POV-Ray : Newsgroups : povray.general : INC questions Server Time
26 Aug 2025 01:14:37 EDT (-0400)
  INC questions (Message 1 to 4 of 4)
Subject: INC questions
Date: 23 Aug 2000 07:15:19
Message: <39a3b247$1@news.povray.org>
Two questions regarding .inc files:
1. Is there any way to make an include file automatically detect whether it
was called or not? In my case I have an include file/macro that will
generate a bolt of lightning. I would like the file to generate an sample
scene if run directly, but not when called (without the user having to
set/change a variable).
2. Would I post such a macro to scene-files or utilities?
Subject: Re: INC questions
Date: 23 Aug 2000 10:43:59
Message: <39A3E358.D37B8ADB@schunter.etc.tu-bs.de>
I don't see any way without modifying the scene file, but the modification is
quite simple:
#declare No_Sample = true;
#include "incfile.pov"
And the incfile.pov with
#if (No_Sample)
   [sample code]
scene-files IMO, because utilities is for seperate programs (no pov-code)
Date: 23 Aug 2000 11:21:25
Message: <chrishuff-3FDE64.10224923082000@news.povray.org>
In article <39a3b247$1@news.povray.org>, "Tom Melly"
> whether it was called or not? In my case I have an include file/macro
> that will generate a bolt of lightning. I would like the file to
> generate an sample scene if run directly, but not when called
> (without the user having to set/change a variable).
Well...maybe only produce the scene file if none of the variables are
set. This won't work for macros, though.
Maybe call an Init() macro after including the file to set up variables
and turn the example scene off.
Or maybe have a variable telling the include which sample to use...if
not declared, no sample would be used.
Anyway, in my opinion, it is a much better idea to have separate
examples. It won't be any harder to do, and it will be easier on the
user and anyone trying to understand either the examples or the utility.
And it allows multiple samples.
Scene-files. The povray.binaries.utilities group is for stuff not
written in POV-Script, and the povray.*.scene-files groups are really
for any POV-Script files or code snippets.
Christopher James Huff
Date: 24 Aug 2000 05:00:55
Message: <39A4E415.7A68C080@buckosoft.com>
I always do at the top of a file:
#ifndef (True)
  #declare True=1;                        // So whoever is parsed first will declare
True and generate a camera.
  #declare False=0;
  #declare TestThisObject=1;              // flag to generate a test object at the
bottom.
  #declare my_other_constants...;         // usually turn on dummy textures or what
not.
  #include "other_objects.inc"            // whatever other objects i am testing with.
  camera { location here look_at there }  // generate a test camera
#declare ThisObject=
union {
// And then at the bottom of the file i put:
#ifdef (TestThisObject)
object {ThisObject}
dik
