POV-Ray : Newsgroups : povray.general : Toughts about texturing system Server Time
5 Nov 2026 16:22:57 EST (-0500)
  Toughts about texturing system (Message 1 to 39 of 39)
Subject: Toughts about texturing system
Date: 3 Oct 2000 07:57:17
Message: <39D9C88D.C0ABE99D@skynet.be>
I recently had some toughts about POV-Ray's texturing system, and tried
to point out some incoherences and suggest some remedies.  Please note
that I'm not whining, or requesting anything.  These are just toughts
for a possible future.  Read it, keep it, throw it, as you feel.
Here's the first of these toughts.
FINISH - Change in material structure
 What's wrong with "finish"* ?  "finish" is at the same hierarchic level
as
"pigment" and "normal", though it works very differently.  "pigment" and
"normal" require a pattern and a map, while "finish" just has some
keywords.
 Of course, "finish" could get some "finish_map", but since, anyway, a
pattern isn't *required*, it's still incoherent with "pigment" and
"normal".
 So, my idea is to put "finish" at the same level as "texture", and
create
a "surface" entity to group both.  Also, this require that, inside the
"finish" statement, finish properties are also grouped into separate
entities.  Given the recent growth of the "finish" content (thanks to
MegaPOV), having all the keywords 'thrown' in a single statement became
annoying.  This would, of course, allow the declaration of the finish
items : finish {reflection {Mirror1} highlights {VeryShiny} ..}
(*note to Warp : I didn't say 'What's wrong with Finnish ?' ;-))
Here is the proposed material structure :
material {
          surface {
                   [pattern - surface_map]
                            [pattern - texture_map]
                            pigment {..}
                            normal {..}
                   finish {
                           [pattern - finish_map]
                           reflection {type .. min .. max .. exponent
                           highlights {phong .. specular .. blinn ..}
                           iridescence {irid .. thickness ..}
                           light {ambient..  brilliance ..}
          interior {
                   refraction {..}
                   media {..}
Subject: Re: Toughts about texturing system
Date: 3 Oct 2000 09:12:24
Message: <39d9db38@news.povray.org>
Hello,
Very well put.
I like your ideas, and agree that the nontrivial complexity inherent to
complete declaration of materials was implemented here-to-fore in a vexing
and insipid manner.
I intend not to bash Pov-Ray, but to state as the growth of the program has
increased, old methods of handling things must be changed.
This vast syntax alteration will cause many incompatibilities, but is
logical relative to the present form.
ian
Fabien Mosen wrote in message <39D9C88D.C0ABE99D@skynet.be>...
>material {
>          surface {
>                   texture {
>                            pigment {..}
>                            normal {..}
>                   finish
>          interior {
>                   refraction {..}
>                   media {..}
Date: 3 Oct 2000 13:01:35
Message: <39da10ef@news.povray.org>
Shudder... I *guess* I could adapt... if it's for the best...
Date: 3 Oct 2000 13:24:52
Message: <39DA155F.AC8F0E0A@skynet.be>
If a change is made towards something that is more logical, it's
easy to get used to it.  "ior" going from "finish" to "interior"
was logical, and no one complained about it.
Fabien.
Date: 3 Oct 2000 15:31:41
Message: <39da341d@news.povray.org>
I like this new structure very much. I've only just come across the need for
a "finish map" (No, not a map of Finland!)
this would solve the problem nicely and is much more logical.
Mick
"Fabien Mosen" <fab### [at] skynetbe> wrote in message
news:39D9C88D.C0ABE99D@skynet.be...
> as
> keywords.
> "normal".
> create
> material {
>           surface {
>                    texture {
>                             pigment {..}
>                             normal {..}
>                    finish
>           interior {
>                    refraction {..}
>                    media {..}
Date: 3 Oct 2000 18:00:42
Message: <39DA5343.227D2EE3@global2000.net>
This looks like it's more logical than the present syntax.  How about making
it the syntax for POV 4.0, which will be a total rewrite?
Brendan
> as
> keywords.
> "normal".
> create
> material {
>           surface {
>                    texture {
>                             pigment {..}
>                             normal {..}
>                    finish {
>           interior {
>                    refraction {..}
>                    media {..}
Date: 3 Oct 2000 20:08:51
Message: <39da7513$1@news.povray.org>
In article <39da341d@news.povray.org> , "Mick Hazelgrove"
You are aware that you can just use a texture_map, so except for consistency
reasons the current syntax should not limit you, or does it?
