POV-Ray : Newsgroups : povray.general : Help with isosurface intersection needed Server Time
25 Aug 2025 18:58:02 EDT (-0400)
  Help with isosurface intersection needed (Message 1 to 5 of 5)
Subject: Help with isosurface intersection needed
Date: 9 Oct 2000 09:22:43
Message: <39e1c6a3@news.povray.org>
Hi all,
This is the first time I've used the isosurface function, and things aren't
behaving as I thought they would.
Using the code below, if I simply render the isosurface, I get a sphere with
the pattern all the way through, which is what I want.
However, when I use the isosurface within a CSG intersection, all (or most)
of the insides disappear, and the effect is similar to simply using a
color_map with filter...which is NOT what I want.
Am I doing something wrong, or is it impossible to achieve the effect I'm
after? I wa under the impression that isosurfaces could be used without
problems in CSG's.
Thanks,
Andy Cocker
#declare tex1=
pigment { crackle color_map {[0 rgb 1][0.25 rgb <1,.6,.47>][0.5 rgb
<.2,.7,.9>][0.75 rgb <1,.916,.6>][1 rgb <.2,.7,.9>]}}
finish {  ambient 0 }
scale 0.5
#declare rad=0.4;
#declare X=
merge {
cylinder { <-2,0,0>,<2,0,0>,rad}
cylinder { <0,-2,0>,<0,2,0>,rad}
sphere {<-2,0,0>,rad}
sphere {<2,0,0>,rad}
sphere {<0,2,0>,rad}
sphere {<0,-2,0>,rad}
sphere {<-2-rad*.5,0,0>,rad/2}
sphere {<2+rad*.5,0,0>,rad/2}
sphere {<0,2+rad*.5,0>,rad/2}
sphere {<0,-2-rad*.5,0>,rad/2}
sphere {<0,0,0>,rad*1.5}
#declare Func =
function {
    pigment {crackle turbulence 0 color_map {[0 rgb 1][0.25 rgb 0][0.5 rgb
1][0.75 rgb 0][1 rgb 1]}}
#declare Main=yes;
#if (Main)
intersection {
isosurface {
    function {Func(x, y, z)}
    threshold 0.5
    contained_by {
         sphere {<0,0,0>,4 }//box {<-4,-4,-4>, < 4, 4, 4>}
    texture {tex1}
    scale 0.5
object {X texture {tex1}hollow}
rotate z*45}
Subject: Re: Help with isosurface intersection needed
Date: 9 Oct 2000 09:44:36
Message: <39e1cbc3@news.povray.org>
BigCeef <big### [at] mariner9fsnetcouk> wrote:
: object {X texture {tex1}hollow}
  Just curious: Why did you use a media keyword (ie. 'hollow') here?
  (Removing it doesn't fix the problem but I'm just curious.)
Date: 9 Oct 2000 11:49:32
Message: <39e1e90c@news.povray.org>
HI Warp,
I was just clutching at straws...I thought it might possibly fix the
problem, but it didn't, and I forgot to remove it before posting the code.
news:39e1cbc3@news.povray.org...
Date: 9 Oct 2000 15:19:05
Message: <39E21A29.E58FB8DD@datacomm.ch>
Just set 'max_trace 5' in your isofunction. I haven't tested it now but
I think this should do it. (See MegaPOV Docs 5.2.5 CSG-Operation).
> #if (Main)
> intersection {
> isosurface {
>     threshold 0.5
-->    max_trace 5
>     contained_by {
>     texture {tex1}
>     scale 0.5
> rotate z*45}
> #end
 email:                      mic### [at] michavirtualavenet
 visit my homepage:          http://micha.virtualave.net
 POVRay Objects Collection:  http://povobjects.keyspace.de
Date: 9 Oct 2000 17:23:14
Message: <39e23742@news.povray.org>
Thanks very much Micha, I shall give that a try.
Andy Cocker
"Micha Riser" <mri### [at] datacommch> wrote in message
news:39E21A29.E58FB8DD@datacomm.ch...
> > #if (Main)
> > intersection {
> > isosurface {
> >     threshold 0.5
> -->    max_trace 5
> >     contained_by {
> >     texture {tex1}
> >     scale 0.5
> > rotate z*45}
> > #end
