POV-Ray : Newsgroups : povray.general : Lens Flares? Server Time
3 Nov 2026 17:31:27 EST (-0500)
  Lens Flares? (Message 1 to 35 of 35)
Subject: Lens Flares?
Date: 6 Nov 2001 18:45:27
Message: <3BE87585.572DA5DB@scifi-fantasy.com>
Something to toy with using photons, perhaps?
The task: cause a lens flare in a rendering without using a plug-in,
and without using objects to simulate the parts of the flare.
Possibly involves building a lens to put in front of the camera...
Tim Cook
Version: 3.12
Subject: Re: Lens Flares?
Date: 6 Nov 2001 19:30:50
Message: <3be880ba$1@news.povray.org>
Heh heh. Of course, then you'd have to give the lens internal reflection,
and make sure it didn't distort the camera's view... I think you're better
off just using NKFlare.
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3BE87585.572DA5DB@scifi-fantasy.com...
> Tim Cook
> http://empyrean.scifi-fantasy.com
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
Message: <3be880ba$2@news.povray.org>
You found me out!  A while back I started to try to do this (one of many
projects simmering on the back burner for me).  After a week of searching I
finally found some values for a 35mm camera lens system and started working
on it.  Last week I was playing a bit more with it and finally got the
beginnings of successful 'real' lens flares.  Mind you it is quite a render,
with 5 lenses (10 refracting/reflecting surfaces) you have to set the max
trace level quite high to get anything workable with all those reflections
and refractions (During the latest runs at it I was up to 5000 for
max_trace_level).  More on that in the future when I get more time to play
with it.
-tgq
> Tim Cook
> Version: 3.12
Date: 6 Nov 2001 21:03:00
Message: <3BE89675.20409E7F@pacbell.net>
I seem to recall that Dan Farmer was playing around with this idea like
5-6 years ago :)
Ken Tyler
Date: 7 Nov 2001 01:17:53
Message: <3be8d211@news.povray.org>
Strange, I was thinking of the same thing last week...
- Nekar
"Trevor Quayle" <Tin### [at] hotmailcom> wrote in message
news:3be880ba$2@news.povray.org...
> with it.
> -tgq
> > Tim Cook
> > Version: 3.12
Version: 6.0.286 / Virus Database: 152 - Release Date: 2001/10/09
Date: 7 Nov 2001 02:43:04
Message: <s9phut41huutiblodjutj1auug9alh07sl@4ax.com>
>5-6 years ago :)
Nah, it can't be done without photons so it can't be that long ago.
However, I think Ron made something like that.
Of course, to simulate the flare perfectly, one needs to introduce
diffraction and interference. *sigh*
Peter Popov ICQ : 15002700
Date: 7 Nov 2001 03:46:36
Message: <3be8f4ec@news.povray.org>
"Peter Popov" <pet### [at] vipbg> wrote in message
news:s9phut41huutiblodjutj1auug9alh07sl@4ax.com...
Something to add to Pov-Ray 4 wishlist!
- Nekar
Date: 7 Nov 2001 06:37:14
Message: <3be91cea@news.povray.org>
Timothy R. Cook <tim### [at] scifi-fantasycom> wrote:
: The task: cause a lens flare in a rendering without using a plug-in,
: and without using objects to simulate the parts of the flare.
  Why? (Except for just the sake of achieving it, even it's extremely slow
and not very useful.)
  It's like making a raytracer with the SDL of POV-Ray. It's slow and not
very useful. It may be fun, but not useful.
  With the include files you get good-looking lensflares of all shapes and
colors easily and it's really fast to render. Not everything has to be
physically correct to look really good.
Date: 7 Nov 2001 06:47:54
Message: <fm7iutcmne52j18edut85r22snvl4ogo5m@4ax.com>
I don't remember content of lens flare include file but does it work correct
with radiosity ?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 7 Nov 2001 08:15:58
Message: <slrn9uid0f.gff.ron.parker@fwi.com>
>>5-6 years ago :)
Not that I remember.
But it really doesn't require photons, so it's possible Dan was playing
with it that long ago.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 7 Nov 2001 09:17:17
Message: <3BE9428F.BAE0967E@pacbell.net>
> >>5-6 years ago :)
Not just possible, it happened. I have personally rendered the file
he created.
Ken Tyler
Date: 7 Nov 2001 09:32:11
Message: <j0hiutonj70dak3rv8ffd2u8eh3pg7va3q@4ax.com>
On Tue, 6 Nov 2001 19:32:27 -0500, "Mahalis" <don### [at] fakeycom> wrote:
> //Mahalis
> camera{....
