POV-Ray : Newsgroups : povray.general : render direction Server Time
5 Nov 2026 12:58:12 EST (-0500)
  render direction (Message 1 to 23 of 23)
Subject: render direction
Date: 8 Nov 2000 22:12:40
Message: <3A0A1728.6DED2CB0@rsp.com.au>
Hiya folks,
Just for a laugh, has anyone thought of adding the option of which way
to render the image?
For example, bottom to top or right to left, instead of the regular top
to bottom starting at the left.
Once or twice i've thought it may be nice...
bep
Subject: Re: render direction
Date: 8 Nov 2000 23:49:23
Message: <3A0A2C86.CE4F5B02@faricy.net>
Ben Paschke wrote:
> Hiya folks,
YKYBRTTL...
Date: 8 Nov 2000 23:50:52
Message: <3A0A2D8A.8C3462CB@pacbell.net>
David Fontaine wrote:
> YKYBRTTL...
IHBRTTL...
Date: 9 Nov 2000 00:16:10
Message: <3A0A33FF.802E6A2B@club-internet.fr>
I was about to say the same....
PSP or Photoshop are here for that.
Fabien
> > YKYBRTTL...
> IHBRTTL...
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Date: 9 Nov 2000 00:57:56
Message: <3A0A3DE7.8E8231F0@rsp.com.au>
> YKYBRTTL...
what - when i need to see the last few lines of an image first? :)
yes, yes, render-subregion yada yada yada.
i said -first-, not -only-!
Lots of renderers dont start at the top left, some even start in the middle
and spiral outwards.
I tell you, it wouldn't be an altogether useless feature.
And yes, i have been raytracing too long.  far too long. there's no hope...
Date: 9 Nov 2000 01:47:06
Message: <3a0a486a@news.povray.org>
Ben Paschke wrote in message <3A0A1728.6DED2CB0@rsp.com.au>...
>Hiya folks,
I'm working on random-order rendering.
Mark
Date: 9 Nov 2000 02:15:39
Message: <3A0A501F.A9DF5605@rsp.com.au>
Allright! Woohoo!
Date: 9 Nov 2000 02:24:34
Message: <3A0A5196.EF786536@aetec.ee>
Ben Paschke wrote:
> Hiya folks,
Well, it's not for laugh, changing rendering order might speed up
rendering: if rendering is performed by buckets, lets say 32x32 pixels,
then renderer can take advantage of spatial coherence and use various
caching mechanisms more effectively. With current option (from left to
right) rays are hit all over the scene and almost all objects are being
hit during scanning one line, thus making cacheing less effective.
Perhaps this is not the issue with current implementation, but if
someone wants to implement true displacement mapping and use selective
surface division (only this bucket, which is hit, is displaced) to avoid
problems with memory, then this could give considerable speedup.
And with really large scenes, which require more memory, than available
(thus requiring use of swap space) it could be faster as well.
Date: 9 Nov 2000 06:57:03
Message: <chrishuff-CDB1EB.06570709112000@news.povray.org>
In article <3A0A33FF.802E6A2B@club-internet.fr>, Fabien HENON
What do PSP and Photoshop have to do with rendering order? Or raytracing?
Christopher James Huff
Date: 9 Nov 2000 07:27:18
Message: <3A0A9825.1E140DAE@erols.com>
Ben Paschke wrote:
> Hiya folks,
> top to bottom starting at the left.
  sky -y
  location MyCamLoc
  look_at MyCamView
Now stand on your head while rendering...
Date: 9 Nov 2000 12:34:17
Message: <3a0ae019@news.povray.org>
In article <3A0A1728.6DED2CB0@rsp.com.au> , Ben Paschke <ben### [at] rspcomau>
wrote:
> Hiya folks,
Changing the render direction will have noticable side effect if you are
using procedural textures like POV-Ray does.  I have posted two images of
the spotted.pov example scene that comes with POV-Ray.  One is rendered from
the top to the bottom, the other from the bottom to the top.