       Thorsten
Date: 3 Oct 2000 20:47:23
Message: <39DA7D0F.8790C3F4@pacbell.net>
Logical to whom ?
I did :)
Subject: Re: Thoughts about texturing system
Date: 3 Oct 2000 22:51:58
Message: <39da9b4e@news.povray.org>
How about this? Notice that "map" replaces all the other maps (less typing),
"light" is now "lighting", and that interior has "fading {...}" now. You
like?
material
 surface
  [pattern - map]
  texture
   [pattern - map]
   pigment {..}
   normal {..}
  finish
   [pattern - map]
   reflection {type .. min .. max .. exponent ..}
   lighting {ambient..  brilliance ..}
 interior
  ior
  media {..}
  fading {distance .. power .. color ..}
Date: 4 Oct 2000 02:32:26
Message: <39dacefa@news.povray.org>
Yes I am aware of that but I found that it was quite hard to control. Much
easier if there was one finish for the whole texture.
Mick
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:39da7513$1@news.povray.org...
for
consistency
>        Thorsten
Date: 4 Oct 2000 05:24:54
Message: <39DAF661.10825941@skynet.be>
And quicker, because currently, if you use a texture-map, the pigment,
normal and finish are calculated more than once for each pixel.
If finish was at the same level as texture, the "underlying" texture
would be calculated just once, no matter the complexity of the "finish
map".
Fabien.
Date: 4 Oct 2000 05:28:05
Message: <39DAF721.A6F16248@skynet.be>
> Logical to whom ?
To many people, it seems.  Given the explanation, don't you find my
idea more logical than the current implementation ?
> I did :)
You are not part of "everyone", you're an exceptionnal being, Ken :-)
Fabien.
Date: 4 Oct 2000 09:37:35
Message: <39db329f@news.povray.org>
"Fabien Mosen" wrote:
> "finish" is at the same hierarchic level as "pigment" and "normal",
> though it works very differently.  "pigment" and "normal" require a
> pattern and a map, while "finish" just has some keywords.
Pigment doesn't require a pattern and a map. In fact it's very common to
specify just a plain colour.
Normal doesn't require a pattern and a map either. The default is a plain
normal (which is usually achieved by simply not specifying the normal).
> a pattern isn't *required*, it's still incoherent with "pigment" and
> "normal".
I disagree. Pigment and normal doesn't require a pattern - on the other
hand, if finish_map was implemented, pigment, normal, and finish would
indeed be very coherent.
I think finish_map should be implemented.
> create a "surface" entity to group both.
I think finish is no more different from pigment and normal than pigment and
normal are different from each other. I think they should be grouped
together in the texture statement like they currently are.
If you want to make a map that affects pigment and normal but not finish you
can already do that. You use a texture_map - but with the new features in
MegaPOV and the future POV-Ray 3.5 you can also simply predeclare a pattern*
and use that pattern in both the pigment and normal statement.
* or if that isn't possible you can use pigment_pattern.
That method also has the advantage that you can have a map affect the
pigment and finish but not the normal, or the normal and finish but not the
pigment.
I can think of situations where I want a map to affect the normal and finish
but not the pigment. Therefore I think that it is not logical to separate
the finish from the pigment and normal.
I don't have any really good arguments against separating finish from
pigment and normal; I just think it's unnecessary and that a new group is
redundant. Instead I would like to see some really good argument *for* the
separation, because I haven't seen any yet IMHO.
What I've written here are only my own thoughts (of course). I would like a
good discussion!
> Also, this require that, inside the "finish" statement, finish
> properties are also grouped into separate entities.
I think that's a good idea.
Greetings,
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated October 1)
/ Also visit http://www.povrayusers.org
Date: 4 Oct 2000 10:55:51
Message: <39DB43F2.8ADE0940@skynet.be>
The plain color case is an exception in the syntax.  It's not very
annoying, but there might be a better way to do it.
No. A "plain normal" can't exist, as a normal is a variation !
(that's also why it doesn't work well with non-gradient patterns, such
as checker).
> > "normal".
 No.  Pigment and normal values rely on the position of the texture's
point in space, while finish rely on the normal value, light positions
and other objects positions.  Put otherwise, pigment and normal are
"global" properties (doesn't change with the point of view), while
finish
is a "local" (change with the point of view) property.  They do not
belong to the same hierarchy level.
