POV-Ray : Newsgroups : povray.general : normal amount and normal map Server Time
26 Oct 2026 14:49:39 EDT (-0400)
  normal amount and normal map (Message 1 to 3 of 3)
Subject: normal amount and normal map
Date: 15 Sep 2000 10:09:04
Message: <39C22D70.58AA7B42@alleganisd.org>
Say I have a texture like this:
#declare Texture1 = texture { //Reddish
    pigment { color rgb <0.790, 0.000, 0.000>
        } // pigment;
    normal {
        boxed
        normal_map {
            [ 0.250 bumps turbulence 0.2 ]
            [ 0.750 crackle turbulence 0.3 ]
            } // normal map
        scale <0.2, 0.1, 0.3>
        } //normal
} //texture
Normally, if you use a single pattern in a normal you need to
enter an amount. Like this:
        } // pigment;
    normal {
        boxed .25
        } //normal
} //texture
However, is the amount required for normal maps? Is it optional?
I rendered an image with a normal map, with the amount and
without the amount and got no errors. So I guess it's optional,
but legal to use.
See my Free stuff page. It compares free website providers, and
lists free internet access providers.
http://www.crosswinds.net/~robertsc/free.htm
Win98 help file loaded with hints and tips, including securing a
Win 95/98 PC in a classroom setting. VB4 help file with lots of
code and hints.
At http://www.crosswinds.net/~robertsc/
Subject: Re: normal amount and normal map
Date: 15 Sep 2000 10:25:23
Message: <39c23152@news.povray.org>
Chuck Roberts <cro### [at] alleganisdorg> wrote:
: Normally, if you use a single pattern in a normal you need to
: enter an amount.
  No, you don't need to do it. If you don't specify the amount, a default
value is used. I don't know what's the default value (AFAIK it's not 1
although it would be logical).
Date: 15 Sep 2000 11:28:28
Message: <39C23F84.6C93848B@pacbell.net>
> : enter an amount.
It is also not unusual that the POV-Team has assigned default
values for many of the functions in POV-Ray. For example pigment
pattens have default colors assigned if none are specified in an
image_map.
