POV-Ray : Newsgroups : povray.general : No ground fog, why? Server Time
5 Nov 2026 16:23:06 EST (-0500)
  No ground fog, why? (Message 1 to 13 of 13)
Subject: No ground fog, why?
Date: 20 Sep 2000 10:16:41
Message: <39C8C6BF.451310E2@alleganisd.org>
Here is a scene I am trying to render with POV 3.1g for win 98.
No ground fog ever appears. Why?
// Persistence of Vision Ray Tracer Scene Description File
// File: ?.pov
// Vers: 3.1
// Desc: Basic Scene Example
// Date: mm/dd/yy
// Auth: ?[esp]
#version 3.1;
#include "tex.inc" //contains the texture definition.
global_settings
  assumed_gamma 1.4
default {texture {pigment {color Red}} }
//#include "fog.inc"
fog { fog_type 2 //Layer: Layer2
    rgb <0.620, 0.000, 0.000>
    fog_offset 6
    fog_alt 0.5 //fade away rate
} //fog
camera
  location  <0.0, 0.5, -4.0>
  direction 1.5*z
  right     4/3*x
  look_at   <0.0, 0.0,  0.0>
sky_sphere
  pigment
    gradient y
    color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source
  0*x // light's position (translated below)
  color red 1.0  green 1.0  blue 1.0  // light's color
  translate <-30, 30, -30>
light_source
  translate <30, -30, -30>
//#include "shape.inc" //has preview shape
plane { y, -1 pigment {color rgb <0.7,0.5,0.3>}}
sphere { 0.0, 1 //start of shape
    texture { Texture1 }
} //Sphere
See my Free stuff page. It compares free website providers, and
lists free internet access providers.
http://www.crosswinds.net/~robertsc/free.htm
Win98 help file loaded with hints and tips, including securing a
Win 95/98 PC in a classroom setting. VB4 help file with lots of
code and hints.
At http://www.crosswinds.net/~robertsc/
Subject: Re: No ground fog, why?
Date: 20 Sep 2000 10:36:38
Message: <39c8cb76@news.povray.org>
Put the keyword "hollow" into the sky_sphere.
Date: 20 Sep 2000 11:08:00
Message: <39c8d2d0$1@news.povray.org>
In article <39c8cb76@news.povray.org> , "Bob Hughes"
This is nonsense.  They keyword hollow does not belong in the sky_sphere (in
fact it won't work there at all!).   sky_sphere does not have any volume, it
is infinite - otherwise you would also get the "camera in non-hollow object"
warning!   sky_spheres are explained in the POV-Ray manual.
Now to the problem. Simply add the "distance [value]" to the fog statement,
for example:
    distance  20
    fog_offset 6
} //fog
This will make the fog very visible.
      Thorsten
Date: 20 Sep 2000 11:20:53
Message: <39C8D5CA.457A2CF7@alleganisd.org>
Thank you, that worked. The help file led me to believe that
"distance" was only for type 1 fog.
> for example:
>     distance  20
>     fog_offset 6
> } //fog
>       Thorsten
code and hints.
Date: 20 Sep 2000 11:21:04
Message: <39C8D5D6.5C59A7B7@alleganisd.org>
> for example:
>     distance  20
>     fog_offset 6
> } //fog
>       Thorsten
code and hints.
Date: 20 Sep 2000 17:03:50
Message: <39C926BB.1B23DBF2@club-internet.fr>
Just for a try. Does 'inverse' to the plane resolve the problem as well ?
Fabien H
> > for example:
> >     distance  20
> >     fog_offset 6
> > } //fog
> >       Thorsten
> code and hints.
Date: 20 Sep 2000 23:07:35
Message: <39c97b77@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:39c8d2d0$1@news.povray.org...
(in
it
object"
Curiously the Scene Help doesn't mention that fact in the section The Sky
Sphere or the fog sections either from what I could see there.
I hate to lead people astray like that, sorry.  Glad you corrected me
Thorsten.
I still use sphere instead of sky_sphere so much it's second nature to add
hollow to that anyway.  Guess when I make the mistake and get the error when
putting hollow into one that I don't think twice about it and remove it.
Date: 20 Sep 2000 23:09:44
Message: <39c97bf8$1@news.povray.org>
"Fabien Hénon" <ffj### [at] club-internetfr> wrote in message
news:39C926BB.1B23DBF2@club-internet.fr...
Shouldn't.  The normal of a plane isn't flipped when the float is negative,
only when the plane normal itself is negative.  Inside and outside of a
plane remains constant otherwise.  Unless I'm wrong about that too.
Date: 20 Sep 2000 23:33:59
Message: <39C980FA.40792639@pacbell.net>
You may be suffering from one of those misconceptions that Warp has
been talking about. A sky_sphere is not a sphere object. It is more
like the background feature that has spherical pigment properties.
Date: 21 Sep 2000 02:52:00
Message: <39c9b010@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
:> Put the keyword "hollow" into the sky_sphere.
: This is nonsense.  They keyword hollow does not belong in the sky_sphere (in
: fact it won't work there at all!).   sky_sphere does not have any volume, it
: is infinite - otherwise you would also get the "camera in non-hollow object"
: warning!   sky_spheres are explained in the POV-Ray manual.
  Perhaps it could be a good idea to actually TEST the suggestion between
posting it. :)
Date: 21 Sep 2000 02:55:29
Message: <39c9b0e1@news.povray.org>
Bob Hughes <per### [at] aolcom?subject=pov-news:> wrote:
: I still use sphere instead of sky_sphere so much it's second nature to add
: hollow to that anyway.
  Ever considered using 'inverse' instead?
  If you don't inverse your sky sphere you will be looking at its surface
from the inside and thus the normal vectors will be pointing at the wrong
side producing a possibly unwanted result.
Date: 21 Sep 2000 16:32:52
Message: <39ca7074$1@news.povray.org>
news:39c9b0e1@news.povray.org...
add
Sage advice, thanks Warp.  I'll certainly try that.
Date: 21 Sep 2000 16:34:37
Message: <39ca70dd@news.povray.org>
news:39c9b010@news.povray.org...
(in
volume, it
object"
| posting it. :)
Yes, well I do when I'm 50% unsure.  I was 99% sure hollow went into
sky_sphere.
