#local a=<1,1,0>;#local b=<2,1,0>;#local c=<3,2,0>;#local d=<5,3,0>;
#macro P(A,B) polygon{4,A,A+z,B+z,B texture{pigment{color rgb 1}finish
{ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P(2*b,d)P(
d,<2,3,0>)}camera{location <5,1.2,-5>look_at a orthographic}//FL
I had to do it; it's a compulsion. Doesn't anyone understand?
#local a=x+y;#local b=x+a;#local c=a+b;#macro P(A,B) polygon{
4,A,A+z,B+z,B texture{pigment{color rgb 1}finish{ambient 1}}}
#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P(2*b,b+c)P(b+
c,<2,3>)}camera{location<5,1.2,-5>look_at a orthographic}//FL
or
#local a=x+y;#local b=x+a;#local c=a+b;#macro P(A,B)polygon{5,A,A+z,B+z,B,A//FL
texture{pigment{rgb 1}finish{ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P
(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)}camera{location<5,1.2,-5>look_at a orthographic}
which has the advantage of rendering without warnings.
#local R=<7084844682857967,32787982,826975826580>#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Francois Labreque <fla### [at] videotron ca> wrote:
: #local a=<1,1,0>;#local b=<2,1,0>;#local c=<3,2,0>;#local d=<5,3,0>;
: #macro P(A,B) polygon{4,A,A+z,B+z,B texture{pigment{color rgb 1}finish
: {ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P(2*b,d)P(
: d,<2,3,0>)}camera{location <5,1.2,-5>look_at a orthographic}//FL
I don't understand what does it do, but it can ne made a lot shorter:
#local a=x+y;#local b=a+x;#local c=a+b;#local d=b+c;#macro P(A,B)polygon{
5,A,A+z,B+z,B,A pigment{rgb 9}}#end P(0,a)P(a,b)P(b,c)P(c,2*a)P(2*a,2*b)P
(2*b,d)P(d,<2,3,0>)camera{location <5,1.2,-5>look_at a orthographic}//FL
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
Ron Parker <ron### [at] povray org> wrote:
: #local a=x+y;#local b=x+a;#local c=a+b;#macro P(A,B)polygon{5,A,A+z,B+z,B,A//FL
: texture{pigment{rgb 1}finish{ambient 1}}}#end union{P(0,a)P(a,b)P(b,c)P(c,2*a)P
: (2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)}camera{location<5,1.2,-5>look_at a orthographic}
Darn, you made it first.
However, my version is shorter :)
And doesn't warn either.
Yes, I like the rgb 9 trick. That one's new to me. And of course the
'texture' keyword is almost always redundant.
The ,0 is unnecessary, as is the space after location.
So can you make my new one smaller?
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z} // Only my opinions
Okay, that one was boring. So's this one, but at least the output is pretty.
plane{z 3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate z
*60#local a=a-1;#end translate-15*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{-9blue 1scale-x-y+z}text{ttf
"arial.ttf""RP".01,0translate-<.6,.4,.02>}light_source{-z*3rgb-.2} // Ron Parker
And now: the warning-free version.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
That looks like fun! So I made my own. I'm sure it can be shortened more
than this, but 4 lines ain't bad :)
#default{texture{pigment{rgb 0}finish{reflection 1}}}#macro M(A) #declare
B=A;
#end#macro L(A) sphere{A,1}sphere{B,1}cylinder{A,B,1}#declare B=A;#end
M(<4,0>)
L(<8,8>)L(<2,8>)M(<6,0>)L(<10,8>)L(<16,8>)M(<8,4>)L(<12,4>)camera{location
<9,4,-15>}sky_sphere{pigment{bozo colour_map{[0 rgb 0][1 rgb 1]}}} // Tek
> B=A;
> M(<4,0>)
Doh! It wrapped wrong! Can anyone explain what's going on with that? When I
wrote it it wasn't wrapping like that :(
Tek
http://www.evilsuperbrain.com
I think I've fixed it now... I hope...
