POV-Ray : Newsgroups : povray.general : Array... Server Time
3 Nov 2026 18:28:07 EST (-0500)
  Array... (Message 1 to 19 of 19)
Subject: Array...
Date: 14 Oct 2001 11:34:57
Message: <3BC9AFCA.9B469579@sympatico.ca>
Does anyone could give me
some "basic" principles about Array !
I draw a 3d zero and a 3d one,  which objects
can be choosen randomly from a macro....
The macro is done and works well.
Each time I need a number,  the macro
randomly return a zero or a one.
I only need to put this "binary_01 ( )" macro
inside an array,  say,  20*20.
   Alex Pilote
...I know I could use a loop....
Subject: Re: Array...
Date: 14 Oct 2001 11:51:32
Message: <3bc9b483@news.povray.org>
F.Audet <flo### [at] sympaticoca> wrote:
: ...I know I could use a loop....
  So why don't you do it?
Date: 14 Oct 2001 17:05:05
Message: <3bc9fe01@news.povray.org>
I think he meant: "...I know I should use a loop..."
"Warp" <war### [at] tagpovrayorg> ha scritto nel messaggio
news:3bc9b483@news.povray.org...
Date: 14 Oct 2001 17:07:16
Message: <3bc9fe84$1@news.povray.org>
"F.Audet" <flo### [at] sympaticoca> ha scritto nel messaggio
news:3BC9AFCA.9B469579@sympatico.ca...
>    Alex Pilote
In fact:
#declare YOUR_ARRAY = array[20][20]
#declare i = 0;
#while (i<20)
#declare j=0;
#while (j<20)
#declare YOUR_ARRAY[i][j]= binary_01();
#declare j=j+1;
#declare i=i+1;
Done.
Date: 14 Oct 2001 20:38:36
Message: <3BCA2F34.20A7BB2E@sympatico.ca>
> >    Alex Pilote
> In fact:
> #declare i = 0;
> #while (i<20)
> #declare j=0;
> #while (j<20)
> #declare j=j+1;
> #end
> #declare i=i+1;
> #end
> Done.
I don't know why,  but this code doesn't work
with the object which I have to reproduce....
I have also tried this code with a simple sphere;
it doesn' t work anymore.
So,  is there another way of using Array
without using the while directive ?!?
Thank you,            Alex
Date: 14 Oct 2001 20:39:53
Message: <slrn9skc2p.ip.ron.parker@fwi.com>
Is the problem perhaps that you're trying to do it with beta 5 of POV 3.5?
There was a problem with #while loops that caused crashes; it's been fixed
in beta 6.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 14 Oct 2001 21:42:57
Message: <3BCA3E4A.9BBC741E@sympatico.ca>
> in beta 6.
No,  I am still working with the 3.1 version because my computer does
not accept 800*600 screen minimum requirement...  I plan to solve
this problem soon,  with a more recent computer...
I decided to do what I wanted to do in simulating an array
with two #while loops, and it finally worked.
But if you could see why the famous array
did not work,  here is the code :
#declare s1 = seed(1);
#macro bin_01 ()  // note that it works well with a simple while, without array....
  #local obj_temp =
  #if ( rand(s1) <= 0.5 )
    object { nice_zero }
  #else
    object { nice_one }
  object { obj_temp }
#declare i = 0;
#while (i<20)
#declare j=0;
#while (j<20)
#declare YOUR_ARRAY[i][j] = bin_01()
#declare j=j+1;
#declare i=i+1;
> Alex Pilot
Date: 14 Oct 2001 22:05:59
Message: <slrn9skh47.kt.ron.parker@fwi.com>
Maybe something having to do with returning a local from a macro; this might
have been a bug in 3.1 as well.  Try rewriting the macro like this:
>  #else
>    object { nice_one }
>  #end
>#end
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C)bicubic_patch{type 1u_steps 6
v_steps 6R(1)R(3)R(5)R(7)translate 9*z-2pigment{rgb z}}#end#macro _(Y)#local X=
asc(substr(C,Y,1))-65;<mod(X,4)div(X,4)>#end#local O=union{Q("ABEFUQWS")Q(// RON
"WSXTLOJN")}Q("JNKLCGCD")union{O}union{O translate 3*x}light_source{x 1}//PARKER
Date: 15 Oct 2001 11:07:56
Message: <3BCAFAF3.B8207208@sympatico.ca>
> >#macro bin_01 ()
> >  #else
> >    object { nice_one }
> >  #end
> >#end
... It does parse and trace,  but nothing appears on the screen.
Messages: 1 frame level object; 1 infinite.   // my plane object !
... I think it is my fault,  cause I just tried,  a minute ago,  with
a simple csg object,  without any kind of randomness and #local,
and it doesn' t work anymore !
in fact,  the following code doesn' t work at all...
