POV-Ray : Newsgroups : povray.general : question: need 2 curve memory req's for scene... Server Time
26 Oct 2026 13:06:58 EDT (-0400)
  question: need 2 curve memory req's for scene... (Message 1 to 8 of 8)
Subject: question: need 2 curve memory req's for scene...
Date: 29 Oct 2000 01:10:08
Message: <39fbb130@news.povray.org>
I'm using an image AS a heightfield in several different places within a
scene.
Each time I use it..I must read it in...each time I do..it requires more and
more
memory...  Any way to read ONCE...and then assign something to it?
I guess the equivalent would be a pointer C/C++
This is used to create my RUG on the floor...
height_field { png "E:\Gizmo-sick\ceiling2.png" // smooth
                 scale <4, .19, 2>
                 texture { Carpet scale .7 finish { ambient .5 } }
                 rotate <180, 0, 0>
                 translate < -3.2, -0.809, 7.2> // Center around origin
Now...to create my ceiling...I use the same image...
height_field
  png "ceiling2.png"  smooth
  rotate z*180 //flip it over so the points are facing the floor
  translate <0.5, 103, -0.5>
  scale <39.0, 0.06, 30.0>
   texture  { pigment { White } }
    I would rather not have to duplicate this image map
in memory if I could avoid it...anybody have any ideas????
                        Thanks
                       Johnny
Subject: Re: question: need 2 curve memory req's for scene...
Date: 29 Oct 2000 01:48:34
Message: <39FBC845.A7362BB5@schunter.etc.tu-bs.de>
> scene.
> more
Just declare it and use a reference each time:
#declare HF=height_field { png "E:\Gizmo-sick\ceiling2.png" }
object {
    HF
    scale <4, .19, 2>
    rotate <180, 0, 0>
Date: 29 Oct 2000 02:11:28
Message: <39fbcda0@news.povray.org>
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in
message news:39FBC845.A7362BB5@schunter.etc.tu-bs.de...
within a
> > scene.
and
> > more
> object {
>     HF
>     scale <4, .19, 2>
>     rotate <180, 0, 0>
        But every time I use it..in otherwords...I write  object { HF }
it will load ANOTHER copy right?  Meaning..for each oject...
the memory requirements will double...
I guess what I'm trying to say is there is no way to get/force povray
to only load ONCE the image  "E:\Gizmo-sick\ceiling2.png"
and then all subsequent uses refer to that ONE instance only?
                                        Johnny
Date: 29 Oct 2000 02:42:41
Message: <39FBD4F1.59642C40@schunter.etc.tu-bs.de>
No :-)
Just try it out and have a look at the memory stats
Date: 29 Oct 2000 08:15:53
Message: <ijhnvsg13q8iditfg11fnq31rk9omj4qfg@4ax.com>
On Sun, 29 Oct 2000 00:07:42 -0500, "Johnny Smith"
>scene.
>more
Try declaring it and then reusing it. Meshes work this way but whether
this holds for HFs I can't say right now. Do a test and see.
As a side note, if using pre-declared HFs indeed makes copies of them,
would it be too hard to make POV do it the mesh way?
Peter Popov ICQ : 15002700
Date: 29 Oct 2000 09:23:43
Message: <39FC3323.6804C47A@pacbell.net>
> >scene.
> >more
It already does. I have used multiple (1000's) of HF's in a single scene
that used very little memory.
Date: 30 Oct 2000 17:01:52
Message: <bs5qvsgn2nifhcmadmiet21bkdndcfsjuv@4ax.com>
I guessed that much but I really had no time to test it, thanks Ken.
Date: 30 Oct 2000 23:23:15
Message: <39fe4933$1@news.povray.org>
#declare HF = height_field { .... }
    This worked by the way...
declared it ONE time...made all refernences to it as:
object { HF  translate<. . .>  rotate <. . .>  etc }
Memory requirements dropped by 1/2.
(50+meg to 25+ meg)
