Err, this is getting confusing!
I posted a message before without a subject (by accident) and now
it's disappeared. Then I reposted without the text. Then I posted
again without the subject.
Anyhow, I was using Mike Houghs patched version of MegaPOV
(the one he used for his flower image) and I got a message telling
me that GIF images will no longer be supported because of
legal issues. This hasn't happened with my regular version of
MegaPOV 0.5. Does anyone know anything about this? Is
this for sure about no GIF support?
- Doug Eichenberg
http://www.getinfo.net/douge
dou### [at] nls net
MegaPOV 0.5a removed gif support & there were several threads discussing
this in p.g, p.o-t & p.u.p
Nathan explained the reasons at the time but basically (as I understand
it) he (as a hobbyist) cannot afford the $5K the patent owners of the
LWZ compression algorithm are demanding for its use whether or not the
en/decoding algorithm is part of free software or not. The fee also
seems to apply to people having gifs on their web sites.
GIF is an old format that (in many peoples opinions) has been
superseeded by png
Most people don't like software patents and cripplingly expensive
software & so a GIF boycot has been started - see
http://burnallgifs.org/
Bye
Pabs
goto http://www.s11.org
change your images to png (without optimized palette in order to keep
your current palette) and then do a search/replace to find all gif
references in your pov files and change them.
> - Doug Eichenberg
> dou### [at] nls net
>superseeded by png
Believe it or not, this is the first I've heard of it. If that's the
way they're gonna be then good riddance, who needs GIFs!
Doug Eichenberg
dou### [at] nls net
I love that lossy grainy compression and unnecessarily big file sizes! I love
GIF!
David Fontaine <dav### [at] faricy net> ICQ 55354965
Please visit my website: http://davidf.faricy.net/
Seriously how did you miss it? - have U never tried to use gifs in MP0.5a
before now?
> If that's the way they're gonna be then good riddance, who needs GIFs!
Absolutely no-one png is better anyway
Hey U have gifs on your pages
http://www.getinfo.net/douge/portfolio.htm
http://www.getinfo.net/douge/miscart.htm
http://www.getinfo.net/douge/linkpage.htm
Care to convert them to pngs using gif2png?
win console version at http://pegasus.uni-paderborn.de/enno/burnallgifs/
more (newer) versions at http://www.tuxedo.org/~esr/gif2png/
or http://exe2bin.com/gif2png-win32/
Bye
Pabs
PS see http://lpf.ai.mit.edu/Patents/Gif/Gif.html for a better discussion of
the issue
Bye
Pabs
Okay, here's where it gets weird then. I just ran the code in my regular
version of MegaPOV 0.5 with a GIF image for my heightfield and
it worked. Import the same code into Mikes patch and I get the
error. Am I missing something?
- Doug Eichenberg
dou### [at] nls net
"Doug Eichenberg" <dou### [at] nls net> wrote in message
news:39beeb2e@news.povray.org...
At a guess and iirc, you're using mp 0.5 (which afaik supports gifs). It is
mp 0.5a that doesn't support gifs. Mike's patch is presumably based on mp
0.5a.
In article <39BEB06E.2516AF32@faricy.net>, David Fontaine
>love GIF!
GIF, used correctly, is not a lossy format, nor does it have
unnecessarily big file sizes. If the image has less than 256 colors, GIF
preserves the colors completely; as the number of colors drops, the
likelihood that GIF will be much smaller than JPEG increases.
See http://cerebus.acusd.edu/GIFJPG/ for an example of an image that is
either 10 times as big as a JPEG than as a GIF, or is only 3 times as
big but much lower quality.
PNG is even better, but PNG support in web browsers is still lacking,
especially when it comes to transparency and simple animations.
(Also please note that I support the authors of software such as MegaPOV
and GD removing GIF support from their creations.)
Jerry
blah, blah, blah =)
Jpeg's not that great either. And most of the compressors for jpeg aren't
very good.
Exactly, PNG is the greatest!
Good.
Jerry <jer### [at] acusd edu> wrote:
: If the image has less than 256 colors, GIF preserves the colors completely
Less or equal.