#default{texture{pigment{rgb 0}finish{reflection 1}}}#macro M(A) #declare B=A;
#end#macro L(A) sphere{A,1}sphere{B,1}cylinder{A,B,1}#declare B=A;#end M(<4,0>)
Your newsreader is set to wrap words automatically.
Yup, I've bumped it up to 80 characters now.
Tek
Ron Parker <ron### [at] povray org> wrote in message
news:slr### [at] fwi com...
x}rotate
60
Parker
Still 4 lines, but lots more room for comments:
#default{pigment{rgb 0}finish{reflection 1}}#macro M(A)#declare B=A;#end#macro L
(A)sphere{A,1}sphere{B,1}cylinder{A,B,1}M(A)#end M(4*u)L(<8,8>)L(<2,8>)M(6*u)L(<
10,8>)L(<16,8>)M(<8,4>)L(<12,4>)camera{location<9,4,-15>}sky_sphere{pigment{bozo
color_map{[0rgb 0][1rgb 1]}}} // Tek
Hey, I didn't know you could put line breaks there! Thanks :)
color_map{[0rgb 0][1rgb 1]}}} // Tek. www.evilsuperbrain.com
Ron Parker wrote:
> or
Thanks for the optimization. I had to leave for work before I had
finished... I knew I had to close my polygons, but I also found one that
was unecessary, So here's the final version:
,B,A texture{pigment{rgb 1}finish{ambient 1}}}#end union{P(0,a)P(a,b)P(
b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)}camera{location<5,1.2,-5>look_at a
orthographic} // Francois Labreque - fla### [at] videotron ca
wrong!
I get a "Can't find font file!" error.
I know how to fix it, but it should work "out-of-the-box".
Francois Labreque | The surest sign of the existence of extra-
flabreque | terrestrial intelligence is that they never
@ | bothered to come down here and visit us!
videotron.ca | - Calvin
Reminds me of the Van Halen logo.
On Tue, 08 May 2001 20:32:47 -0400, Francois Labreque wrote:
>wrong!
Well, maybe... but I'm cursed with initials that don't have easy
sphere-and-cylinder construction, so I have to fall back on ttf
objects.
: Well, maybe... but I'm cursed with initials that don't have easy
: sphere-and-cylinder construction, so I have to fall back on ttf
: objects.
Well, my nick has an 'R' and a 'P' as well (besides 'W' and 'A') and I
don't have any problem ;)
: So here's the final version:
: ,B,A texture{pigment{rgb 1}finish{ambient 1}}}#end union{P(0,a)P(a,b)P(
: b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)}camera{location<5,1.2,-5>look_at a
: orthographic} // Francois Labreque - fla### [at] videotron ca
Wouldn't you prefer:
,B,A pigment{rgb 9}}#end P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2
,3>)camera{location<5,1.2,-5>look_at a orthographic}
: #default{pigment{rgb 0}finish{reflection 1}}#macro M(A)#declare B=A;#end#macro L
: (A)sphere{A,1}sphere{B,1}cylinder{A,B,1}M(A)#end M(4*u)L(<8,8>)L(<2,8>)M(6*u)L(<
: 10,8>)L(<16,8>)M(<8,4>)L(<12,4>)camera{location<9,4,-15>}sky_sphere{pigment{bozo
: color_map{[0rgb 0][1rgb 1]}}} // Tek
If you add a "scale.5" or similar right after the color_map block, the
sig will be 7 characters longer but will look a lot cooler.
: plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
: z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
: *z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
: "RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
A bit shorter:
#macro L(P,C,R)light_source{P,rgb C rotate z*R}#end plane{-z,-3normal{crackle
scale.2#local a=5;#while(a)warp{repeat x flip x}rotate z*60#local a=a-1;#end
translate-9*x}pigment{rgb 1}}L(-9,x,60)L(-9,y,-60)L(9-z*18,z,0)L(-z*3,-.2,0)
text{ttf"arial.ttf""RP".1,0translate-<.6,.4,.02>pigment{bozo}}//Ron Parker
>: objects.
