POV-Ray : Newsgroups : povray.general : Sigs Server Time
4 Nov 2026 01:03:50 EST (-0500)
  Sigs (Message 1 to 12 of 12)
Subject: Sigs
Date: 10 May 2001 07:15:49
Message: <3AFA7866.6013E87A@ucl.ac.uk>
Wow, leave the group for a fortnight and it sure looks different.
Covered in .sigs :)
Anyone fancy rendering them all and collecting them together on a
webpage?  We could have a competition...
-No Sig yet- :(
Subject: Re: Sigs
Date: 10 May 2001 07:49:31
Message: <3afa804b$1@news.povray.org>
Andrew wrote in message <3AFA7866.6013E87A@ucl.ac.uk>...
I'm working on such page. Of course I'll ask all authors first to get scripts.
#macro Sig(A,B,X)_(A,B)_(B,X)_(X,A)#end#macro _(A,B)cylinder{<A.x,A.y,3>,<B.u,
B.v,3>.1,9}#end global_settings{max_trace_level 9}light_source{0 1}camera{up y
*4right-3*x}blob{_(<3,1>,<1,-5>)_(<2,-2>,<4,-2>)Sig(x,<-1,1.5>,<1,3>)_(z-1,z-4
)pigment{rgb 1}}box{-3 3pigment{rgb 0}finish{reflection 1}hollow} // POV-Ray31
Subject: Re: Sigs
Date: 10 May 2001 09:19:02
Message: <slrn9fl5a8.kbm.ron.parker@fwi.com>
Here's all of mine, in one convenient location.  I never adopted Warp's
suggestions on my third one, though, so it's a little bulkier than it needs
to be.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Subject: Re: Sigs
Date: 10 May 2001 09:45:08
Message: <3AFA9A41.DE1A8162@videotron.ca>
Here's mine.  I modified it to have the same look and feel as my other
.sigs.
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Subject: Re: Sigs
Date: 11 May 2001 07:20:32
Message: <3afbcaff@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: I never adopted Warp's
: suggestions on my third one, though, so it's a little bulkier than it needs
: to be.
  Why not?-)
  And here is my signature (so you don't have to search it somewhere else).
  I didn't look so much after a cool-looking signature when rendered, but for
obfuscation. It's rather hard to make obfuscated POV-Ray code (which is also
as short as possible) and this is the best I could achieve.
  However, I'm quite happy with the rendered result as well...
Subject: Re: Sigs
Date: 11 May 2001 08:43:24
Message: <slrn9fnnjh.m36.ron.parker@fwi.com>
>: to be.
>  Why not?-)
Because I threw out that signature just after you made the suggestions, so
I never applied them.
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Subject: Re: Sigs
Date: 12 May 2001 02:06:50
Message: <3afcd2fa@news.povray.org>
Here's mine. I'm working on a better one still
Nekar
#local N=<-4,8,20>;#local K=<4,-8,20>;#local R=seed(0);union{#while((K-N).x>0)
#local X=N;#local N=N+<rand(R),rand(R),1>/30;#local N=(vlength(N-K)<vlength(X-K
)?N:2*X-N);sphere{<N.y,-N.x,N.z>,.2}sphere{N,.2}sphere{<-N.x-8,N.y,N.z>,.1//-NX
pigment{rgb N}}sphere{<N.x+8,-N.y,N.z>,.1 pigment{rgb N}}#end pigment{rgb 9}}
Subject: Re: Sigs
Date: 12 May 2001 05:43:24
Message: <3afd05bc@news.povray.org>
The old one:
This one looks better, but it's five lines:
#local N=<-20,40,100>;#local K=<20,-40,100>;#local R=seed(0);blob{#while((K-N).
x>0)#local X=N;#local N=N+<rand(R),rand(R),1>/3;#local N=(vlength(N-K)<vlength(
X-K)?N:2*X-N);sphere{<N.y,-N.x,N.z>,1,1 scale .02}sphere{N,1,1 scale.02}sphere{
<-N.x-40,N.y,N.z>1,1 scale.01}sphere{<N.x+40,-N.y,N.z>1,1 scale.01 }#end
pigment{rgbt 1}interior{media{emission <2,4,5>*5}}hollow}// Nekar Xenos
Subject: Re: Sigs
Date: 20 May 2001 09:10:39
Message: <3B07C288.D4B71CD6@comtrade.ee>
I read all these sig messages and decided to create mine .sig as well.
Here it is, if you want to use it. It's quite straightforward and not
the most beautiful and shortest, though.
#macro a(l)cylinder{0,y*l,.5 2pigment{rgb 2-3*x}normal{bozo.2scale.1}
#end#macro b(d)translate d#end blob{a(5.65)rotate z*-45}a(2.83)rotate
z*45b(x*4)}a(4)b(x/2)}a(4)b(x*2)}b(-2+z*7)}light_source{-9color-2}//VK
Subject: Re: Sigs
Date: 21 May 2001 07:04:52
Message: <3b08f653@news.povray.org>
Vahur Krouverk <vkr### [at] comtradeee> wrote:
: #macro a(l)cylinder{0,y*l,.5 2pigment{rgb 2-3*x}normal{bozo.2scale.1}
: #end#macro b(d)translate d#end blob{a(5.65)rotate z*-45}a(2.83)rotate
: z*45b(x*4)}a(4)b(x/2)}a(4)b(x*2)}b(-2+z*7)}light_source{-9color-2}//VK
  I seem to have this obsession of making other people's signatures
shorter. I just can't resist the temptation :)
  Well, here it is (the normal pattern is different, but I don't think
you'll mind):
#macro a(l,R,d)cylinder{0,y*l,.5,2rotate z*R translate x*
d-2+z*7}#end blob{a(5.65,-45,0)a(2.83,45,4)a(4,0,.5)a(4,0
,2)pigment{rgb x}normal{granite.3}}light_source{-9rgb 2}//VK
Subject: Re: Sigs
Date: 21 May 2001 14:29:04
Message: <3B095EA7.84C16656@comtrade.ee>
> you'll mind):
Thanks, this "optimization" trick seems to be quite well coming out of
your sleeve.
Subject: Re: Sigs
Date: 21 May 2001 15:07:48
Message: <slrn9gips6.uu2.ron.parker@fwi.com>
>you'll mind):
I have that problem, too.  Here's a couple characters shorter, with the
extra mind-numbing quality of the "l.5" string.
#macro a(l,R,d)cylinder{0y*l.5,2rotate 45*R translate<d
0,7>-2}#end blob{a(5.65,-z,0)a(2.83z,4)a(4,0,.5)a(4,0//  VK
2)pigment{red 1}normal{granite.3}}light_source{-9rgb 2}