it is not connected with the thread but I observe your signature and I wait for
Warp's reaction to your wasted space. But there is no reaction. So, allow me to
reduce your signature a little :-)
#macro c()union{cylinder{x+y/2x.1}difference{torus{.5,.1rotate 90*x}box{x+z/5
,-.2-(x+y)/2}translate(1-z)/2}#end merge{c()}c()scale<-1,1,1>}cylinder{y/2,0,
.1}pigment{crackle scale.5rotate 90turbulence.75color_map{[.05rgb 1][.1rgb<1,
.25,1>][.25rgbf 1]}}finish{ambient 1}}camera{location-2*z+y/4look_at y/2}
that's probably not everything I can do but perhaps now Warp could start :-)
ABX
Date: 7 Nov 2001 10:22:09
Message: <3be951a1@news.povray.org>
Włodzimierz ABX Skiba <abx### [at] babilonorg> wrote:
: #macro c()union{cylinder{x+y/2x.1}difference{torus{.5,.1rotate 90*x}box{x+z/5
: ,-.2-(x+y)/2}translate(1-z)/2}#end merge{c()}c()scale<-1,1,1>}cylinder{y/2,0,
: .1}pigment{crackle scale.5rotate 90turbulence.75color_map{[.05rgb 1][.1rgb<1,
: .25,1>][.25rgbf 1]}}finish{ambient 1}}camera{location-2*z+y/4look_at y/2}
  Well, I think I can beat that:
#macro c(X)torus{.5.1clipped_by{box{<.7.2><-.7,-.2.7>}}rotate-90*x translate
x*X}#end #macro C(A)cylinder{A,A-y*.5.1}#end merge{c(.5)c(-.5)C(x)C(-x)C(0)
translate z*2pigment{crackle scale.5rotate 90turbulence.75color_map{[.05rgb
1][.1rgb<1,.25,1>][.25rgbf 1]}}finish{ambient 1}}
  Ok, the texture is not identical to the original, but I don't think it
matters that much.
Date: 7 Nov 2001 10:38:44
Message: <3BE955A6.4C3ED542@pacbell.net>
Everybody around here whines about how important it is to use proper
indenting yet look at that mess! When I do it people critisie me. When
you guys do it in your sigs it is all of a sudden ok. Talk about double
standards!
Ken Tyler :)
Date: 7 Nov 2001 11:11:51
Message: <slrn9uina8.gj7.ron.parker@fwi.com>
#macro c(X)torus{.5.1clipped_by{plane{z,0}}rotate x*90translate x*X}#end#macro C
(A)cylinder{A,A-y*.5.1}#end merge{c(.5)c(-.5)C(x)C(-x)C(0)translate z*2pigment{
crackle scale.5turbulence.75rotate 90color_map{[.05rgb 1][.1rgb 1-.75*y][.25rgbf
and depending on just how unimportant the exact texture is, the rotate 90 could
be changed to rotate 9 or removed altogether (and the translate z*2 could be
moved to the end, which would also change the texture.)
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 7 Nov 2001 11:24:36
Message: <3be96044$1@news.povray.org>
See the post in p.b.i
-tgq
Date: 7 Nov 2001 11:34:11
Message: <3be96283$1@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3BE955A6.4C3ED542@pacbell.net...
translate
> standards!
    I agree.
//// New, improved and FAIR code follows ////
 #macro c (X)
    torus {
           0.5, 0.1
              clipped_by {
                          box {
                               <  0.7, 0.2 >,
                               < -0.7,-0.2, 0.7 >
              rotate-90*x
              translate x*X
 #macro C (A)
    cylinder{
             A, A-y*0.5, 0.1
 merge{
       c(0.5)
       c(-0.5)
       C(x)
       C(-x)
       C(0)
       translate z*2
       pigment{
               crackle
               scale 0.5
               rotate 90
               turbulence 0.75
               color_map {
                          [ 0.05 rgb 1 ]
                          [ 0.10 rgb < 1.0, 0.25, 1.0 > ]
                          [ 0.25 rgbf 1 ]
              finish {
                      ambient 1
Date: 7 Nov 2001 11:35:01
Message: <igoiutsfrfcorap2sal2eklrg66r8urg2j@4ax.com>
> standards!
Perhaps your scripts should create more signaturing results. For example try
this:
#warning#macro P(S)#local T=val(substr(S,1,7));#local B=substr(S,8,strlen(S)-7)
#local O=M(T)#if(strlen(B)>0)#local O=concat(O,P(B))#end O#end#macro M(V)#local
S=chr(mod(V,123))#local F=div(V,123);#if(F>0)#local S=concat(S,M(F));#end S#end
P("167668818409731737237048969510822381537545154019204883010625882")
ABX :-)
Date: 7 Nov 2001 12:15:42
Message: <3BE96B97.595EEF1C@scifi-fantasy.com>
> > plug-in, and without using objects to simulate the parts of
> > the flare.
>   Why?
Same reason you (might) render Schroedinger's cat even though
the box is closed: more complete simulation of reality! ;)
Tim Cook
Version: 3.12
Date: 7 Nov 2001 12:24:02
Message: <3be96e32$1@news.povray.org>
news:3BE96B97.595EEF1C@scifi-fantasy.com...
> > > the flare.
> >   Why?
