POV-Ray : Newsgroups : povray.general : How are radiosity samples calculated? Server Time
26 Oct 2026 13:04:12 EDT (-0400)
  How are radiosity samples calculated? (Message 1 to 15 of 15)
Subject: How are radiosity samples calculated?
Date: 12 Nov 2000 20:04:50
Message: <3A0F3F54.4AA4250A@unforgettable.com>
A question for Nathan, or anyone else who knows...
I thought that radiosity works a bit like blurred reflection, shooting
out X samples in random directions to gather environmental information,
but I've been experimenting some more today and it seems like this may
not be the case.
So how *does* it work, exactly? And if it is like blurring, wouldn't an
option to shoot out rays which are evenly spaced over an area instead of
randomly-aimed produce smoother and more accurate results, assuming a
decently-large (say, at least a hundred) number of samples?
-Xplo
Subject: Re: How are radiosity samples calculated?
Date: 13 Nov 2000 03:58:56
Message: <3A0FAD74.E047F4AB@skynet.be>
Sorry, I can't answer to your question.  However, I have a suggestion..
Why not organise a "radiosity roundtable" ?  Let me explain : when
radiosity appeared in POV-Ray, the availiable computers made it very
slow, and thus difficult to master.  Slowly, people started to
understand how it sould be used to give good results, and realised
that the "right way" was quite different from what the docs said.
At one point, when our favorite sport was "rad without light source",
Nathan decided to modify the core code.  It worked ten times better
than before, but, still, people started making interesting discoveries
(you, TonyB, Gilles, and others), which again showed that the engine
was better than what the programmers tought !!  So, my suggestion is to
do some "comferences", where concerned people could publicly exchange
their views about how it works, how it acts, how it could work...
A detailed answer to your question could be a good starting point.
Of course, if it happens, it would be after the release of
POV-Ray 3.5...
Fabien.
Date: 13 Nov 2000 07:15:58
Message: <3a0fdb7e@news.povray.org>
Xplo Eristotle <inq### [at] unforgettablecom> wrote:
: I thought that radiosity works a bit like blurred reflection, shooting
: out X samples in random directions to gather environmental information,
: but I've been experimenting some more today and it seems like this may
: not be the case.
  Yes, it basically works like this.
  However, if it only did this, the rendering of any simple scene with
radiosity would take ages (eg. with 100 samples and recursion level 4 it
would take 4^100 times longer, ie. about 10^62 times longer; which means
that the Sun would die before the rendering is ready).
  I have to go to class right now but I'll explain a little bit more when
I return and nobody else has already done it.
Date: 13 Nov 2000 09:21:10
Message: <3a0ff8d5@news.povray.org>
As far as I have understood, the algorithm goes approximately this way
(Nathan, please correct me if I say anything wrong):
  The lighting values of the radiosity calculations are stored in a spatial
tree.
  When the lighting of a certain point is calculated povray first looks if
the point is close enough to a point in that spatial tree. If it is, then
it just takes some closest points in the tree (I think that the number
is specified with 'nearest_count') and calculates a weighted average of
their illumination values.
  If there isn't any point close enough, then it shoots lots of rays
in every direction (well, not in every direction but only through the
hemisphere which is defined by the surface normal vector). If the recursion
level is 1, then it just takes those values the rays hit. If the recursion
level is higher than 1, then it performs this same algorithm for each
intersection point.
  At the beginning the spatial tree is empty and thus the first rays will
take pretty long to calculate, but as the tree gets filled of values, less
samples have to be taken and more old sample values can be used.
  This is why even a deep recursion level will not explode the render time.
Date: 13 Nov 2000 14:12:42
Message: <3A103E50.2EF00DC7@unforgettable.com>
I was actually in the midst of putting together some webbable material
on low-error radiosity when it occurred to me to ask this question.
Won't be done for a while, though; I'm still making a demo scene, and
that takes a while to render (and eats more RAM than I can really give
it; low-error is pretty RAM-intensive).
-Xplo
Date: 13 Nov 2000 14:25:55
Message: <3A104164.6E04A307@unforgettable.com>
> tree.
> intersection point.
Okay, that sounds about right.
Here's what's bothering me, though: I have a small room with no
traditional lighting and a rad source (1/8th of a three foot radius
sphere with ambient 8 or so) in one corner, and the light it shines on
the far wall is decidedly splotchy, even with the nearest_count pumped
to 20 (the max) and the count cranked up to 600 (I really don't want to
go higher, as it's already slow enough, and *shouldn't* have to).
It occurs to me that if the radiosity algorithm is shooting out random
rays, then although they should average out, they may not be doing a
very good job of it, and I wonder if it would work better with some kind
of even distribution pattern.
It might be worth looking into other ways to tweak the algorithm as
well, but for now that sort of thing would be over my head.
-Xplo
Date: 13 Nov 2000 14:49:32
Message: <3A1045EE.E2DB4C35@skynet.be>
Someone did that :
 http://perso.wanadoo.fr/albedo/patchedpov.html
Fabien.
Date: 14 Nov 2000 00:07:47
Message: <3A10C842.DF544490@faricy.net>
Wouldn't this be 100^4, ie 10^8? Quite a bit different of a number...
