Here is a scene I am trying to render with POV 3.1g for win 98.
No ground fog ever appears. Why?
// Persistence of Vision Ray Tracer Scene Description File
// File: ?.pov
// Vers: 3.1
// Desc: Basic Scene Example
// Date: mm/dd/yy
// Auth: ?[esp]
#version 3.1;
#include "tex.inc" //contains the texture definition.
global_settings
assumed_gamma 1.4
default {texture {pigment {color Red}} }
//#include "fog.inc"
fog { fog_type 2 //Layer: Layer2
rgb <0.620, 0.000, 0.000>
fog_offset 6
fog_alt 0.5 //fade away rate
} //fog
camera
location <0.0, 0.5, -4.0>
direction 1.5*z
right 4/3*x
look_at <0.0, 0.0, 0.0>
sky_sphere
pigment
gradient y
color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source
0*x // light's position (translated below)
color red 1.0 green 1.0 blue 1.0 // light's color
translate <-30, 30, -30>
light_source
translate <30, -30, -30>
//#include "shape.inc" //has preview shape
plane { y, -1 pigment {color rgb <0.7,0.5,0.3>}}
sphere { 0.0, 1 //start of shape
texture { Texture1 }
} //Sphere
See my Free stuff page. It compares free website providers, and
lists free internet access providers.
http://www.crosswinds.net/~robertsc/free.htm
Win98 help file loaded with hints and tips, including securing a
Win 95/98 PC in a classroom setting. VB4 help file with lots of
code and hints.
At http://www.crosswinds.net/~robertsc/
Put the keyword "hollow" into the sky_sphere.
In article <39c8cb76@news.povray.org> , "Bob Hughes"
This is nonsense. They keyword hollow does not belong in the sky_sphere (in
fact it won't work there at all!). sky_sphere does not have any volume, it
is infinite - otherwise you would also get the "camera in non-hollow object"
warning! sky_spheres are explained in the POV-Ray manual.
Now to the problem. Simply add the "distance [value]" to the fog statement,
for example:
distance 20
fog_offset 6
} //fog
This will make the fog very visible.
Thorsten
Thank you, that worked. The help file led me to believe that
"distance" was only for type 1 fog.
> for example:
> distance 20
> fog_offset 6
> } //fog
> Thorsten
code and hints.
> for example:
> distance 20
> fog_offset 6
> } //fog
> Thorsten
code and hints.
Just for a try. Does 'inverse' to the plane resolve the problem as well ?
Fabien H
> > for example:
> > distance 20
> > fog_offset 6
> > } //fog
> > Thorsten
> code and hints.
"Thorsten Froehlich" <tho### [at] trf de> wrote in message
news:39c8d2d0$1@news.povray.org...
(in
it
object"
Curiously the Scene Help doesn't mention that fact in the section The Sky
Sphere or the fog sections either from what I could see there.
I hate to lead people astray like that, sorry. Glad you corrected me
Thorsten.
I still use sphere instead of sky_sphere so much it's second nature to add
hollow to that anyway. Guess when I make the mistake and get the error when
putting hollow into one that I don't think twice about it and remove it.
"Fabien Hénon" <ffj### [at] club-internet fr> wrote in message
news:39C926BB.1B23DBF2@club-internet.fr...
Shouldn't. The normal of a plane isn't flipped when the float is negative,
only when the plane normal itself is negative. Inside and outside of a
plane remains constant otherwise. Unless I'm wrong about that too.
You may be suffering from one of those misconceptions that Warp has
been talking about. A sky_sphere is not a sphere object. It is more
like the background feature that has spherical pigment properties.
Thorsten Froehlich <tho### [at] trf de> wrote:
:> Put the keyword "hollow" into the sky_sphere.
: This is nonsense. They keyword hollow does not belong in the sky_sphere (in
: fact it won't work there at all!). sky_sphere does not have any volume, it
: is infinite - otherwise you would also get the "camera in non-hollow object"
: warning! sky_spheres are explained in the POV-Ray manual.
Perhaps it could be a good idea to actually TEST the suggestion between
posting it. :)
Bob Hughes <per### [at] aol com?subject=pov-news:> wrote:
: I still use sphere instead of sky_sphere so much it's second nature to add
: hollow to that anyway.
Ever considered using 'inverse' instead?
If you don't inverse your sky sphere you will be looking at its surface
from the inside and thus the normal vectors will be pointing at the wrong
side producing a possibly unwanted result.
"Warp" <war### [at] tag povray org> wrote in message
news:39c9b0e1@news.povray.org...
add
Sage advice, thanks Warp. I'll certainly try that.
news:39c9b010@news.povray.org...
(in
volume, it
object"
| posting it. :)
Yes, well I do when I'm 50% unsure. I was 99% sure hollow went into
sky_sphere.