 A proof of that ?  With MegaPOV, you can obtain the value of a pigment
at some point with "eval_pigment", but there's absolutely no way to
get the finish value of a point in space.
Yes.  That's the thing that got me thinking about that hierarchy
problem.
I would like to know WHY it hasn't been implemented yet.  I suspect
that the answer would come back to the hierarchy problem.
See the global vs. local issue, above.
> good discussion!
That's why we're here :-)
Fabien.
Date: 4 Oct 2000 11:00:51
Message: <slrn8tmhi9.eo2.ron.parker@fwi.com>
>finish
Finish doesn't change with the point of view.  The point of view is one
of the parameters that affects the appearance of a finish, but that's it.
This is not a proof of what you think it is.  The reason there's no way to
get teh finish value is because a given finish is the same everywhere.
>problem.
I suspect that the answer is that nobody's done it yet.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Proudly not helping RIAA and SDMI steal my rights --
  http://www.eff.org/Misc/EFF/Newsletters/EFFector/HTML/effect13.08.html
Date: 4 Oct 2000 11:13:08
Message: <39DB47FB.51F51C6A@skynet.be>
More precisely : the resulting finish value of one point of an object
changes with the point of view. (while the pigment and normal don't)
I'm gonna make a diagram to make my point clearer.
Fabien.
Date: 4 Oct 2000 11:17:19
Message: <slrn8tmih6.eon.ron.parker@fwi.com>
Normal certainly does, at least as much as finish does.  The terminology is
a bit sloppy, though.
Date: 4 Oct 2000 12:15:06
Message: <39DB5680.88B4D64C@skynet.be>
Normal does ??
let's say :
 sphere {<0,0,0>,1 pigment {Red}
                   normal {bumps .1}
                   finish {reflection .5}
let's consider the surface of the sphere at <0,1,0> (top of it).
The pigment value returned for that point will be the same,
whatever the camera position is.
The "virtual" slope (normal perturbation) at that point will
always be the same, regardless of the camera position.
However, the finish value returned (coming from reflection,
in that example) will be different with a different camera.
Fabien.
Date: 4 Oct 2000 12:20:20
Message: <slrn8tmm7b.eq3.ron.parker@fwi.com>
But the appearance of the surface due to that perturbation will vary with
camera position and lighting.
Not true.  Only the appearance of the surface due to the finish will vary.
The finish itself is constant.
Date: 4 Oct 2000 12:34:18
Message: <39DB5B00.D2F93934@skynet.be>
As is the appearance of the pigment, whose perception is influenced
by the normal of the surface, the lights...
The *definition* of the finish is constant troughout space, but
the resulting finish value, the one that will contribute to the
final aspect, varies with the camera position.
Imagine a scene without a camera.  Can you get the pigment value
of a suface's point ? Yes.  Can you get the normal at that point ?
Yes.  Can you get the color variation caused by reflection at that
point ? No !
As I said earlier, pigment and normal needs a pattern (plain color
pigment being a case where the color_map has an unique value), while
finish isn't based on patterns.
That's why I think that pigment and normal belongs to the same
level, as they have similar workings, but finish is a different
beast.
Fabien.
Date: 4 Oct 2000 12:35:13
Message: <39db5c41@news.povray.org>
> > very common to specify just a plain colour.
> It's not very annoying, but there might be a better way to do it.
So you're saying, "a difference between pigment and finish is that pigment
requires a pattern, except when it doesn't".
> > is a plain normal (which is usually achieved by simply not
Wrong. The normal is a vector which points away from the surface and is
perpendicular to it. When you specify a normal with a pattern, POV-Ray
artificially modifies this normal vector. But it's there no matter if you
modifies it or not!
> > would indeed be very coherent.
There is no such thing as a pigment value. There are colour vectors that are
controlled by the pigment statement.
There is no such thing as a normal value. There are normal vectors that are
controlled by the normal statement.
There is no such thing as a finish value. There's the ambient value, the
diffuse value, the phong, reflection, brilliance, and metallic values, and a
whole lot of other values. None of those values are dependent on light
positions or other objects' positions or anything. (If I specify reflection
to be 0.6, then it is 0.6 independent on other objects.)
> Put otherwise, pigment and normal are "global" properties
> (doesn't change with the point of view), while finish
> They do not belong to the same hierarchy level.
