POV-Ray : Newsgroups : povray.general : modest problem Server Time
26 Oct 2026 13:01:55 EDT (-0400)
  modest problem (Message 1 to 20 of 20)
Subject: modest problem
Date: 2 Nov 2000 16:25:16
Message: <3A01DBB1.F6A1469D@ij.net>
I've had this before and faked it. The attached file has the only light
source at +Z and a camera at -Z. I can see the unilluminated side of the
sphere. Note all sources of reflections are commented out.
Always go through life a little bit hungry.
You never know when you might meet something edible.
	-- The Iron Webmaster, 139
Download 'us-ascii' (1 KB)
Subject: Re: modest problem
Date: 2 Nov 2000 16:43:46
Message: <chrishuff-71E179.16465202112000@news.povray.org>
In article <3A01DBB1.F6A1469D@ij.net>, Matt Giwer <jul### [at] ijnet>
Your indentation style is horrible. :-)
Also, "scale 1" doesn't do anything. And you use an image map...I
replaced it with "wrinkles color_map {[0 rgb 0][1 rgb 1]}" so I could
render the file.
I assume the problem is that you don't want to see the dark side of the
sphere? Give the sphere an ambient of 0. It is currently at 0.5, which
means the minimum illumination will be 0.5. You could also specify
ambient_light 0 in global_settings, this sets the ambient value of
everything in the scene to 0.
Christopher James Huff
Date: 2 Nov 2000 16:50:26
Message: <3A01E139.57CD995D@aol.com>
> finish {ambient .5}
Can't render it as you have it lacking the image map, but perhaps this is the
problem?
Date: 2 Nov 2000 16:51:55
Message: <3A01E1F5.B1D0A04@ij.net>
	Guilty as charged. Noodling around trying to correctly solve this
problem correctly.
> render the file.
	Playing with ambient is one of the ways of faking it. If there is no
illumination, why should anything be visible regardless of the ambient?
I just want things to behave according to the scene description.
	I have this image of the light reflecting off of the camera ...:)
Date: 2 Nov 2000 16:53:56
Message: <3A01E271.9B5205C6@ij.net>
MikeH wrote:
> > finish {ambient .5}
> problem?
	Stick in any image you have laying around. Put in a texture.
	How is it possible to see what is not illuminated?
Date: 2 Nov 2000 18:14:36
Message: <3a01f55c@news.povray.org>
"Matt Giwer" <jul### [at] ijnet> wrote in message
news:3A0### [at] ijnet...
... but that's the whole point of ambient. Its primary use is as a fake
radiosity - giving objects a visible colour when otherwise they would be in
pure shadow.
Time to rtfm?
Date: 2 Nov 2000 18:24:06
Message: <chrishuff-6D4B86.18271202112000@news.povray.org>
But there *is* illumination. You specified a 50% gray ambient lighting.
Think of it this way: there is a global ambient light source which
defaults to white. It has no direction or location, so it illuminates
the scene evenly, is not shadowed or shaded. The color of this light is
specified by the "ambient_light" keyword in global_settings. Textures
have an "ambient" component which specifies how much they are affected
by this ambient light, the two colors are multiplied together and the
result added to the illumination. The ambient_light keyword gives you a
way to globally change the ambient values, and the ambient finish
attribute allows you to control it on a per-texture basis.
Since the default is "ambient_light rgb < 1, 1, 1>", and you specified
ambient 0.5(which is the same as "ambient rgb < 0.5, 0.5, 0.5>"), what
you did is tell POV to add rgb < 0.5, 0.5, 0.5> to the illumination of
each point on the sphere.
Actually, the "ambient_light" keyword isn't even necessary, you can do
something like this:
#declare AmbLgt = color rgb < 1, 1, 1>;
    finish {
        ambient AmbLgt*0.5
However, variables may not have existed when ambient_light was added.
It is, I assure you. :-)
More like a fill light at the camera position that doesn't leave shadows
and isn't affected by the contours of the surfaces(no shading). Ambient
is actually intended as a quick-and-dirty way to simulate diffuse
illumination, light bouncing off of other objects, but radiosity does a
much better job of that. Since ambient light can be specified per-object
and is added to the ordinary illumination, it is often used to make
glowing objects.
Date: 2 Nov 2000 18:29:50
Message: <3A01F8AA.56E1D705@faricy.net>
Tom Melly wrote:
> Time to rtfm?
I think so...
Date: 2 Nov 2000 19:49:56
Message: <3A020BB2.1A7CFED7@ij.net>
> pure shadow.
> Time to rtfm?
	Oh. Guess so.
	It has always worked as though it were the purpose to make it seen
without a particular finish. Why read when it worked exactly as
expected? No excuse, Sir!
Here is the rule and read it clear, only the US government can
invoke god and no one else can.