      Thorsten
e-mail: tho### [at] trfde
Date: 9 Nov 2000 13:32:31
Message: <3a0aedbf@news.povray.org>
Hi Thorsten!
Just courios: May I ask: How comes?
cukk
Date: 9 Nov 2000 14:06:17
Message: <3A0AF5A6.8D03B49D@spiritone.com>
That is very strange. Was this bottom left to upper right or bottom right to
upper left? I still don't undserstand why the order the rays are traced matter
so much. Any enlightenment?
Josh
> wrote:
> > Hiya folks,
>       Thorsten
eng### [at] spiritonecom
Date: 9 Nov 2000 16:42:23
Message: <3a0b1a3f@news.povray.org>
In article <3A0AF5A6.8D03B49D@spiritone.com> , Josh English
Very simple:  Procedural texture are based on pseudo-random number
generators.  While you get the same sequence for every render, you do not
get a reverse sequence when you render from bottom to top.
You would have the same problem with any other render algorithm that splits
up the image as well.  This is also one of the complicated issue when it
comes to making POV-Ray multithreaded or do network rendering of single
frames.
    Thorsten
Date: 9 Nov 2000 16:42:49
Message: <3a0b1a59$1@news.povray.org>
> upper left?
left to right for both.
Date: 9 Nov 2000 17:01:08
Message: <chrishuff-3AB02C.17011309112000@news.povray.org>
In article <3a0b1a3f@news.povray.org>, "Thorsten Froehlich"
I always thought this only affected FRAND(), and that patterns based on
Noise() would always give the same result for every point...hmm...
Date: 9 Nov 2000 18:35:51
Message: <3A0B34F2.1E7DF5E5@peak.edu.ee>
So how come you get the same pattern at different resolutions and with/without
AA, or when rendering only a subset of the image?
E.g. if I were to render a 480-line image by doing
(+SR480 +ER480), (+SR479 +ER479), ...
would I get a result different from a top-down render?
Margus Ramst
Date: 9 Nov 2000 19:50:59
Message: <3a0b4673$1@news.povray.org>
In article <3A0B34F2.1E7DF5E5@peak.edu.ee> , Margus Ramst
You are right, my explanation is wrong.  I should look into the code
first...
     Thorsten
Date: 10 Nov 2000 07:28:40
Message: <3a0be9f7@news.povray.org>
Mark Wagner <mar### [at] gtenet> wrote:
: I'm working on random-order rendering.
  Does it work with antialiasing?
  Does it work with interrupted renders?
  If radiosity is used, will the resulting image be identical from render
to render (if nothing is changed)?
  What about other features which use caches to use previously calculated
results (I think the crackle pattern uses something like this)?
  How much will it take memory?
Date: 15 Nov 2000 03:19:36
Message: <3a124718$1@news.povray.org>
Warp wrote in message <3a0be9f7@news.povray.org>...
It will do antialiasing as a second rendering pass.
Yes.
I don't know.  I haven't gotten it to a workable form.
It won't affect the results from the crackle cache, but in many cases will
slow down the rendering.
Hopefully, not much more than current rendering methods.
Mark
Date: 15 Nov 2000 05:19:40
Message: <3a12633c@news.povray.org>
:>  Does it work with interrupted renders?
: Yes.
  How?
:>  How much will it take memory?
: Hopefully, not much more than current rendering methods.
  How can this be possible if you have to keep the whole image in memory
(for example for the antialiasing pass)?
Date: 15 Nov 2000 16:19:23
Message: <ltu51t4i608plvl3gqrsb1dib5uut18ua1@4ax.com>
POV-Ray for Windows already does that when display is turned on.
Peter Popov ICQ : 15002700
Date: 16 Nov 2000 02:35:33
Message: <3a138e45@news.povray.org>
Warp wrote in message <3a12633c@news.povray.org>...
>: Yes.
>  How?
It stores the number of the last pixel computed in the comments section of
the image file, and uses the number of each pixel to figure out which pixel
to compute next.  This isn't true random order, it will just look random.
It won't need to.  It will store the image on disk, probably as a temporary
uncompressed TGA file.
Mark
