POV-Ray : Newsgroups : povray.general : Re: Problem with normal statement Server Time
24 Mar 2026 15:14:50 EDT (-0400)
  Re: Problem with normal statement (Message 1 to 2 of 2)
Subject: Re: Problem with normal statement
Date: 3 Oct 2000 07:19:31
Message: <39D9C0C4.35F036F9@schunter.etc.tu-bs.de>
Pavel Fryda wrote:
> Hi,
> I have a problem with normal statement. When I rendered following scene,
> I've got attatched picture as an output. It is distorted on it's left
> side. When I removed the line with normal statement, output seemed to be
> OK.
> Is it a bug in povray or in my source code?
> Please help.
> (I'm using POV-Ray for Windows Ver. 3.1g)
First of all, please don't post binary attachments in this newsgroup
(povray.binary.images can be used for this). Furthermore, jpg is the preferred
format.
Concerning your problem, I would estimate, the "scale 0.025" in the normal
statement probably causes a rounding error responsible for the strange
behaviour.  But i'm not sure about it.
For example
normal { granite 0.15 scale 0.1 }
looks much better although there are still strange things happening :-)
Date: 3 Oct 2000 07:59:52
Message: <39d9ca38@news.povray.org>
"Pavel Fryda" <fry### [at] seznamcz> wrote in message
news:39D9BB6E.66D1EAD2@seznam.cz...
> Hi,
> OK.
> Please help.
You could try switching to bozo, which produces similiar results but without
the (apparent) bug. Incidentally, and I could easily be wrong, but the "odd"
area on the left is, I think, what you should get scaling the bumps this
small - the smoother area is the bug (this is assuming that bozo scale 0.025
is similiar to bumps scale 0.025).
As noted, please do not post images in this group - there is a faq in
povray.announce.faq (and with a scene this simple, an image is probably not
required since it only takes a few seconds to render).
BTW assuming you're new here, welcome aboard!
