POV-Ray : Newsgroups : povray.general : Making animatable humans Server Time
23 Mar 2026 17:09:38 EDT (-0400)
  Making animatable humans (Message 1 to 7 of 7)
Subject: Making animatable humans
Date: 1 Jul 2001 13:26:53
Message: <3B3F7A8F.50106@home.nl>
I was thinking about how to make animatable humans. At the moment
there's pretty less software (I only know Poser, but it doesn't animated
and export to pov). So I was thinking, perhaps I can write some nice
piece of software myself. But there's a big problem, what is the best
way to design human beings? I'm artistically not capable of desinging
them, so they have to be physical creatable, so I 'only' have to get a
nice algorithm.
I was thinking about getting the bones and muscles once and the let the
user input the size, length and so on. I don't know if this can be done.
Anyone has some good ideas on what user input is needed?
Remco Poelstra
Subject: Re: Making animatable humans
Date: 1 Jul 2001 14:28:20
Message: <3b3f6bc4@news.povray.org>
"Remco Poelstra" <rjp### [at] homenl> wrote in message
news:3B3### [at] homenl...
> Hi,
> and export to pov).
You can animate in Poser, and with a bit (actually, a lot) of work you can
even render the animations in POV.  You'll have to export every single frame
as a OBJ file, convert them using a program such as 3DWin, edit all the
resulting include files and get the textures right, etc.  But it *can* be
done.
Date: 1 Jul 2001 14:46:58
Message: <3B3F8D52.9040407@home.nl>
> done.
Ok, but it's not what I call fun.
remco
Date: 2 Jul 2001 04:24:55
Message: <3B402FE2.81761D7@inapg.inra.fr>
can
frame
be
> done.
It's a little bit easier than that, actually, since all the resulting
meshes (usually) share the same texture definition. It must be defined
only once in the main pov file, like for a single mesh. The most
difficult part is to get the right correspondance between the frame
numbers and pov clock.
#declare Frame_number=*** // "01","02"..., can be a function of clock
#declare T_*** = texture{***} // put the global mesh textures here
#declare Fname= concat("mymesh",frame_number,"_o.inc") // creates the
file name for this frame
#include Fname // call the mesh file
G.
Date: 3 Jul 2001 16:02:58
Message: <3B4226A1.71494106@erols.com>
> animated and export to pov). So I was thinking, perhaps I can write
> some nice piece of software myself. But there's a big problem, what is
> the best way to design human beings?
I'm note-taking on a similar project; namely, I'm working on a
subdivision surface modeller that supports UV mapping and posable
models, with the ability to generate .INC files that can be animated
with the appropriate POV script.  It's a tall order, and my IRTC work
is greatly hampering the progress of the project.
Once this is done, someone else can actually model the humans.
John
ICQ: 46085459
Date: 5 Jul 2001 15:11:52
Message: <3B44BBF8.4ACB6733@my-deja.com>
> Hi,
> nice algorithm.
> Remco Poelstra
Have you looked at Blobman?  I've played a little with it, and the
people seem acceptable (I wish I understood how to make clothes for
them, though).  I've not gotten past some basic posing, but the people
are already built, the "output" of a movement macro would be a matrix of
positions for the body parts.
Good luck (I would love to have an easy to use human animation macro,
too).
Tom A.
See everything; over look a great deal; correct a little.  -Blessed Pope
John XXIII
Date: 7 Jul 2001 09:56:12
Message: <3B4714EC.761D315C@pacbell.net>
> done.
And I could do a root canal on myself but I am not going to try it anytime
soon :)
Ken Tyler