I think what you mean is that the *appearance* of the finish is dependant on
lights, objects, etc.
But the appearances of the pigment and normal are also dependent on those
things. If I make a pigment with a white colour it will look red if I have a
red light_source only. If I make a bumpy normal I can't see the bumps if the
object is in shadow.
So you see, everything is dependent on each other, not just the finish.
As I said, there is no such thing as a finish value.
Besides, you can't obtain the normal vector at some point either, so you
have no "proof".
Rune
Date: 4 Oct 2000 12:44:49
Message: <39db5e81@news.povray.org>
> point ? No !
You can't compare like that! Either you must compare the *values* of
pigment, normal, and finish. *OR* you must compare the *appearance* of
You can't compare the *values* of pigment and normal with the *appearance*
of finish. That doesn't make sense.
Rune
Date: 4 Oct 2000 13:50:15
Message: <39DB6CD5.3375C6FB@skynet.be>
> modifies it or not!
I meant that the normal {..} can't be plain.  I wasn't speaking of
the general normal of a surface, but of the perturbated normal
obtained by the normal {..} statement.
Thus, the default is rather "no perturbation".
There IS !  It is the rgbft value of the color at a given space point
(that value being determined by the pattern, color_map, and
transformations).
There IS !  It is the slope value at a given point of a surface.
(that value being determined by the pattern values at adjacent points of
 the surface, and transformations).
Guess what ? There IS !  It is the rgb value of the color that will
be added to the others texture elements at a given point of a surface,
that value being determined by the finish definition  (amount of
reflection, etc..), the normal of the surface at that point,
AND the camera, lights, objects positions.
> diffuse value,
> Ambient and diffuse are
That is the DEFINITION, not the resulting value !!
(and, BTW, ambient and diffuse shouldn't be in finish, since they are
 view-independent)
When POV-Ray searches the finish value for a pixel, it doesn't search
the "0.6", since it *already* knows that, it searchs for the color of
the reflected ray, which will be multiplied by 0.6 before being
"incorporated" with the pigment and normal values.
The finish is MORE fundamentally dependant on those things, since it
needs camera/lights/objects data to give its value for some point of
a surface.  Pigment and normal have an independant value, which is,
later,
affected by environment.  So, finish RELY on environment, while pigment
and normal are AFFECTED by environment.
> have no "proof".
 You could obtain the normal at some point of a surface.  It's not
availiable, but it's possible (you "just" have to interpolate
the values of adjacent points on the surface).
 In fact, a simple macro using 'trace' and 'eval_pattern' could give
you that value, but it's impossible (or tell me how) to get the
equivalent
finish information.
Fabien.
Date: 4 Oct 2000 13:51:45
Message: <39DB6D36.63646333@skynet.be>
I compared values with values.  See my previous post to see what
is, to me, the value of a finish.
Fabien.
Date: 4 Oct 2000 16:02:55
Message: <39db8cef@news.povray.org>
> > None of those values are dependent on light positions or other
> > objects' positions or anything. (If I specify reflection to be
> search the "0.6", since it *already* knows that, it searchs for
> the color of the reflected ray, which will be multiplied by 0.6
> before being "incorporated" with the pigment and normal values.
So what you're looking at is the resulting value; in other words the colour
value seen by the camera.
In that case, in order to compare, you also have to see at the resulting
value for the pigment and for the normal.
The problem is, it doesn't make sense. You can't separate the resulting
colour of pigment, normal and finish from each other, because they're all
dependent on each other and on external conditions.
> they are view-independent)
Well there you go. Where should they go then, if not in the finish? And what
about brilliance? And what is it anyway that makes you think that finish =
view-dependent?
> a surface.
No. A pigment has a colour no matter if there's any light_sources (or
cameras) or not. But you can only see it if there's light and camera.
Similarly, a finish has a reflection value etc., no matter if there's any
light_sources (or cameras) or not. But here too, you can only see it if
They're very coherent.
> Pigment and normal have an independent value, which is,
> later, affected by environment.
No, you can't see your pigment if there's no camera and light_sources.
Your arguments just don't make sense.
Rune
Date: 4 Oct 2000 17:01:06
Message: <39DB9988.D9A568C5@skynet.be>
No, I'm looking for the value BEFORE it's finally affected by the
projection system.
finish value depends, amongst other things, on normal (normal of the
object's surface + normal {..} perturbation).  That's the only
inter-dependance.  They don't "depend on each other".  Pigment and
normal are independant from each other and from finish, and finish
is independant from pigment.
