POV-Ray : Newsgroups : povray.general : Test for vector <0,0,0> Server Time
25 Aug 2025 23:06:54 EDT (-0400)
  Test for vector <0,0,0> (Message 1 to 9 of 9)
Subject: Test for vector <0,0,0>
Date: 2 Sep 2000 08:23:57
Message: <39b0f15d@news.povray.org>
I see many people use
#if ( Vector.x=0 & Vector.y=0 & Vector.z=0 )
and
#if ( Vector.x!=0 & Vector.y!=0 & Vector.z!=0 )
I personally find it much simpler to use
#if (vlength(Vector)=0)
and
#if (vlength(Vector)!=0)
I just thought I'd share it with you.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated July 23)
/ Also visit http://www.povrayusers.org
Subject: Re: Test for vector <0,0,0>
Date: 2 Sep 2000 08:40:13
Message: <39B0F580.685093C0@schunter.etc.tu-bs.de>
> and
> and
> Rune
If you consider speed optimization, how about:
#if ( abs(Vector.x)+abs(Vector.y)+abs(Vector.z)=0 )
I don't know how fast povray calculates vlength(), but in regular programming
this would probably be faster, because vlength() would have to use
multiplication and sqrt().
Date: 2 Sep 2000 09:07:03
Message: <39b0fb77@news.povray.org>
programming
I was not thinking about speed, only what was easier to type.
But I made a speed test, and surprisingly it showed that using vlength()
is quicker than both of the two other methods! At least on my computer...
// Speed test
#declare C = 0;
#declare S = seed(0);
#while (C<100000)
   #declare V = <rand(S),rand(S),rand(S)>*4-2;
   // #if (V.x=0&V.y=0&V.z=0) #declare D = 0; #end // 119 seconds
   // #if (abs(V.x)+abs(V.y)+abs(V.z)=0) #declare D = 0; #end // 121 seconds
   #if (vlength(V)=0) #declare D = 0; #end // 113 seconds
   #declare C = C+1;
sphere {-z, 0.1 pigment {color 0}}
Greetings,
Rune
Date: 2 Sep 2000 10:23:40
Message: <39B10CF1.42249F5C@mindspring.com>
> > and
> > and
> > Rune
Maybe I'm missing something here, but this isn't going to work.  All you're doing
is adding up the vector components.  Yes, it will be true for the zero vector,
but it will also be true for vectors like <2, -2, 0> and <3, 2, -5>, etc.
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Kevin Jackson-Mead
http://www.mindspring.com/~jacksonmead
Date: 2 Sep 2000 10:27:20
Message: <39b10e48@news.povray.org>
quicker parse?
Date: 2 Sep 2000 10:30:25
Message: <39B10F99.5D686CA6@geocities.com>
> > > and
> > > and
> > > Rune
Almost, but....
As you can see, he used the abs, so those vectors you mentioned would turn into <2,
2, 0> and <3, 2, 5>, which would still pass his test.
Date: 2 Sep 2000 10:35:33
Message: <chrishuff-A3FA04.09371002092000@news.povray.org>
In article <39B10CF1.42249F5C@mindspring.com>, Kevin Jackson-Mead
> you're doing is adding up the vector components.  Yes, it will be
> true for the zero vector, but it will also be true for vectors like
Wrong. The vector < 2,-2, 0> will add up to 4, and < 3, 2,-5> will add
up to 10. That is what the abs() function is for, it gets the absolute
value of the number.
Christopher James Huff
Date: 2 Sep 2000 10:37:50
Message: <39B11043.1CA96F3B@mindspring.com>
I knew I was missing something.  That's what I get for trying to post on a
Saturday morning.  Man I feel like such a tool.
Kevin Jackson-Mead
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 2 Sep 2000 11:53:50
Message: <chrishuff-C64FE6.10552802092000@news.povray.org>
In article <39b0fb77@news.povray.org>, "Rune" <run### [at] inamecom>
You could just make a vNull() macro to make it even easier to type, and
more obvious exactly what you are doing.
Though vlength() does 3 squares and a sqrt(), it does them internally,
in native C. Using the comparison method, each comparison has to be
parsed separately, which is slower.