Good point. It just presents more challenge, right?
I'm starting to think I should create a script to randomly select one of my
(four, so far, counting this new one) signatures for each post.
Look, Ma, no commas, no #locals, and no #declares!
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}}#end Z(
-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90} // ron### [at] povray org
Still none of those things, and now with added highlights.
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
In article <slr### [at] fwi com>, Ron Parker says...
Smart!
I have the distinct feeling that I am lagging behind, somehow :(
Regards, Sander
I figured I'd post here rather than start another thread. I had to try
making my own. It's too long for a sig, but I was still pleased with the
result.
#version unofficial MegaPov 0.6;camera{location-z*8direction z*2look_at 0}
light_source{<-2,5,-2>*1e3 rgb1}%K=text{ttf"cyrvetic.ttf""KEVIN".25,0
translate-1.5*x scale 1.5}%G=pigment{rgb<.8,.6,.4>}%R=seed(0);#macro
B()<rand(
R)-.5,rand(R)-.5,rand(R)-.5>#end#macro
A(C)%T=0;%V=<0,1,0>;#while(T<250)%S=0;%
P=B();%U=trace(K,C,P)-C;#while(S<15)%P1=B();%W=trace(K,C,P1)-C;#if(vlength(W)
<vlength(U))%P=P1;%U=trace(K,C,P)-C;#end%S=S+1;#end%V=V+P;%V=V/vlength(V);%D=(
250-T)/1e4;union{cylinder{C,C+V*.03,D}sphere{C,D}triangle{C,C+B()*D*10,C+B()*D
*4
pigment{rgb<0,.7,0>}}pigment{G}no_shadow}%C=C+V*.03;%T=T+1;#end#end%N=0;
#while(N<35)A(<(rand(R)-.5)*3, 0, rand(R)/4>*1.7)%N=N+1;#end // Kevin
Wampler
Whoops, line wraps messed the formatting up, and I made a type too... Hopefully this
will be better
light_source{<-2,5,-2>*1e3 rgb 1}%K=text{ttf"cyrvetic.ttf""KEVIN".25,0
translate-1.5*x scale 1.5}%G=pigment{rgb<.8,.6,.4>}%R=seed(0);#macro B()<rand(
R)-.5,rand(R)-.5,rand(R)-.5>#end#macro A(C)%T=0;%V=<0,1,0>;#while(T<250)%S=0;%
*4 pigment{rgb<0,.7,0>}}pigment{G}no_shadow}%C=C+V*.03;%T=T+1;#end#end%N=0;
#while(N<35)A(<(rand(R)-.5)*3, 0, rand(R)/4>*1.7)%N=N+1;#end // Kevin Wampler
In article <3AFA277A.440A9AA4@u.arizona.edu>, Kevin Wampler says...
> Hopefully this will be better
<snip>
As far as I understand you are not suppose to have the actual characters
appearing in the sig!
It IS very nice, though, your sig :))
Regards, Sander
Kevin Wampler wrote in message <3AFA1C94.F93EB686@u.arizona.edu>...
So and I.
My current sig is fine but just for fun I realized next idea :-)
I must admit those all our sigs are very good lesson of povray and I think we
got small "testing compatibility for next versions" pack.
Here it is (don't worry I'm not the ghost):
#macro A(B,X)[1spherical color_map{[.5rgb 0][1rgb 19]}translate C*(X-B)+B+z*8]
#end light_source{0 1}plane{-z,-8pigment{average pigment_map{#local C=1;#while
(C)A(-4*x-y,y-3*x)A(y-3*x,-2*x-y)A(-4*x-y,-2*x-y)A(y-x,-y-x)A(2*y-x,x+y)A(x+y,
-x)A(-x,x-y)A(x-y,-2*y-x)A(2*x+y,4*x-y)A(4*x+y,2*x-y)#local C=C-.04;#end}}}
#macro Sig(A,B,X)_(A,B)_(B,X)_(X,A)#end#macro _(A,B)cylinder{<A.x,A.y,3>,<B.u,
B.v,3>.1,9}#end global_settings{max_trace_level 9}light_source{0 1}camera{up y
*4right-3*x}blob{_(<3,1>,<1,-5>)_(<2,-2>,<4,-2>)Sig(x,<-1,1.5>,<1,3>)_(z-1,z-4
)pigment{rgb 1}}box{-3 3pigment{rgb 0}finish{reflection 1}hollow} // POV-Ray31
: I'm starting to think I should create a script to randomly select one of my
: (four, so far, counting this new one) signatures for each post.