It is my goal in life to create a simulation of reality that is
indistinguishable from reality, we can insert the simulated reality and
noone would be the wiser because it would be *exactly* the same... or
perhaps I already have ;)
-tgq
Date: 7 Nov 2001 16:01:23
Message: <3be9a123@news.povray.org>
In article <3be91cea@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Hmm, so as you like to write fun but useless things, maybe change POV-Ray to
allow the "real" lense flare? ;-)
    Thorsten
e-mail: tho### [at] trfde
Date: 7 Nov 2001 16:24:44
Message: <ug9jut46oculuevnsu5fu89gl7inam8bv0@4ax.com>
On 7 Nov 2001 08:15:58 -0500, Ron Parker <ron### [at] povrayorg>
OK, I'll have to check who it was, then.
How so? Lens flares usually originate from light sources.
Date: 7 Nov 2001 16:38:38
Message: <slrn9ujaf0.hkl.ron.parker@fwi.com>
True, but since the path is ES*L, it is sufficient to give the light source a
looks_like that has sufficient brightness to survive multiple reflections.
Photons are only useful when the path is ES*DS*L.
To get some of the more interesting flares requires blurred reflection and/or
refraction, and perhaps a touch of dispersion.  Slow, slow, slow.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 7 Nov 2001 16:44:59
Message: <3be9ab5b$1@news.povray.org>
See image posted in p.b.i.  Uses looks like sphere with ambient set to 1000,
max_trace_leve = 1000, six lenses (12 reflect/refract surfaces) with fresnel
reflection (max set to 1/3 to minimize scene reflection). It's not as pretty
as fake ones, but that's not what I was trying to achieve.  BTW, the viewing
angle here was only 2.5 degrees, orthographic can probably be used as well
and is maybe the better choice.
-tgq
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
source a
and/or
1u_steps
X=asc(substr(C,Y
Date: 7 Nov 2001 16:54:16
Message: <3be9ad88@news.povray.org>
Trevor Quayle wrote:
> Uses [...]
Yep! And it didn't crash?!
Jonathan.
Date: 7 Nov 2001 16:56:59
Message: <3be9ae2b$1@news.povray.org>
without fresnel on it would, but for some reason with fresnel it didn't, I
was even successful with 5000!
-tgq
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3be9ad88@news.povray.org...
> > Uses [...]
> Jonathan.
Date: 7 Nov 2001 16:58:34
Message: <3be9ae8a$1@news.povray.org>
Hmm, something must operate different with fresnel on, it wouldn't even
crash at 1 million.
-tgq
news:3be9ae2b$1@news.povray.org...
> -tgq
> > > Uses [...]
> > Jonathan.
Date: 7 Nov 2001 17:05:04
Message: <slrn9ujc0j.hm6.ron.parker@fwi.com>
Is adc_bailout nonzero?
Date: 7 Nov 2001 17:12:47
Message: <3be9b1df@news.povray.org>
yes, 0.0001
-tgq
I
1u_steps
X=asc(substr(C,Y
Date: 8 Nov 2001 01:26:33
Message: <3bea2599@news.povray.org>
"Bill DeWitt" <bde### [at] cflrrcom> wrote in message
news:3be96283$1@news.povray.org...
> translate
> > standards!
>     I agree.
>  #macro c (X)
>     torus {
>            0.5, 0.1
>               clipped_by {
>                           box {
>                                <  0.7, 0.2 >,
>                                < -0.7,-0.2, 0.7 >
>               rotate-90*x
>               translate x*X
>  #end
>  #macro C (A)
>     cylinder{
>              A, A-y*0.5, 0.1
>  #end
>  merge{
>        c(0.5)
>        c(-0.5)
>        C(x)
>        C(-x)
>        C(0)
>        translate z*2
>        pigment{
>                crackle
>                scale 0.5
>                rotate 90
>                turbulence 0.75
>                color_map {
>                           [ 0.05 rgb 1 ]
>                           [ 0.25 rgbf 1 ]
>               finish {
>                       ambient 1
Hmmm - and maybe add comments as well so we can understand it more easily  ;o)
- Nekar
Date: 8 Nov 2001 05:16:46
Message: <3bea5b8e@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: clipped_by{plane{z,0}}
  Doh! Didn't think of that. Shame on me! :)
Date: 8 Nov 2001 05:17:37
Message: <3bea5bc1@news.povray.org>
: Everybody around here whines about how important it is to use proper
: indenting yet look at that mess! When I do it people critisie me. When
: you guys do it in your sigs it is all of a sudden ok. Talk about double
: standards!
  That's exactly what "obfuscated" means: The opposite of what you should
write usually. :)
Date: 8 Nov 2001 10:15:39
Message: <3beaa19b$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3bea5bc1@news.povray.org...
> write usually. :)
I thought that was (: .yllausu etirw dluohs uoy tahw, the opposite of obfuscated
is detacsufbo surely?
Date: 8 Nov 2001 23:25:44
Message: <3beb5ac8@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3beaa19b$1@news.povray.org...
> > write usually. :)
obfuscated
I don't think so. It looks like you've got it backwards.
Date: 13 Nov 2001 00:25:59
Message: <3bf0aee7@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote...
source a
and/or
Or you can use a bit of phong (and/or specular) highlighting to get the
reflection of the light_source to show up.  Over a year ago tried this with
a bit of dispersion and it worked great, though the renders were SO SLOW!
-Nathan
