POV-Ray : Newsgroups : povray.general : Any way to create variable turbulence? Server Time
12 May 2026 19:30:07 EDT (-0400)
  Any way to create variable turbulence? (Message 1 to 9 of 9)
Subject: Any way to create variable turbulence?
Date: 22 Mar 2001 09:07:24
Message: <3ABA1777.1010108@hlavacek-partner.cz>
I need to create turbulated pattern with amount of turbulence
dynamically changing, at the center of some circle I need zero
turbulence and at some distance from center I need turbulence 1.
Ideal will be some way to get turbulence value at some point from
another pattern.
Any way to do this? Or I will require coding?
Regards
Disnel
Subject: Re: Any way to create variable turbulence?
Date: 22 Mar 2001 09:21:12
Message: <3ABA0A53.C3C249F8@gmx.de>
> another pattern.
You can use a pigment_map, something like:
  spherical
  pigment_map {
    [0.0 bozo turbulence 1.0 ]
    [1.0 bozo turbulence 0.0 ]
Maybe use more pigment map entries with a while loop.
Rune has some examples for this technique on his site:
http://rsj.mobilixnet.dk/3d/goodies/goodies.html
Date: 22 Mar 2001 11:02:30
Message: <3ABA3271.5080508@hlavacek-partner.cz>
> pigment {
>   spherical
>   pigment_map {
I need it for curving rays from some point, at the point they should be
straight and at greater distance they should be randomly curved. When I
will use your pigment_map they will be chopped.
Disnel
Date: 22 Mar 2001 11:34:09
Message: <3ABA2982.B7265C7@gmx.de>
> > pigment {
> >   spherical
> >   pigment_map {
I don't really understand what you want to do, but the construction i
suggested makes a perfectly smooth pigment if you use a smooth color map.
Date: 22 Mar 2001 11:36:00
Message: <3ABA3A49.504@hlavacek-partner.cz>
Image descripbin the problem sent to p.b.i
Date: 22 Mar 2001 11:46:35
Message: <3ABA2C69.5B4437AB@gmx.de>
Seen it, just use more pigment map entries with a while loop like i
suggested:
  spherical
  pigment_map {
    #declare Inx=0.0;
    #while (Inx<=1.0)
      [Inx bozo turbulence 1.0-Inx ]
      #declare Inx=Inx+0.03;
Of course you can only use up to 255 entries right now.
Date: 22 Mar 2001 11:57:31
Message: <3aba2efa@news.povray.org>
Perhaps you could use pigment functions for this.
  That is, create two functions using two pigments (the same pigments but
with different amount of turbulence) and then interpolate between these
two functions as needed.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 23 Mar 2001 06:28:29
Message: <3ABB43B4.10301@hlavacek-partner.cz>
> suggested:
> pigment {
>   spherical
>   pigment_map {
>     #declare Inx=0.0;
>     #while (Inx<=1.0)
>     #end
Sure, but it is still an aproximation. I want use it in isosurface.
> Christoph
Date: 23 Mar 2001 06:36:04
Message: <3ABB3524.38B0FEA8@gmx.de>
That shouldn't be a problem, of course it would be quite slow.
Another possibility would be to use a displace warp, but that would
generate a quite different type of turbulence.