I think most newsreader have this kind of functionality already.
At least in tin, if you configure the signature path to point to a
directory (instead to a file), it will select a random file from that
directory.
I know, resurrecting an old thread... I just wanted to debut my new .sig,
because I think it's kinda cool. And it still has no #locals and no
#declares, though the commas proved intractable. To compensate, though,
this one has a loop with no #while. I'd love to see suggestions on how to
make this one shorter, even though I don't need them at this point.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)union{R(z+a z)R(-z a-z)R(
a-z*3 a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro S(g)9-(D-g)*(D
-g)#end#macro Z(D a T F)union{P(z+a)P(z-a)R(-z-z-x a)translate-10*y+D/10pigment
{rgb<S(7)S(5)S(3)>}}#if(D)Z(D-.2a,T F)#end#end Z(10x*-2x.2)camera{rotate x*90}
So of course I found some of my own...
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)union{R(z+a z)R(-z a-z)R(a
-z*3a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro S(g)9-(D-g)*(D-g)
#end#macro Z(D a T F)union{P(z+a)P(z-a)R(-z+y-1a)translate.1*D-y*8pigment{rgb<S(
Two characters:
-z*3a+z)torus{1F clipped_by{plane{a 0}}}translate z+V}#end#macro S(g)9-(D-g)*(D-
g)#end#macro Z(D a T F)union{P(a)P(-a)R(y-z-1a)translate.1*D-y*8pigment{rgb<S(7)
On 29 Jun 2001 18:06:37 -0400, Warp wrote:
> Two characters:
Thanks, I've adopted those two. The one was painfully obvious, wasn't it?
Any other takers?
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
a-z)R(a
S(g)9-(D-g)*(D-
Nice :)
Inspired, I've come up with this one:
media{emission rgb<2,3,4>absorption rgb<2,3,4>density{function{.1/(y+1)}}}#macro
P(d)pigment{checker rgb 6 translate d scale.15 rotate 45*y}#end#macro F(S,T,E,G)
box{<S,T,-.01>,<E,G,1>}#end camera{location<1,2,-3>look_at 0}sphere{y-x,1 finish
{reflection 1}}union{F(0,4,3,5)F(1,0,2,5)F(4,0,5,5)F(4,4,7,5)F(4,2,6,3)scale.35
rotate 90*x P(1)}plane{y,0 P(0)} // Tekno Frannansa. evilsuperbrain.com
It's kind of the reflective ball on checkered floor, but showing off more ;).
Obviously it's a bit long at the moment, so I was kind of hoping someone might
have some suggestions for shortening it, because I've run out of ideas (well,
it's 3 in the morning, I think my brain's given up!).
Cheers.
Tek
I can't render it. It seems to have an unsupported keyword in it. :)
Nonetheless, you can save some characters by just removing unnecessary spaces
after numbers and before keywords and/or symbols. So, for example,
"scale.15 rotate" becomes "scale.15rotate". That doesn't come anywhere near
making it small enough, of course.
<clip>
I got to admit I ran out and did the same thing after I saw Ron and Warps sigs.
