POV-Ray : Newsgroups : povray.general : 3.5 update in p.a.f-a-q Server Time
26 Oct 2026 15:43:07 EDT (-0400)
  3.5 update in p.a.f-a-q (Message 1 to 8 of 8)
Subject: 3.5 update in p.a.f-a-q
Date: 3 Sep 2000 10:21:15
Message: <39B25E63.FA669BE2@yahoo.com>
did you all see it?  of the maybe features, the one i'll be happiest
about if it is included is solid triangle mesh since i've used it as a
main feature of my models.
Subject: Re: 3.5 update in p.a.f-a-q
Date: 3 Sep 2000 15:42:59
Message: <39b2a9c3@news.povray.org>
I wonder what this means (in the NO list):
"Reset children (deprecated - use pigment_pattern)"
How can a pigment_pattern be used instead of the reset_children warp?
I can't figure it out myself right now.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated July 23)
/ Also visit http://www.povrayusers.org
Date: 3 Sep 2000 15:58:32
Message: <39b2ad68@news.povray.org>
Say you used to have this:
pigment
 bozo turbulence 1
 pigment_map
  [0 bozo]
  [1 granite]
 reset_children
Now you use:
pigment
 pigment_pattern {bozo turbulence 1}
 pigment_map
  [0 bozo]
  [1 granite]
Date: 3 Sep 2000 16:41:57
Message: <39b2b795@news.povray.org>
> pigment {
>  bozo turbulence 1
>  reset_children
> Now you use:
> pigment {
Aha, ok, but wouldn't you have to make sure the color_map goes from black to
white? Like for example using spotted instead of bozo. And isn't this method
slower? It's like having a pattern, and base a pigment on that pattern, and
then converting the pigment back into a pattern.
Greetings,
Rune
Date: 3 Sep 2000 16:44:02
Message: <39B2B849.B2BB8F03@schunter.etc.tu-bs.de>
I wonder whether GIF support will be removed as in megapov. There is nothing
about it in the list, but it says, that there will be TIFF file support and IIRC
several TIFF subformats use the LZW algorithm just like GIF.
Date: 3 Sep 2000 17:16:36
Message: <39B2BEA7.BD73C875@skynet.be>
It will, because of the Unisys issue.  As of TIFF, it's just the
compressed format who use lzw, and it's rarely used in graphics...
Fabien.
Date: 3 Sep 2000 18:05:49
Message: <39b2cb3d@news.povray.org>
to
> white?
Yes, I believe so.
and
I dunno. You've got me. :)
Date: 4 Sep 2000 16:45:17
Message: <39b409dd$1@news.povray.org>
"Rune" <run### [at] inamecom> wrote...
to
> white?
Yes.
and
Possibly, but the speed difference isn't as much as you might think.  This
technique uses 11 multiplications and 6 additions to do the conversions: 8
"extra" multiplications and 4 "extra" additions to do blend the color_map
entries, plus 3 mulitplications and 2 additions to convert to grey-scale.
(This is based on blending a single-component pattern value, as opposed to a
5-component color value, using 2 multiplications and 1 addition.)
Interestingly enough, though, using this instead of reset_children will
often eliminate the need to apply some warps to the child textures, which
could mean fewer matrix transformations.
-Nathan
