POV-Ray : Newsgroups : povray.general : Translucent texture Server Time
25 Oct 2026 01:14:58 EDT (-0400)
  Translucent texture (Message 1 to 5 of 5)
Subject: Translucent texture
Date: 18 Jun 2001 18:02:25
Message: <3B2E7A36.BB174441@taconic.net>
Does anyone have any tips, suggestions or pointers towards getting a
translucent effect in pov? (This is not to be confused with
transparency.)
Abe
Subject: Re: Translucent texture
Date: 18 Jun 2001 18:31:13
Message: <slrn9it09j.3gn.ron.parker@fwi.com>
>transparency.)
You can cheat with some objects, such as bicubic patches, that allow
illumination from both sides.  I think MegaPOV lets you turn on that
functionality for any object with the double_illuminate keyword.
If that doesn't do what you want, your only alternative is a dense
scattering media.  The down side to that, of course, is that it might
be a bit slow.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 19 Jun 2001 01:48:39
Message: <3b2ee7b7@news.povray.org>
Abe <bul### [at] taconicnet> wrote in message
news:3B2E7A36.BB174441@taconic.net...
> transparency.)
I used the following pigment for frost on a window. It looked ok from a
distance.
  bozo
  scale 0.0001
  color_map {
   [0.0 Clear]
   // [0.9 White]
   [1.0 White]
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.          Babylon 5 *
* The difficult we do immediately, the impossible takes a little longer *
Date: 19 Jun 2001 02:17:40
Message: <3B2EEEAF.8D358639@rsp.com.au>
You could consider looking at PovMan by Vahur Krouverk:
http://www.aetec.ee/fv/vkhomep.nsf/pages/povman2
it allows you to define your own shading models and procedural
pigments.(very versitile)
benp
> transparency.)
> Abe
Date: 19 Jun 2001 14:28:58
Message: <9wvEBCAVxyL7EwJj@econym.demon.co.uk>
>transparency.)
You might consider something like
     pigment {rgbt <1,1,1,0.7>}
     normal {bozo scale <1,1,10>*0.001}
     interior {ior 1.3}
This is intended to be viewed from along the z axis, so the normals are
scaled higher in the z direction than they are in the x and y
directions.
Depending on the exact effect you're after, you may want to tweak some
of those numbers. Increasing the ior increases the scattering. Changing
the pigment to {rgbt <1.5,1.5,1.5,0.7>} can look convincing in some
cases.
Mike Williams
Gentleman of Leisure