	-- The Iron Webmaster, 167
Date: 2 Nov 2000 20:01:41
Message: <3A020F47.B09AA20D@hotmail.com>
Thats the Allman style
try an even worse style - Whitesmiths
or the tuxracer src for some v bad indentation
personally I like the K&R style
see  http://www.tuxedo.org/~esr/jargon/html/entry/indent-style.html for more.
Bye
Pabs
Subject: Re: modest answer
Date: 2 Nov 2000 23:48:56
Message: <3A0243B9.433B1C0E@ij.net>
I follow the rule of finish{ambient 0} and it looks very dark to dull.
To make it look halfway like the original image I have to go the
light_source as  rgb<1,1,1>*3 and *5 isn't that bad.
	OK, I am still missing something as that should not be necessary,
right?
	And if it is necessary, what am I missing regarding the consistant
nature of the scene language? Was ambient originally a hack?
	Attachment indented for the purist at heart. This is a side view that
will give essentially the effect I desire.
	BTW: congrats, I guess, to the developer of the type 1 mapping for
first converting the image to a square or whatever the trick was to
avoid the need for scaling a rectangular image to a sphere.
	And if you do not have a picture of the earth around to see the effect
it is simply the earth with a light and dark side and the shaded
transition from light to dark. Just stick in any image and look at the
lit hemisphere with *3 compared to *5 and see it is clearly less of half
than it should be.
If there is anything that makes life complicated it is
trying to find decisions other than pragmatic. We appeal
to gods to make life hard.
	-- The Iron Webmaster, 222
Date: 3 Nov 2000 02:41:40
Message: <3A026D49.26F83A45@unforgettable.com>
Matt Giwer wrote:
> If there is no
They *do* behave according to the scene description.
Ambient *is* illumination. It's directly added to whatever object(s) you
tell it to affect. In this case, since you've set the ambient of the
sphere to .5, the entire sphere is being illuminated by a constant,
directionless gray light. As someone else has mentioned, you could think
of it as "glowing".
If you were to shine a point light on this sphere, then every point on
the sphere would receive its normal illumination from the light, PLUS an
additional .5 from the ambient lighting.
This is one of the simplest concepts in POV-Ray, IMO. What part of it
*don't* you get?
-Xplo
Date: 3 Nov 2000 02:50:38
Message: <3A026F65.6F8CED9@unforgettable.com>
Try setting the sphere's diffuse to 1 (the default is .6, for some reason).
-Xplo
Date: 3 Nov 2000 09:56:59
Message: <chrishuff-12F744.10000703112000@news.povray.org>
In article <3A020F47.B09AA20D@hotmail.com>, Pabs <pab### [at] hotmailcom>
It looks like an Allman/K&R mix, but it has a bunch of spaces where they
shouldn't be, and some spots are missing spaces. But what I was really
referring to was the sphere at the end.
I tend to use a modified K&R style for POV code, and Allman style with
4-space indents for C/C++/ObjC. The K&R style lets me fit more POV
objects and code into view, which makes it easier to edit the scene, but
I find it easier to read C/C++/ObjC in Allman style.
Date: 3 Nov 2000 10:38:57
Message: <3a02dc11$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-12F744.10000703112000@news.povray.org...
Never had much time for the Altmans or Whitesnake myself, but R&B is cool.
BTW Shouldn't this be in O.T.?
Date: 3 Nov 2000 10:41:39
Message: <chrishuff-3C3A21.10444703112000@news.povray.org>
In article <3A0### [at] unforgettablecom>,
> reason).
The reason is that the ambient value is not 0 by default(I think the
default for ambient is 0.2), and scenes often have multiple light
sources. If it was 1 by default, everything would be washed out unless
you set your own value.
Date: 3 Nov 2000 21:47:24
Message: <3A0378BB.57824F08@ij.net>
	Increasing diffuse to 3 helps greatly.
Wilkomorski is a frigging liar but holohuggers
love him.
	-- The Iron Webmaster, 173
Date: 3 Nov 2000 22:55:07
Message: <3A0389B2.3363858A@unforgettable.com>
An rgb 1 light that hits an rgb 1 surface with a diffuse of 1 and an
ambient of 0 should produce pure white. The fact that you need to
"overcharge" the lighting simulation suggests to me that you're using
light fading, shining the light through a partially transparent object
or absorbing media, or using a very dark image as a texture. I can see
from the code that the first two aren't the case, so I suspect it's the
third one.
-Xplo
Date: 4 Nov 2000 19:43:55
Message: <3A04AD4B.FA3B6C07@ij.net>
> *don't* you get?
	Because when I have used it other times it has always appeared to work
as though it were simply reflecting more of the illumination so there
was never a reason to Read The Fine Docs.
Live fast, love well, and have a glorious website.
<a href="http://www.giwersworld.org/mgiwer/">
The rest of Matt Giwer's World</a>
	-- The Iron Webmaster, 61
Date: 4 Nov 2000 20:13:49
Message: <3A04B44C.A3AA821A@ij.net>
> third one.
	In POV binaries I am posting the results of diffuse 1 2 and 3 in Sub:
pov.general ambient v diffuse