I came up with this one...
light_source{-9 color rgb 1}#macro C(a)cylinder{-a.x*y,0,.1 rotate a.z*z
translate<a.y,0,6>}#end#macro V(a,b,c,d,e)torus{a,.1 clipped_by{plane{z,e}}
rotate b*90*x translate<c,d,6>}#end union{C(x-3*y)C(x-y*2)C(x-y*1.5)C(x-y)C(x+
y*3.45)C(.8*x-y/2)C(.8*x-.1*y)C(.8*x+.3*y)C(<2.5,-3,90>)V(.4,1,1,-.5,2)V(.4,1,
2,-.5,2)V(.4,1,3,-.5,2)V(.5,1,-2.5,0,0)V(.2,-1,-.3,-.7,0)V(.2,-1,.1,-.7,0)
pigment{rgb x+y}}
But that seemed too long, so I tried this.
light_source{<-9,9,-9> color rgb 1}#macro A(T E)cylinder{-T.x*y 0 .1 rotate 90*
T.z*z translate<T.y,E,4>}#end union{torus{.5,.1 clipped_by{plane{z,0}}rotate 90
*x translate<.5,0,4>}A(<1.5,-1.25,0> .5)A(x 0)A(x+y 0)A(x+z (-.25))A(<1.5,-2,1>
.5)pigment{rgb<1,.9,.2>}finish{phong.05 reflection.1}}
Which fit in 4 lines, but didn't look as nice. Then I figured I'd try again and got:
light_source{-10 color rgb 1}#local T=6*z-3*x;#local I=T;#local M=0;#local A=
array[10]{1287709,43035510,7312399,36346003,50603446,6192184,12772732,33037915,
41777870,42384480}union{#while(M<99)#local N=int(mod(A[div(M,10)]/pow(6,(9-mod(
M,10))),6));#local I=I+((N=0)-(N=1))*y/2+((N=3)-(N=2))*x/2;#if(N=4)sphere{T.1}
cylinder{T,I,.1}#end#local T=((N>3)?I:T);#local M=M+1;#end pigment{rgb x+y}}
Which is a bit long, but is obfuscated nicely. So I tried simple but nice..
light_source{<-9,9,-9>rgb x+y+z}text{ttf"timrom.ttf" // timothyea
"Tim Attwood".1,0 pigment{rgb x+y}translate<-2.7,-.3,5>}// @worldnet.att.net
sky_sphere {pigment{gradient y color_map{[.45 rgb<.2,.3,.2>][0.5 rgb x+y+z]
[0.55 rgb x+y][0.6 rgb x+.5*y][.7 rgb 0]}scale 2 translate -1}}
And that's perty and has the benefit of having my name all over it. Maybe I'll use
it again, but I also
came up with this one:
#macro T(I M)cylinder{0,I*x,.2 rotate 15*M*z translate A pigment{rgb E}finish
{ambient 1}}#end#macro Y(E O)#local A=y-x+O;T(1,0)T(2,18)T(1,12)#local A=x+y
+O;T(2,17)T(2,19)#local A=.7*x-.5*y+O;T(.6,0)#end#local D=seed(2);#local W=1;
#while(W<35)Y(rand(D)*z<9*rand(D)-5,9*rand(D)-5,9>)#local W=W+1;#end Y(1,4*z)
And that seemed perty good too. Which do you prefer?
Doh! That's because I used the "function" command. It works fine in Megapov,
which is perculiar because it shouldn't allow me to use unnofficial features
unless I have a #version at the start!
Anyway, here's a fixed version, though it doesn't look as good:
camera{location<1,2,-3>look_at 0}sphere{y-x,1#macro F(S,T,E,G)box{<S,T,-.01>,<E,
G,1>}#end finish{reflection 1}}#macro P(d)pigment{checker rgb 6translate d scale
.15rotate 45*y}#end media{emission rgb<.2,.3,.4>absorption rgb<.2,.3,.4>density{
planar poly_wave .1scale 9000}}union{F(0,4,3,5)F(1,0,2,5)F(4,0,5,5)F(4,4,7,5)F(4
,2,6,3)scale.35rotate 90*x P(1)}plane{y,0 P(0)}// Tekno Frannansa.