Date: 14 Nov 2000 04:56:24
Message: <3a110c48@news.povray.org>
: Here's what's bothering me, though: I have a small room with no
: traditional lighting and a rad source (1/8th of a three foot radius
: sphere with ambient 8 or so) in one corner, and the light it shines on
: the far wall is decidedly splotchy, even with the nearest_count pumped
: to 20 (the max) and the count cranked up to 600 (I really don't want to
: go higher, as it's already slow enough, and *shouldn't* have to).
  The problem is that since your bright object is small, the rays sent
from each intersection point will hit it only rarely. This means that only
few of these points will be illuminated by that bright object while the
others are dark. This is what causes the splotchiness.
  You'll get a lot better result if you make that bright object shadowless
and add a light_source (possibly an area_light) in the middle of it.
Date: 14 Nov 2000 04:57:19
Message: <3a110c7f@news.povray.org>
David Fontaine <dav### [at] faricynet> wrote:
: Wouldn't this be 100^4, ie 10^8? Quite a bit different of a number...
  Oops, your are right... :)
Date: 14 Nov 2000 10:49:40
Message: <slrn912nom.5rv.ron.parker@fwi.com>
This made me think of something that may or may not be useful but would
certainly be an interesting idea to try (and if it works and is an
original idea, it might be a good thesis.  Maybe I should shut up. :) )
Anyway... what if the probability of a ray being shot in a given direction
is proportional to the brightness in that direction?
First, we need a way to determine an estimate of the amount of light
radiated by a given cube of arbitrary size.  This can be done by tracing
a few rays through the cube and averaging the brightness of the surfaces
they hit, using some sort of statistical method like the one used for media
method 1 to determine when enough we're confident in the results.
Take a cube that encloses the entire scene (this generalizes easily to a
box.)  Use this cube as an argument to a recursive routine that does the
following:
  Subdivide the cube into eight subcubes.
  Determine the brightness of each subcube and store the result.
  If the subcubes are smaller than a threshold, return immediately.
  If the variance in brightness over the eight subcubes is larger than a
    threshold, call this routine for each subcube.
This gives you an octree of intrinsic brightness values (i.e. brightness
resulting from ES*DL paths.)  Now you can repeat the process the routine
below and this 1-bounce octree to determine the illumination of the
surfaces, which will give you an octree of after-1-bounce (ES*DDL)
brightness values that can be used to do 2-bounce radiosity.  You may now
throw out the 1-bounce octree, because the 2-bounce version is more balanced.
Repeat until you reach the desired recursion level or until the new octree
looks sufficiently similar to the old one.
To determine the illumination of a surface (both while rendering and while
building new octrees) you need to fire a multitude of rays in random
directions just as before, but with the directions weighted.  To create a
random ray, use the top-level cube of the octree as an argument to the
following tail recursive routine:
  If there are no subcubes to the current cube, pick a random point in
    the current cube and fire a ray at it.
  Add up the average intensities of all eight subcubes (you should be able
    to just take the average intensity of the current cube and multiply by
    8.)  Pick a random number between zero and that sum and call it p.
  Traverse the subcubes in a predetermined order, subtracting the intensity
    of each subcube from p (and keeping the result as the new value of p.)
    When the value of p becomes negative or zero, use the current subcube
    as the argument to this procedure, then return immediately.
If the ray returned by this procedure is behind the illuminated surface,
keep it but give it a value of zero (if you just ignore it, you run the
risk of getting very few qualifying rays and causing your render time to
skyrocket.  Besides, if most of the illumination in the scene is behind
the surface, the surface won't be getting much illumination anyway.)
This method has three tunable parameters: the threshold at which a subcube
is divided, the minimum size of a subcube, and the maximum number of
recursions in the octree-building process.  The more precise these are, the
longer the octree-building process will run and the more precision will
be available in determining probability.
There is no requirement that the recursion level of the octree-building
process must match the recursion level of the intensity-determining
process.  Since the octree is used only to determine the probability that
a given ray will go in a given direction, it may be very coarse indeed and
still get okay results.  The extreme case is the current case, with the
entire octree consisting of exactly one cube of infinite size.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 14 Nov 2000 14:09:00
Message: <3A118EF0.809466D3@unforgettable.com>
I'm aware of that, but I really don't see any excuse for this much
splotchiness with that many samples. Even the bright areas near the
"light" are noticibly uneven, and unless someone has a better
explanation, I blame the sampling method; maybe it's not random enough,
so the generated numbers tend to repeat themselves and the results don't
average out as well as one might expect.
The light isn't even really that tiny; imagine a glowing beanbag chair
crammed in a ceiling corner of your bedroom and you have a fair idea of
the proportions of the scene.
-Xplo
Date: 15 Nov 2000 05:22:48
Message: <3a1263f7@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Anyway... what if the probability of a ray being shot in a given direction
: is proportional to the brightness in that direction?
  I suggested some time ago if it could be possible to tell to the
radiosity algorithm "this object is very bright so send more rays here".
  It could be another idea to think about (perhaps in addition to your idea).
Date: 15 Nov 2000 06:04:34
Message: <chrishuff-B871FA.06044815112000@news.povray.org>
In article <slr### [at] fwicom>, ron### [at] povrayorg
How would you do this?
Christopher James Huff
Date: 15 Nov 2000 09:14:54
Message: <slrn9156j3.6sa.ron.parker@fwi.com>
Third (original) paragraph of the post you replied to.
