abilites should a particle system have?
Date: 2 Dec 2001 20:55:25
Message: <3C0ADB1F.66DD2EB7@gmx.de>
Hi there!
Well, I am programming a particle system for POV-Ray and have designed
in a fashion which makes
almost anything customizable (when I'm speaking of design, I mean
algorithms, it's text-based, like POV).
Now, what I was wondering:
What exactly should a particle system be able to handle? Not only do I
want to see if I can cover the
demands by checking if the macros can supply the needed basis for people
to program the algorithms using
the macros, but also, I think it would be great if one could have sort
of a check-list to see, what one should
think about to create an awesome particle system.
Hope you get the idea...
Well, I'll begin with something simple:
Particle-Systems should definitely have some sort of Emitter, e.g.
definable areas, in which the particles are born.
Subject: Re: What abilites should a particle system have?
Date: 2 Dec 2001 21:01:40
Message: <3c0add04@news.povray.org>
Love to see some of this work. Happy to beta test if needed! Have a look at
the features of Illusion from Coolfun:
http://www.coolfun.com/illusion/index.htm
You can download the manual and see all the parameters they offer.
D..
"Tim Nikias" <Tim### [at] gmxde> wrote in message
news:3C0ADB1F.66DD2EB7@gmx.de...
> Hi there!
Date: 2 Dec 2001 21:44:56
Message: <3C0AE6BA.DB2D31E1@gmx.de>
Yeah, well, that's something someone already wrote. Your reply is of value, of
course, but my intent was to have the community speak up and tell, what
sort of effects they can come up with and what they'd expect and like to have.
Nontheless, I'm downloading right now... ;)
So, another idea would be force-fields, which affect particles found within
them, like swirling them around (to create twisters or such) or just slowing
them down.
Date: 3 Dec 2001 00:51:40
Message: <3c0b12ec$1@news.povray.org>
Similarly, a defined area in which particles die, but it should be optional.
It should also support collision detection with objects and between
particles, and/or the ability for particles to repel or pull each other as a
function of their distance.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 3 Dec 2001 15:30:27
Message: <3c0be0e3$1@news.povray.org>
I'd really like to see the ability to "particalize" a preexisting bitmap.
Hope you can consider that as an option.
D.
"Slime" <noo### [at] hotmailcom> wrote in message
news:3c0b12ec$1@news.povray.org...
optional.
a
> - Slime
Date: 3 Dec 2001 18:38:22
Message: <3c0c0cee@news.povray.org>
Destroyer : particles are removed on contact
environmental modifiers. things like gravity and wind
object modifiers. attractor and repulse scene objects (could replace
gravity)
intersection & collision - particle to particle, and particle to object
PGP Public Key
Date: 4 Dec 2001 07:46:22
Message: <3c0cc403.276451@news.povray.org>
On Mon, 03 Dec 2001 02:53:35 +0100, Tim Nikias <Tim### [at] gmxde>
wrote:
>Hi there!
Mhm, here's a good feature list:
Emitters:
 spherical, cone and object emitter (object emitter=particles are on
the surface of and object and have initial speed=normal*factor)
 controls for: initial speed, accelleration, position, speed
randomness, accell rondomness, position randomness, die age, die age
randomness, initial color, initial color randomness, particle die mode
(hit-die,age-die,speed-die).
Particles:
 hit detection-rebound, color control: speed based, age based,
accelleration based (mhm there should be a speed, age etc variable for
every particle, and then I should be able to attach those variables to
color channels or to any other value... like phong highlight etc...)
