POV-Ray : Newsgroups : povray.general : Array... Server Time
12 May 2026 08:38:20 EDT (-0400)
  Array... (Message 1 to 10 of 19)
Subject: Array...
Date: 14 Oct 2001 11:34:57
Message: <3BC9AFCA.9B469579@sympatico.ca>
Does anyone could give me
some "basic" principles about Array !
I draw a 3d zero and a 3d one,  which objects
can be choosen randomly from a macro....
The macro is done and works well.
Each time I need a number,  the macro
randomly return a zero or a one.
I only need to put this "binary_01 ( )" macro
inside an array,  say,  20*20.
   Alex Pilote
...I know I could use a loop....
Subject: Re: Array...
Date: 14 Oct 2001 11:51:32
Message: <3bc9b483@news.povray.org>
F.Audet <flo### [at] sympaticoca> wrote:
: ...I know I could use a loop....
  So why don't you do it?
Date: 14 Oct 2001 17:05:05
Message: <3bc9fe01@news.povray.org>
I think he meant: "...I know I should use a loop..."
"Warp" <war### [at] tagpovrayorg> ha scritto nel messaggio
news:3bc9b483@news.povray.org...
Date: 14 Oct 2001 17:07:16
Message: <3bc9fe84$1@news.povray.org>
"F.Audet" <flo### [at] sympaticoca> ha scritto nel messaggio
news:3BC9AFCA.9B469579@sympatico.ca...
>    Alex Pilote
In fact:
#declare YOUR_ARRAY = array[20][20]
#declare i = 0;
#while (i<20)
#declare j=0;
#while (j<20)
#declare YOUR_ARRAY[i][j]= binary_01();
#declare j=j+1;
#declare i=i+1;
Done.
Date: 14 Oct 2001 20:38:36
Message: <3BCA2F34.20A7BB2E@sympatico.ca>
> >    Alex Pilote
> In fact:
> #declare i = 0;
> #while (i<20)
> #declare j=0;
> #while (j<20)
> #declare j=j+1;
> #end
> #declare i=i+1;
> #end
> Done.
I don't know why,  but this code doesn't work
with the object which I have to reproduce....
I have also tried this code with a simple sphere;
it doesn' t work anymore.
So,  is there another way of using Array
without using the while directive ?!?
Thank you,            Alex
Date: 14 Oct 2001 20:39:53
Message: <slrn9skc2p.ip.ron.parker@fwi.com>
Is the problem perhaps that you're trying to do it with beta 5 of POV 3.5?
There was a problem with #while loops that caused crashes; it's been fixed
in beta 6.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 14 Oct 2001 21:42:57
Message: <3BCA3E4A.9BBC741E@sympatico.ca>
> in beta 6.
No,  I am still working with the 3.1 version because my computer does
not accept 800*600 screen minimum requirement...  I plan to solve
this problem soon,  with a more recent computer...
I decided to do what I wanted to do in simulating an array
with two #while loops, and it finally worked.
But if you could see why the famous array
did not work,  here is the code :
#declare s1 = seed(1);
#macro bin_01 ()  // note that it works well with a simple while, without array....
  #local obj_temp =
  #if ( rand(s1) <= 0.5 )
    object { nice_zero }
  #else
    object { nice_one }
  object { obj_temp }
#declare i = 0;
#while (i<20)
#declare j=0;
#while (j<20)
#declare YOUR_ARRAY[i][j] = bin_01()
#declare j=j+1;
#declare i=i+1;
> Alex Pilot
Date: 14 Oct 2001 22:05:59
Message: <slrn9skh47.kt.ron.parker@fwi.com>
Maybe something having to do with returning a local from a macro; this might
have been a bug in 3.1 as well.  Try rewriting the macro like this:
>  #else
>    object { nice_one }
>  #end
>#end
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C)bicubic_patch{type 1u_steps 6
v_steps 6R(1)R(3)R(5)R(7)translate 9*z-2pigment{rgb z}}#end#macro _(Y)#local X=
asc(substr(C,Y,1))-65;<mod(X,4)div(X,4)>#end#local O=union{Q("ABEFUQWS")Q(// RON
"WSXTLOJN")}Q("JNKLCGCD")union{O}union{O translate 3*x}light_source{x 1}//PARKER
Date: 15 Oct 2001 11:07:56
Message: <3BCAFAF3.B8207208@sympatico.ca>
> >#macro bin_01 ()
> >  #else
> >    object { nice_one }
> >  #end
> >#end
... It does parse and trace,  but nothing appears on the screen.
Messages: 1 frame level object; 1 infinite.   // my plane object !
... I think it is my fault,  cause I just tried,  a minute ago,  with
a simple csg object,  without any kind of randomness and #local,
and it doesn' t work anymore !
in fact,  the following code doesn' t work at all...
#declare i = 0;
#while (i<20)
#declare j=0;
#while (j<20)
#declare YOUR_ARRAY[i][j] = sphere { 0, 1 pigment { White }}
#declare j=j+1;
#declare i=i+1;
Have I to put it into "object {YOUR_ARRAY}", or something like that ?!?
Alex Pilot
Date: 15 Oct 2001 11:28:49
Message: <3bcb00b1@news.povray.org>
I didn't try it, but it seems to me that if you are using somewhere in the
code:
#declare toto = sphere{0*x,r}
there is not any object in the scene until  you write
object { toto }
It should be the same with your code.
Chaps
"F.Audet" <flo### [at] sympaticoca> wrote in message
news:3BCAFAF3.B8207208@sympatico.ca...
might
> > >#macro bin_01 ()
> > >  #else
> > >    object { nice_one }
> > >  #end
> > >#end
> #declare i = 0;
> #while (i<20)
> #declare j=0;
> #while (j<20)
> #declare j=j+1;
> #end
> #declare i=i+1;
> #end
> Alex Pilot
1u_steps 6
_(Y)#local X=
1}//PARKER