#declare i = 0;
#while (i<20)
#declare j=0;
#while (j<20)
#declare YOUR_ARRAY[i][j] = sphere { 0, 1 pigment { White }}
#declare j=j+1;
#declare i=i+1;
Have I to put it into "object {YOUR_ARRAY}", or something like that ?!?
Alex Pilot
Date: 15 Oct 2001 11:28:49
Message: <3bcb00b1@news.povray.org>
I didn't try it, but it seems to me that if you are using somewhere in the
code:
#declare toto = sphere{0*x,r}
there is not any object in the scene until  you write
object { toto }
It should be the same with your code.
Chaps
"F.Audet" <flo### [at] sympaticoca> wrote in message
news:3BCAFAF3.B8207208@sympatico.ca...
might
> > >#macro bin_01 ()
> > >  #else
> > >    object { nice_one }
> > >  #end
> > >#end
> #declare i = 0;
> #while (i<20)
> #declare j=0;
> #while (j<20)
> #declare j=j+1;
> #end
> #declare i=i+1;
> #end
> Alex Pilot
1u_steps 6
_(Y)#local X=
1}//PARKER
Date: 15 Oct 2001 11:46:05
Message: <3BCB03E4.6337B066@sympatico.ca>
I should have missed something, somewhere...
Is there a tutorial about arrays,  on the web ?
Thank you,               Alex
Date: 15 Oct 2001 14:15:46
Message: <3bcb27d2@news.povray.org>
might
> > >#macro bin_01 ()
> > >  #else
> > >    object { nice_one }
> > >  #end
> > >#end
> #declare i = 0;
> #while (i<20)
> #declare j=0;
> #while (j<20)
> #declare j=j+1;
> #end
> #declare i=i+1;
> #end
> Alex Pilot
I think you misunderstood what an array is. Just having 400 objects put in
an array does not mean that you get them traced!
If you want to put your 400 objects in a 20x20 units grid you have to add
the following code:
 #declare i = 0;
 #while (i<20)
#declare j=0;
#while (j<20)
object {YOUR_ARRAY[i][j] translate <-10 +i, 0 , -10+j>}
#declare j=j+1;
#declare i=i+1;
But probably it's me who has misunderstood you...
Jonathan.
Date: 15 Oct 2001 15:01:47
Message: <3bcb329a@news.povray.org>
JRG <jrg### [at] hotmailcom> wrote:
: I think you misunderstood what an array is.
  It is possible that someone who has no experience in programming may have
no notion what an "array" is in a programming language. The term "array"
has also another meaning in a different context and this may be the cause
of the confusion.
Date: 15 Oct 2001 15:22:37
Message: <3BCB36A5.FD815ADF@sympatico.ca>
> of the confusion.
 I thought the array function allowed to reproduce an object
into a grid system... I didn' t think about it in term of programming anymore.
Excuse me,  I misunderstood the reel functionality of an array.
Alex
Date: 15 Oct 2001 15:26:10
Message: <3bcb3852@news.povray.org>
Then you just need this one:
#declare i = 0;
#while (i<20)
#declare j=0;
#while (j<20)
object {binary_01() translate <-10 +i, 0 , -10+j>}
#declare j=j+1;
#declare i=i+1;
Hope this helps,
Jonathan.
Subject: Re:that's ok
Date: 15 Oct 2001 20:24:44
Message: <3BCB7D73.EEE5DB3C@sympatico.ca>
> #declare i = 0;
> #while (i<20)
> #declare j=0;
> #while (j<20)
> #declare j=j+1;
> #end
> #declare i=i+1;
> #end
> Hope this helps,
> Jonathan.
Yes,  I did it that way and
I think everything is OK by now...   Have a look at Binaries-images
to see what were the purpose of my requests.
......................."Virus_inc"............"F.Audet"...............................
Thank you very much for your responses,
        Alex
Date: 17 Oct 2001 14:38:42
Message: <3bcdd032@news.povray.org>
does
Do you mean, Povray 3.5 (beta) doesn't run with 640*480 screen
resolution? (3.1g did some warning - is not designed to run under
800*600 - but it run) I'm a bit afraid about that message, I'm going
to use Povray 3.5 (when it's out) on a 640*480 screen.
Can someone tell me if that's true (or better: not true) - I tried
with beta 4, it worked (you could not press the ok-button of the
povlegal-screen - but it worked)
Or did I misunderstand you?
cukk
Date: 17 Oct 2001 18:41:19
Message: <3bce090f@news.povray.org>
"KalleK" <kal### [at] gmxde> wrote in message news:3bcdd032@news.povray.org...
> cukk
I just tried it.  It runs.
...Chambers
Date: 18 Oct 2001 04:02:12
Message: <3bce8c84@news.povray.org>
Phewww...
Thank you
cukk
