POV-Ray : Newsgroups : povray.general : converting rgb to spectra Server Time
13 May 2026 10:14:12 EDT (-0400)
  converting rgb to spectra (Message 1 to 10 of 19)
Subject: converting rgb to spectra
Date: 21 Aug 2000 10:33:08
Message: <39A192D3.9659E6D5@home.nl>
I saw in a message from Peter Popov in reply to Feature request for
pov3.5 (08/09/00 16:55), that rgb can be converted to spectra. That's
what I need., since I want to convert the rgb value to a corresponding
audio frequentie, and audio is spectra. Where can I find more
information on doing so? (I'm a newbie on complex math, so it should be
a little bit easy explained.)
Remco Poelstra
Subject: Re: converting rgb to spectra
Date: 21 Aug 2000 11:51:21
Message: <39A15022.1157D2F4@aetec.ee>
Remco Poelstra wrote:
> Hi,
> Remco Poelstra
I don't think that you'll need complex math for this. In MegaPov source
code there is function (RGBtoHue in color.c)from MSGTracer, which
converts RGB to visible spectra (although part of it is commented out,
but You can get idea). Basically you should convert RGB to hue, then
convert hue to frequency (or wave length).
Date: 21 Aug 2000 12:07:10
Message: <39A1A8DE.E97F9626@home.nl>
> > Hi,
> > Remco Poelstra
All right, I'll, but what is hue exactly? I thought it's the 'rotation'
of the colorcircle.
Remco
Date: 21 Aug 2000 12:40:42
Message: <chrishuff-3689A8.11420321082000@news.povray.org>
In article <39A192D3.9659E6D5@home.nl>, Remco Poelstra
I think it would be very useful to have rgb2hls() and hls2rgb()
functions, and similar ones for HSV and other color spaces. These could
also be useful post_process filters. The only thing stopping me from
writing them is a lack of knowledge of how to convert between them.
Christopher James Huff
Date: 21 Aug 2000 12:45:04
Message: <slrn8q2ns2.13j.ron.parker@fwi.com>
The PostScript Language Reference Manual contains the necessary formulae,
and is available in PDF format from Adobe's website.  It also might
include some CMYK conversions, though I'm undecided as to the usefulness
of those.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 21 Aug 2000 12:54:33
Message: <chrishuff-EC51D2.11555421082000@news.povray.org>
In article <slr### [at] fwicom>, ron### [at] povrayorg
> of those.
Thanks for the information! I will check it out...
I tend to agree about the CMYK, it is just too dependant on output
devices. However, a simple conversion might still be useful, if the
documentation warns about the fact it isn't very accurate. The problem
is, where do we put the K? The other color spaces could be stored in the
same rgb vectors, the components would just have different meanings.
Maybe the function should optionally take a float vector which it would
store the K value in.
Date: 21 Aug 2000 18:15:50
Message: <39A1A7FA.53ED54C8@faricy.net>
I wrote a macro to do RGB<->HLS...
David Fontaine   <dav### [at] faricynet>   ICQ 55354965
Please visit my website:  http://davidf.faricy.net/
Date: 21 Aug 2000 18:43:33
Message: <chrishuff-76DC9C.17445421082000@news.povray.org>
In article <39A1A7FA.53ED54C8@faricy.net>, David Fontaine
And I have it on my system. :-)
I just haven't reverse engineered it and written a POV conversion
function yet. And it only takes care of one color space.
Date: 21 Aug 2000 21:33:00
Message: <39a1d84c@news.povray.org>
Psuedocode plagerized from Computer Graphics and Principals 2nd Edition:
procedure RGB_To_HSV( r, g b: real; var h,s v : real)
begin
    max := Maximum(r,g,b);
    min := Minimum(r,g,b);
    v := max;
if max <> 0 then
    s := (max - min)/max;
else s := 0;
if s = 0 then
   h := UNDEFINED
else
    begin
        delta := max - min;
        if r = max then
            h := (g - b)/delta;
        else if g = max then
            h := 2 + (b - r)/delta;
        else if b = max then
            h := 4 + (r - g)/delta;
        h := h* 60;
        if h < 0 then
            h := h + 360;
    end
end
This should be easily converted into a macro (assumming I haven't made too
many typing errors.)
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
> of those.
Date: 21 Aug 2000 23:05:08
Message: <chrishuff-87615D.22063021082000@news.povray.org>
In article <39a1d84c@news.povray.org>, "Halbert" <hha### [at] capitalnet>
...snip...
> made too many typing errors.)
Whee, Pascal...the last time I read Pascal I was trying to convert a
demo program written in it to C. It was surprisingly easy, actually...
Here is an untested attempt at a straight conversion to POV:
#macro RGB2HSV(RGB)
    #local Max = max(RGB.r, max(RGB.g, RGB.b));
    #local Min = min(RGB.r, min(RGB.g, RGB.b));
    #local V = Max;
    #if(Max != 0)
        #local S = (Max - Min)/Max;
    #else
        #local S = 0;
    #if(S = 0)
        #local H = 0;
    #else
        #local Delta = Max - Min;
        #if(RGB.r = Max)
            #local H = (RGB.g - RGB.b)/Delta;
        #else
            #if(RGB.g = Max)
                #local H = 2 + (RGB.b - RGB.r)/Delta;
            #else
                #if(RGB.b = Max)
                    #local H = 4 + (RGB.r - RGB.g)/Delta;
        #local H = H*60;
        #if(H < 0)
            #local H = H + 360;
    (< H, S, V>)