And for comparison, here's the original version (from before the 1st one I
posted), which is megapov only and uses radiosity:
#version Unofficial Megapov 0.7 global_settings{ini_option"+qr"radiosity{}}media
{emission rgb<2,3,4>absorption rgb<2,3,4>density{function{.1/(y+1)}}}#macro P(d)
pigment{checker rgb 6 translate d scale.15 rotate 45*y}#end#macro F(S,T,E,G)box{
<S,T,-.01>,<E,G,1>}#end union{F(0,4,3,5)F(1,0,2,5)F(4,0,5,5)F(4,4,7,5)F(4,2,6,3)
rotate 90*x scale.35 P(1)}plane{y,0 P(0)}camera{location<1,2,-3>look_at 0}sphere
{y-x,1 finish{reflection 1}} // TeknoFrannansa. evilsuperbrain.com
It looks nice, but it's way to long for a sig, and excludes anyone using normal
pov.
Tek
Tek <tek### [at] evilsuperbrain com> wrote:
: camera{location<1,2,-3>look_at 0}sphere{y-x,1#macro F(S,T,E,G)box{<S,T,-.01>,<E,
: G,1>}#end finish{reflection 1}}#macro P(d)pigment{checker rgb 6translate d scale
: .15rotate 45*y}#end media{emission rgb<.2,.3,.4>absorption rgb<.2,.3,.4>density{
: planar poly_wave .1scale 9000}}union{F(0,4,3,5)F(1,0,2,5)F(4,0,5,5)F(4,4,7,5)F(4
: ,2,6,3)scale.35rotate 90*x P(1)}plane{y,0 P(0)}// Tekno Frannansa.
It doesn't look 100% the same, but a bit shorter:
camera{location<1,2,-3>look_at 0}#macro P(d)pigment{checker rgb 6translate d
scale.15rotate 45*y}#end sphere{y-x#macro F(S,T,E,G)box{<S,T,-.01><E,G,1>scale
.35rotate 90*x P(1)}#end 1finish{reflection 1}}fog{rgb 1fog_type 2distance 2
fog_alt.5}fog{rgb<.2,.3,.6>distance 10}F(0,4,3,5)F(1,0,2,5)F(4,0,5,5)F(4,4,7,5
)F(4,2,6,3)plane{y,0P(0)}// Tekno Frannansa.
.35rotate x*90P(1)}...
Tim Attwood <tim### [at] worldnet att net> wrote:
: #macro T(I M)cylinder{0,I*x,.2 rotate 15*M*z translate A pigment{rgb E}finish
: {ambient 1}}#end#macro Y(E O)#local A=y-x+O;T(1,0)T(2,18)T(1,12)#local A=x+y
: +O;T(2,17)T(2,19)#local A=.7*x-.5*y+O;T(.6,0)#end#local D=seed(2);#local W=1;
: #while(W<35)Y(rand(D)*z<9*rand(D)-5,9*rand(D)-5,9>)#local W=W+1;#end Y(1,4*z)
A bit shorter:
#macro T(I M A)cylinder{0,I*x,.2pigment{rgb E*9}rotate M*z*15translate A}
#end#macro Y(E O)T(1,0,y-x+O)T(2,18,y-x+O)T(1,12,y-x+O)T(2,17,x+y+O)T(2,
19,x+y+O)T(.6,0,.7*x-.5*y+O)#end#local D=seed(2);#macro X(W)#if(W)Y(rand
(D)*z<9*rand(D)-5,9*rand(D)-5,9>)X(W-1)#end#end X(35)Y(1,4*z)
I like the last one.
/* Nekar Xenos */#local N=<-20,40,100>;#local K=<20,-40,100>;#local R=seed(0);
blob{#while((K-N).x>0)#local X=N;#local N=N+<rand(R),rand(R),1>/3;#local N=(
vlength(N-K)<vlength(X-K)?N:2*X-N);sphere{<N.y,-N.x,N.z>,1,1 scale .02}sphere{N
,1,1 scale.02}sphere{<-N.x-40,N.y,N.z>1,1 scale.01}sphere{<N.x+40,-N.y,N.z>1,1
scale.01 }#end pigment{rgbt 1}interior{media{emission <2,4,5>*5}}hollow}
