POV-Ray : Newsgroups : povray.general : Non-linear transforms Server Time
24 Mar 2026 22:12:16 EDT (-0400)
  Non-linear transforms (Message 1 to 10 of 10)
Subject: Non-linear transforms
Date: 12 Aug 2000 17:22:10
Message: <3995C000.235C4553@club-internet.fr>
(see images in povray.binary.images)
This little test shows how it is theoretically possible to do non-linear
transformations on objects using megapov.
The object is the union of a cube, a sphere and a cone.
A function based on the distance to this object is created, using the
proximity pattern.
Then an isosurface is created, using this function and a limit slightly
positive. This way, the surface is "just a bit" envelopping the object.
The advantage is that there is no equation here to describe the object;
the proximity pattern does all the job.
The second picture makes use of this first function, which is composed
with a (rather uninteresting) space transform, to perform the reverse
transformation to the object. And the nice point is that this
transformation is non-linear.
The sad point is that the rendering times are absolutely insane.
As Chris wrote, there is a granularity issue here, and very strong
sampling for the proximity detection, high accuracy for the isosurface,
and a bit of AA are necessary to get a fairly ugly and tiny image of a
very simple object.
"Material" questions could certainly be solved the same way to get the
texture follow the object transformation.
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
\/\/ \__/ /_ /_ |__ \_ |\
Subject: Re: Non-linear transforms
Date: 12 Aug 2000 17:51:00
Message: <8F8EF73D6seed7@204.213.191.228>
>very simple object.
Could you use the object pattern here and use it as a function?
Ingo
Date: 12 Aug 2000 18:13:37
Message: <3995CC0F.FB8CE0BE@club-internet.fr>
I don't think so.
The object pattern gives only two possible values and I'm not sure the
isosurface algorithm would appreciate. Eg. if the function returns 0
outside and 1 inside, a threshold of 0 would probably give the whole
container, .5 would give nothing and 1 would give "something" inside the
object. This is why I used the proximity pattern with a very small
treshold.
Anyway I'll give it a try.
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
Date: 12 Aug 2000 18:46:27
Message: <chrishuff-B99548.17473512082000@news.povray.org>
In article <8F8EF73D6seed7@204.213.191.228>, ing### [at] homenl (ingo)
The isosurface uses the gradient of the function in it's calculations,
the object pattern returns one of 2 values, so it basically has an
infinite gradient. This causes the isosurface algorithm problems, it
can't easily find the surface and you end up with a bunch of artifacts.
The same problem will occur with other patterns like checker and with
color_maps with sharp changes in color.
Date: 12 Aug 2000 18:55:31
Message: <chrishuff-491968.17563912082000@news.povray.org>
In article <3995C000.235C4553@club-internet.fr>, Francois Dispot
Actually, one of my planned enhancements to the proximity pattern
consists of adding a proximity function to some of the shapes...objects
which can't be computed this way, like some CSG's, would still use the
sample method, but objects like spheres and boxes would use their own
equations. Of course, all this would be hidden from the user...
> very simple object.
The above enhancement wouldn't only speed up the pattern, it would also
give perfectly smooth results for some objects. :-)
And of course, blobs don't need this...just use the blob pattern.
I don't understand what you mean...
Date: 13 Aug 2000 05:38:47
Message: <39966CA6.84396041@club-internet.fr>
I have already thought about this for meshes and it should be fast to
get the distance from a point to a mesh. Knowing whether it is inside or
not is a different problem...
> > very simple object.
If you apply a texture to the above object, you will do so after its
shape is transformed. Thus it is not transformed. If you want to bend a
wooden object, you need to bend the wood pigment the same way you bend
the shape. Here it has not been done (well, the plain white pigment is
quite versatile ;-)
> Christopher James Huff - Personal e-mail: chr### [at] maccom
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> Personal Web page: http://homepage.mac.com/chrishuff/
> TAG Web page: http://tag.povray.org/
      __  __ __  __  _
|  | /  \  /  / |_  /  |/
Date: 13 Aug 2000 08:47:32
Message: <39969902.E17E2337@schunter.etc.tu-bs.de>
Don't know, whether this has been discussed before, but how about not
transforming the objects but distorting space itself ? That would probably
involve some elementary changes in the raytracing engine itself and can be very
time consuming with complicated transformations.  Furthermore it would affect
all objects in the scene equally, which would be something quite different.
I don't really know if this idea is realizable (i never looked at that part of
the Pov source btw. :-)
IIRC there are some efforts including relativistic effects in raytracing
programs which seems somehow similar to my idea (the influence of gravity fields
on light for example)
Date: 13 Aug 2000 12:09:14
Message: <chrishuff-F2970F.11102213082000@news.povray.org>
In article <39966CA6.84396041@club-internet.fr>, Francois Dispot
Actually, that one has already been solved in MegaPOV, all that is left
is the proximity calculation.
> quite versatile ;-)
Yeah, I understood the problem, but I didn't understand your solution to
> the texture follow the object transformation.
But I don't see how they could be solved in the same, or any similar
way, unless you transformed the function by converting it to a pigment
and warping it(so you could just warp the texture in the same way).
Some of what has been called displacement is just modifying the
function...for example, adding noise3d() to the radius of a sphere. This
isn't a displacement, that would be modifying the coordinates given to
the sphere function, like multiplying the coordinates given to the
sphere function by noise3d(), and isn't always as easy to control.
Date: 13 Aug 2000 15:24:07
Message: <3996F776.ABDF82E9@pobox.com>
> not transforming the objects but distorting space itself ?  . . .
It could be fun to make scenes in hyperbolic or elliptic space,
but I suspect that'll never be an option in an official version!
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 20 Aug 2000 21:06:21
Message: <slrn8q10ri.j2.ron.parker@fwi.com>
But it's not really solved; the method used is a little fiddly.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
