Someone recently posted on here that a crash is always an error; that
the appropriate action for the program to take if there's something
wrong is to give an error message, not to crash. So I'm posting this
code, which makes POV do just that.
I am using POV-Ray, version 3.1g for Macintosh, on a G3/300 running OS
9.0.4, with 160mb RAM. I know code shouldn't normally be posted in this
group, but this is /really/ short, as I was looking at how height fields
work. I suspect my slopes are too abrupt or too confused, but here it
is. You can find the image I was using to create the height field at
<http://www.coyotesdaughter.com/dawn/newworld.gif>.
light_source { <0, 10, 0> White }
location <0, 3, 0>
look_at 0
} // close camera
height_field {
gif
"newworld.gif"
//smooth
pigment { Red }
Dawn McKnight | "Who cares what the hipbone's connected to? I'm in Neurology!"
McK### [at] mac com | -- Justine Devlin, M.D.
In article <3A2### [at] mac com> , Dawn McKnight <mck### [at] mac com>
Please check the POV-Ray documentation folder and fill out the bug report
form. then send this form to mac### [at] povray org
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
This is one of the oldest bugs that I know of. It has something
to do with the camera being at x+z = 0 while using look_at = 0.
i.e. -
location <0, 3, 0>
look_at 0
If you change it to something like -
location <0, 3, 0>
look_at <0,0, -0.01>
the crash will not happen. A divide by zero bug maybe ?
More specifically, the problem is caused by the camera's view direction
being parallel to the sky direction (e.g. location <3, -5, 1> look_at <3,
15, 1> should also cause the problem). When this occurs, POV-Ray is unable
to determine the up vector of the camera matrix, and the result is often a
program crash.
As Ken detailed, a work-around to avoid this is simply to shift the location
or look at so the view direction is not parallel to the sky direction, which
can also be done by specifying the sky or up vector of the camera directly.
Ken wrote in message <3A232B64.7E9DE15F@pacbell.net>...
>i.e. -
>camera {
> location <0, 3, 0>
> look_at 0
I've never had a problem with doing this. Is it something specific to a
particular version? I'm using POV-Ray for Windows 3.1e, all versions of
MegaPOV, many versions of the SuperPatch, all versions of UVPov since 4.0a,
and all versions of SkyPOV.
Mark
It used to be a problem in v2.2 and it happened in v3.0 for Windows.
It guess I have been so strongly influenced by this I doubt I ever
checked it out in v3.1.
"Dawn McKnight" <mck### [at] mac com> wrote in message
news:3A2### [at] mac com...
Well, there have been other suggestions, but, IIRC, hf's do sometimes crash
pov - the general solution is to move the camera slightly.
Dawn McKnight <mck### [at] mac com> wrote:
: Someone recently posted on here that a crash is always an error; that
: the appropriate action for the program to take if there's something
: wrong is to give an error message, not to crash.
I think that was me. And you are right. Povray should never crash, specially
when we are dealing with the camera location. If the camera location is
illegal, an error should be issued instead of just starting the rendering
and crashing.
I've only had this problem with heightfields.
Peter
http://hertel.no/bigone
4.0a,
Does the problem occur if you remove the hf? (put something else in scene to
avoid "no objects" warning).
The problem is that the Cartesian system of describing a 3dimensional space doesn't
allow for proper calculations when the
camera points straight down like that. The up vector goes from y to <0,0,0> and
rotations are mathematically impossible. I
don't have all the mathematical details here, but the calculations jump to infinity in
this situation. My brother works with
aerodynamics and he had to work around this by using quaternions.
Josh
> camera {
> location <0, 3, 0>
> look_at 0
> } // close camera
> height_field {
> gif
> "newworld.gif"
> //smooth
> pigment { Red }
eng### [at] spiritone com
On Mon, 27 Nov 2000 19:23:13 -0700, Dawn McKnight <mck### [at] mac com>
wrote:
<snip>
>camera {
> location <0, 3, 0>
> look_at 0
> } // close camera
I am almost certain this appears in the POV-Ray documentation. At
least I am certain I knew it long before I started frequenting this
server. Basically, when the direction vector is parallel to the y
axis, there's a high chance of a division by zero error. This happens
because the default sky vector is +y and POV gets confused when it
tries to determine the transformation matrix to apply to the camera.
Try moving the camera location or look_at just a bit (1E-6 in x or z
is enough), using an up vector of +z (yuck!) or just placing your
object in the xy plane instead of xz, and then using a more common
camera such as camera { location -3*z }
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
Another solution is to not use the look_at keyword
and instead use a direction statement in the camera
block and then rotate/translate the camera as needed.
This also allows more control of the camera.
location 0 // leave at 0 so rotation works as expected
direction <0, 0, 1> // look along the Z axis in the + direction
right <640/480, 0, 0> // change depending on output image dimensions
up <0, 1, 0>
rotate WHATEVER
translate WHEREEVER
Of course, right, up, and direction must be mutally perpendicular.