Oh, BTW, interior {ior} depends on normal perturbation (it
affects the refracted ray).  Would you, because of that, put
the "interior" statement inside the "texture" statement ?
Good question.  Historically, "finish" has been fed with many
features that didn't fit elsewhere.  "crand" is an example of
that.  ambient, diffuse and brillance might go into a separate
statement, (maybe "lighting") which describes how the surface
reacts to light.
You know, I don't intend to criticize, and the current system
works fine, but some design flaws are there, and are worth
discussing, especially in the perspective of future enhancements.
> view-dependent?
I explained myself in great lenghts about that.
I can ask POV-Ray to retrieve it and put the rgb value on-screen,
without even rendering !  I can do the same (with a macro) for the
normal perturbations.  However, I can't do it for finishes.  If
you can, tell me how.
A reflection AMOUNT, which, with a camera, light, and object, can
result into a rgb value at a given point.
See above.  I can retrieve the value.
Fabien.
Date: 4 Oct 2000 17:19:44
Message: <slrn8tn7os.fb7.ron.parker@fwi.com>
Using a feature that doesn't exist.  Just because it doesn't exist
doesn't mean it's not possible.
Date: 4 Oct 2000 17:31:05
Message: <39DBA08E.FCEF2F6E@skynet.be>
Nor the opposite ;-)
Retrieving the normal value is not an availiable feature, but I can
do it (without a camera anywhere) by using the surface's normal
and the normal pattern.
If you think that "retrieving the finish value at some point of
a surface, without a camera", is possible please explain me
(basically) how.  (even if it implies non-availiable features,
I'm just interested by the theorical principle).
By "finish value", I mean the rgb value that contributes to the
final material aspect at a given point.  Imagine a Red sphere,
with a white phong highlight.  The "finish value" is different for
points "covered" by the highlight, and for points that are
"outside" the highlight. (though the "finish parameters" are constant).
Fabien.
Date: 4 Oct 2000 17:42:46
Message: <slrn8tn941.fbq.ron.parker@fwi.com>
Your definition of "finish value" is basically meaningless.  You also can't
get the final color of a pigment without knowing where all the light sources
are.
Date: 4 Oct 2000 18:27:29
Message: <39dbaed1$1@news.povray.org>
In article <39DAF661.10825941@skynet.be> , Fabien Mosen
> map".
If I am not completely wrong this is not the case you should be able to put
your pigment and normal stuff in one texture layer and have as many finish
layers as you like in other texture layers.
    Thorsten
Date: 5 Oct 2000 06:30:16
Message: <39dc5838@news.povray.org>
Fabien Mosen <fab### [at] skynetbe> wrote:
: Can you get the normal at that point ? Yes.
: Can you get the color variation caused by reflection at that
: point ? No !
  You are comparing different things.
  Yes, you can get the normal at that point, but you can't get the
color variation caused by the normal at that point.
  In the same way, yes, you can get the finish value at that point but
you can't get the variation caused by the finish at that point.
  Normal and finish are very similar.
Date: 5 Oct 2000 06:44:26
Message: <39dc5b89@news.povray.org>
: No, I'm looking for the value BEFORE it's finally affected by the
: projection system.
  You can't get a color caused by a reflection/refraction BEFORE the final
projection system is set. So you are asking for something that is impossible.
: Oh, BTW, interior {ior} depends on normal perturbation (it
: affects the refracted ray).
  You made a wrong statement and then a true statement in parentheses.
  The normal doesn't affect the ior because the ior is constant. Yes, the
normal affects the refracted ray. A reflected/refracted ray is affected
by many things.
: Good question.  Historically, "finish" has been fed with many
: features that didn't fit elsewhere.  "crand" is an example of
: that.  ambient, diffuse and brillance might go into a separate
: statement, (maybe "lighting") which describes how the surface
: reacts to light.
  Since when finish has contained only view-dependant things?
: I can ask POV-Ray to retrieve it and put the rgb value on-screen,
: without even rendering !
  No, you can't.
  Well, you can, but without shading (due to light sources), shadows,
fog, media, radiosity... A kind of +Q0 image.
:> No, you can't see your pigment if there's no camera and light_sources.
  It's perfectly possible to see a pigment without light_sources.
  A scene without a camera doesn't make sense.