 ability to attach a generic object to every particle (blob, sphere,
light, point etc) with or without orientation (mhm you can calc object
oriet. by using particle speed vector or by adding a normal vector to
particles... this would allow spinning objects)
 point and line particles
Forces:
 normal (linear), vortex, bend, attractor
Date: 4 Dec 2001 08:31:15
Message: <3c0cd023$1@news.povray.org>
> Particles:
> light, point etc)
make that ability to attach any pov object to a particle, quick and dirty
collisions etc could be done using an objects bounding box
PGP Public Key
Date: 4 Dec 2001 08:37:01
Message: <3c0cd183.3732987@news.povray.org>
On Tue, 4 Dec 2001 13:29:49 -0000, "Rick [Kitty5]" <ric### [at] kitty5com>
wrote:
>> Particles:
>> light, point etc)
Mhm, I think it's really important to have accurate collisions with
meshes... I think that this can not be done with boundingboxes... For
collisions I think that you can assume that particles are spheres (or
points if It's too slow to do spheres), not check object->mesh
collision as this would be really impossible
>Rick
>Kitty5 WebDesign - http://Kitty5.com
>POV-Ray News & Resources - http://Povray.co.uk
>TEL : +44 (01270) 501101 - FAX : +44 (01270) 251105 - ICQ : 15776037
>PGP Public Key
>http://pgpkeys.mit.edu:11371/pks/lookup?op=get&search=0x231E1CEA
Date: 5 Dec 2001 07:11:07
Message: <3c0e0edb$1@news.povray.org>
> >> light, point etc)
then have 2 options - accurate + quick and dirty
PGP Public Key
Date: 5 Dec 2001 19:10:17
Message: <3C0EB6FF.27BC77C5@gmx.de>
I really enjoy reading this. Hope others will continue, since I intend to
write down and sort the list and place it on my website (which is currently
under construction).
I also like people commenting on how things are possible, since mostly, more
people come to better conclusions, since there's a broader perspektive.
Tim
Date: 6 Dec 2001 07:25:15
Message: <3c0f63ab$1@news.povray.org>
currently
more
its just important that we don't strive to be too different
when something has been implemented perfectly in another application, lets
not re invent the wheel
PGP Public Key
Date: 6 Dec 2001 10:21:16
Message: <3c0f8cec@news.povray.org>
What do you mean by acceleration?
I don't think that's very generic. Instead I'd assign a random number to
each particle. This, combined with the age, speed, etc. can be used by the
user for anything, for example to give the particle a specific color.
> Particles:
> age based, accelleration based (mhm there should be
> a speed, age etc variable for every particle, and
> highlight etc...)
Exactly.
The user can simply be given the location, speed, age, etc., and then take
care of creating the particles from that. That's much more generic than
implementing specialized support for blobs, spheres, light_sources etc.
What do you mean by line particles? If you simply mean particles that are
longer in one direction, then see above.
>  normal (linear)
= Gravity?
Please explain these in more detail or point me to relevant references.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 7 Dec 2001 14:02:44
Message: <3c111254@news.povray.org>
I'd like the ability (as posted in 'square particles' ) to have something
like 'bricks' in a particle system, that would fall and tumble.
More definitive, the ability to attach meshes to each particle, and have
rotation part of the collision process.  Collisions should be chooseable
1) Simple (bounding sphere), no rotation
2) Medium - Bounding box, x/y/z rotations from bbox collision (bbox orients
as the object falls / twists)
3) Complex (mesh collision), without deformations - collisions would be
chooseable from inelastic to elastic
4) Have collision (elastic/inelastic) modifiable acording to some function;
possibly modifying the object as well.
4) would be hard, but the visual effect would be a large object falling, and
they 'crushing'
                  == John ==
> Hi there!
Date: 7 Dec 2001 14:49:45
Message: <3C111D51.12F278E3@scifi-fantasy.com>
While you're at it, why not make a more generic physical simulation
engine that lets you define density properties to objects, gravity
constant, etc., so that you can do simple particle systems AND
collision detection among other object AND objects being blown up
or being run into by other objects...?
I know they have these things already, able to be leased for however
many thousand dollars a month, but a simplified version would be fun.
You might need a modeller for it...or not, what with the enjoyment
y'all get from the idea of building entire scenes with isosurfaces
hehee
Tim Cook
Version: 3.12
Date: 7 Dec 2001 21:42:38
Message: <3c117e1e$1@news.povray.org>
That's true, with the features I listed you're pretty close.  You'd really
need density and gravity anyway for a good particle system.
Maybe we should startup a sourceforge version ...
                  == John ==
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3C111D51.12F278E3@scifi-fantasy.com...
> hehee
> Tim Cook
> http://empyrean.scifi-fantasy.com
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
