POV-Ray : Newsgroups : povray.general : mesh --> .pov with 3dwin Server Time
16 Jul 2025 06:54:58 EDT (-0400)
  mesh --> .pov with 3dwin (Message 1 to 3 of 3)
Subject: mesh --> .pov with 3dwin
Date: 17 Apr 2001 18:10:26
Message: <3ADCBFE8.F64A0973@gmx.de>
Hy,
I try to import a mesh of triangles (.raw) into povray. For that, I read
them into 3dwin4.6a and try to smooth them with modify object/smooth and
export as .pov with specific settings on (all) and udu/mdl out. Then I
render the .pov-file but the triangles are not smooth!! What am I doing
wrong in 3dwin???
Thanks
Subject: Re: mesh --> .pov with 3dwin
Date: 17 Apr 2001 21:12:54
Message: <3ADCEA48.A7B940EF@pacbell.net>
Ursula Theobald wrote:
> Hy,
> wrong in 3dwin???
There are a couple of things that will affect the smoothness of the
converted model. If the original is a low polygon count (blocky looking)
model even with smoothing applied there is only so much you can
expect from smooth_triangles in POV-Ray. The higher the resolution
of your original model the better your results are going to be in
POV-Ray.
If you have the smoothing 'angle' set too low your results will not
be as expected. I think the default smoothing angle in 3DWin is 70
but don't be afraid to try higher values. If you have it set lower
than 70 go higher. It does get to a point of no return so don't get
too carried away.
Ken Tyler
Date: 18 Apr 2001 15:15:03
Message: <3ADDE7CF.9D9753C9@inapg.inra.fr>
> Hy,
> wrong in 3dwin???
Are the triangles actually smooth (replaced with smooth_triangle{}) in the
resulting file ?
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