Date: 5 Oct 2000 09:11:26
Message: <39DC7CFF.FC68B825@skynet.be>
That's part of the problem !  The MAIN purpose of finish is to set
these view-dependant features : reflection and highlights (which
are faked blurred reflections).  The word "finish" implies that
its the "last" property of a surface : varnish,...
>   No, you can't.
#declare RGBValue = eval_pigment (MyPigment,<x,y,z>);
#debug concat ("the rgb value at <x,y,z> is ",
                str(RGBValue.x,3,3),str..,str..)
All right.  That is the rgb value at that point, which is, "later",
modified by other elements.
Thats for the sake of explaining how finish is different from
pigment and normal.  Within some hours, I'll get that diagram
done, and I hope it will make things clearer.
(BTW, you could want to make a scene without a specific camera, just
 to get the results of a particular algorithm that uses POV-Ray's
 specific capabilities)
Fabien.
Date: 5 Oct 2000 09:26:03
Message: <39dc816a@news.povray.org>
: That's part of the problem !  The MAIN purpose of finish is to set
: these view-dependant features : reflection and highlights (which
: are faked blurred reflections).  The word "finish" implies that
: its the "last" property of a surface : varnish,...
  And why things like crand, ambient and diffuse are not this kind of things?
:>   It's perfectly possible to see a pigment without light_sources.
:>   A scene without a camera doesn't make sense.
: Thats for the sake of explaining how finish is different from
: pigment and normal.
  Normal is not much different from finish. If you don't have any light
source nor reflection/refraction, applying a normal to a surface has absolutely
no effect. The normal has effect only in the final rendering pass, as well
as finish.
Date: 5 Oct 2000 09:43:03
Message: <39dc8567@news.povray.org>
Hmm, I came up with this a long time back.  I wanted to do a wood pattern,
and looking at the wood (balsa) I was working from, I noticed a series of
tiny lines perpendicular (or maybe parallel) to the grain that shine more
than elsewhere.  Only way I could do it was a texture map where the pigment
and normal were the same, but the finishes were different.  Having a
separate finish map to allow for finishes that vary over the surface while
the texture does not could be nice.
On the other hand, where textures are also varying, it requires two maps
with the same entry values (to do what used to be done), but I'm not sure
that's a good reason *not* to do it.  Certainly making them independent
allows for a lot of new possibilties (ex: Textures vary based on granite
pattern, while finishes based on bump, or whatever)
Geoff
Date: 5 Oct 2000 12:59:24
Message: <39dcb36c@news.povray.org>
No comments, thoughts, critiques?
Date: 5 Oct 2000 15:38:17
Message: <39dcd8a9@news.povray.org>
Fabien,
if I have understood you correctly you're saying that finish is
view-dependent, while pigment and normal are not. I have tried several times
to explain why that is not true, but apparently have failed.
I will now try to explain it using some clearer expressions. I will use
"property" contra "appearance". These should not easily be mixed up.
In the pigment you specify the colour(s) of your object. If you make a
sphere with a white pigment, then a property of the sphere is that it is
white. Even if your object is lit by a red light_source only, the colour
property of the sphere is *still* white. The *appearance* however, is *red*
(and very dark red where it is in shadow).
Note that the surroundings don't affect the property of the object, but they
do affect the appearance.
Now to the normal. A property of an object can be it's slope at a given
point. This slope is independent on the surroundings (lights, camera, etc.).
However, the *appearance* of the slope is dependent on many things which I
will not go into details with here.
In the finish you specify many properties of the object. Ambient, diffuse,
the amount of reflection, highlights, and many other things. The values you
specify are the properties of the object. They are independent of the
surroundings (view-independent). Only the *appearance* is dependent on the
surroundings.
When you want to measure the reflected rays for an object, that is related
to the appearance, not the property of the object.
So for the pigment you want to measure a property.
And for the normal you want to measure a property.
But for the finish you want to measure the appearance!!!
So as I have said many times before, you can't compare like that.
Rune
Date: 7 Oct 2000 23:20:31
Message: <39DFE43E.55DF@pacbell.net>
Well, after having just read thru all the posts on this subject, all I
have to say is "How many Angles can dance on the head of a pin?"
Ken Matassa
Date: 8 Oct 2000 21:59:08
Message: <slrn8u29dm.14e.ron.parker@fwi.com>
That's acute question, but you're right.  Maybe we're being too obtuse.
