In the fisheye camera type I'd like the confinement to a circular area to be
optional. I think that would make it a much more useful camera type.
This suggestion is not meant for any specific version of POV-Ray.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated July 23)
/ Also visit http://www.povrayusers.org
Rune <run### [at] iname com> wrote:
: In the fisheye camera type I'd like the confinement to a circular area to be
: optional. I think that would make it a much more useful camera type.
Are you sure the function used to calculate it allows this?
I wouldn't be surprised if the function uses a square root of a value
which is negative outside that circular area.
"Warp" wrote:
> : circular area to be optional. I think that would make it
> : a much more useful camera type.
Yes, because it is already possible in an indirect way.
If you want to get rid of the circular confinement do this:
Render your image with double angle and in double resolution and use these
command line settings:
+sc0.25 +sr0.25 +ec0.75 +er0.75
Tada!
And I *have* tested it. It really is the same down to pixel level.
However, it's a bit tedious to remove the unused part of the image,
especially for animations. That's the reason I would like the confinement to
simply be optional. *I* wouldn't be surprised if it is very easy to do.
Rune
\ all be found at http://rsj.mobilixnet.dk (updated August 7)
"Rune" <run### [at] iname com> wrote in message
news:39ce4f6c@news.povray.org...
That's simply a image formatting thing, nothing to do with the ray trace
itself anyway. So the actual fix that could work is to somehow expand the
partial render to fit the full resolution by predicting a field of view.
Then you lose part of the fisheye field. If wanting a complete 360 degree
field shown as rectangular that requires greater than 360 degree field...
how can that be done then?
It would have limitations anyhow.
Wasn't there a fish eye camera patch out there that filled the whole screen?
I made a spherical camera that is capable of capturing the whole scene from the
viewpoint of the camera in a single rectangular image. It's a little different
than the fisheye but is the only camera type that I know of that can fill the
entire frame with a 360 FOV. The patch is in MegaPOV.
-Mike
I know of your patch, but I believe there was another.
> | and use these command line settings:
> ray trace itself anyway.
I completely disagree. My example was just meant to show that the mapping
type in itself can indeed produce images without the circular confinement.
The actual fix will be much more simple.
> field of view.
That would be crazy. Don't tell me a completely new method is needed to
obtain result that are completely similar except for some black pixels in
the corners. I'm sure that removing the circular confinement will be really
easy; probably it'll be about removing some code rather than adding some.
Making it optional will require a bit more work probably but I'm sure that
would be rather easy too.
> If wanting a complete 360 degree field shown as rectangular
Since when has angles greater than 360 degrees been a problem? Read the
documentation.
Exactly what is that statement based on? Facts? I don't think so.
Indications? I don't see any. To me it is obvious that it would actually
have no limitations at all. It even works perfectly with the clumsy method I
provided.
Rune
Ultra Wide Angle should be close to fisheye, and it fills the full Rectangular
area. I haven't looked at the formulas, but the docs point that out.
Johs
> Rune
eng### [at] spiritone com
> full Rectangular area. I haven't looked at the formulas, but
Maybe they look rather similar when the angle is shallow, but then, most of
the different camera types do. Ultra Wide Angle is a completely different
camera type than fisheye.
Greetings,
Rune
news:39cf6b29@news.povray.org...
| documentation.
I was just trying to go on one simple thought about it, I haven't checked
into any of it. What I was saying is that if there were a fisheye
projection (for lack of a better word) having rectangular boundaries then
your solution would be using a angle going to the corners not the sides.
That means loss of field of view for a fraction of the whole intended by a
given angle in the camera, ie. 360 is seen only at the corners of a square
aspect resolution and not the sides. Clipped.
I
| provided.
I would guess it's all in how such a thing would be implemented.
I keep telling everybody I *know* I found a patch to the fisheye camera that
filled the whole rectangle on the 'Net once, but I'm been looking high and
low and don't see it any more. I believe the demo images showed a chess set.
"Bob Hughes" wrote:
> What I was saying is that if there were a fisheye projection
> having rectangular boundaries then your solution would be
No, the angle keyword should control the horizontal angle as always, not the
diagonal angle.
> whole intended by a given angle in the camera, ie. 360 is
> seen only at the corners of a square aspect resolution
No, there would not have to be any clipping. It would be like this:
The areas that are currently black would not be black anymore.
It really can't get anymore simple than that.
To see what I mean, look in povray.binaries.images
I can't argue against that. They could always choose to implement it in a
strange way.
Rune
> fisheye camera that filled the whole rectangle on the
> 'Net once, but I'm been looking high and low and don't
> see it any more.
That's a shame! :-(
Rune
