POV-Ray : Newsgroups : povray.general : Mirroring a pigment? Server Time
25 Oct 2026 02:05:58 EDT (-0400)
  Mirroring a pigment? (Message 1 to 9 of 9)
Subject: Mirroring a pigment?
Date: 24 May 2001 02:39:43
Message: <3B0CAC6C.4B589080@hotmail.com>
Here’s a problem.  I have union of two hemispheres.  I want to use the
same pigment, such as  Blue_Sky,  on one hemisphere and use the mirror
of that texture on the other hemisphere.  I have tried rotating the
pigments but I can’t get them to match.
Thanks in advance for any help,
Subject: Re: Mirroring a pigment?
Date: 24 May 2001 02:46:51
Message: <4kbpgtgag9btb3tspju0ne6ske77gpriaf@4ax.com>
On Wed, 23 May 2001 23:38:36 -0700, Bob Franke
Scale it -1 along the axis you want to mirror it about.
Mirror x: scale <-1,1,1>
Mirror y: scale <1,-1,1>
Mirror z: scale <1,1,-1>
Peter Popov ICQ : 15002700
Date: 24 May 2001 13:03:02
Message: <3B0D3FF1.A0441D65@erols.com>
> >the same pigment, such as  Blue_Sky,  on one hemisphere and use the
> >mirror of that texture on the other hemisphere.  I have tried
> >rotating the pigments but I can’t get them to match.
And if that axis is not parallel to any of the coordinate axes:
#local vA=vnormalize(Axis_of_Mirroring);
matrix <1-2*vA.x*vA.x, -2*vA.x*vA.y, -2*vA.x*vA.z,
matrix <-2*vA.x*vA.y, 1-2*vA.y*vA.y, -2*vA.y*vA.z,
matrix <-2*vA.x*vA.z, -2*vA.y*vA.z, 1-2*vA.z*vA.z,
        0, 0, 0 >
This is untested, but I'm confident it works.
John
ICQ: 46085459
Date: 24 May 2001 13:49:42
Message: <3B0D49E7.A58E6795@gmx.de>
>         0, 0, 0 >
Surely not the way it is, better use (untested too BTW):
                    0,             0,             0 >
Anyway i would not be able to write this down straigt away like you, would
rather use the 'rotate, scale, rotate back' method.
Date: 24 May 2001 13:56:57
Message: <3B0D4C95.E4867033@erols.com>
> >         0, 0, 0 >
>                     0,             0,             0 >
Note to self:  Edit better when using cut-and-paste...
> Anyway i would not be able to write this down straight away like you,
Only took me about five minutes to work out the matrix.
> would rather use the 'rotate, scale, rotate back' method.
Yeah, that would work, too.
ICQ: 46085459
Date: 24 May 2001 18:31:55
Message: <Xns90AC56942998seed7@povray.org>
> matrix [...]
 You know, there are some of these days on the net, I enjoy more than
average, they make me smile in a certain way. It happens sometimes on
the USENET but also on this, relative small, server. For example, a
thread with a peculiar problem is going on a few days;
    1. A day, or two, after you think, everything is said and
explained, Chis Colefax suddenly comes 'crawling from under his stone'.
He gives a simple yet elegant solution to the problem, in a way that
makes all of us hurry, to catch our lower jaw before it hits the
ground.
Or ...
    2. the problem discussed is about some esoteric transformation.
After a possible solution or two published, John VanSickle appears with
4-5 lines of nifty code, containing the word 'matrix'. And then the
'MatrixMan' has the guts to say:
... and it does, not just for this case but for all related.
I love it,
thank you,
Ingo
Date: 24 May 2001 22:10:50
Message: <3B0DBEE8.B9666CA9@hotmail.com>
This is what I love about the Internet, got a problem, put my question out
there and check the next day for a bunch of great answers.  The negative
scale method works for me.  If I have more time I will check out the
matrix.  Now I can get back to modeling my ladybug.
Thanks guys,
Date: 24 May 2001 22:19:19
Message: <3B0DC1E7.6F5F8704@pacbell.net>
Well, that is at least true for this part of the internet.
Ken Tyler
Date: 26 May 2001 13:50:45
Message: <3B0FEE31.4738E7E2@erols.com>
> stone'. He gives a simple yet elegant solution to the problem, in a
> way that makes all of us hurry, to catch our lower jaw before it hits
> the ground.
> Or ...
> with 4-5 lines of nifty code, containing the word 'matrix'. And then
> the 'MatrixMan' has the guts to say:
One of my Throughly Useful Macros can also do mirroring:
Stretch(Vector,-1)
Silly, not to think of it.
John
ICQ: 46085459
