POV-Ray : Newsgroups : povray.general : Anybody know this site? Server Time
26 Oct 2026 17:29:42 EDT (-0400)
  Anybody know this site? (Message 1 to 25 of 25)
Subject: Anybody know this site?
Date: 11 Aug 2000 23:06:19
Message: <3994bf2b@news.povray.org>
I'm trying to find a website:  it had an excellent tutorial on turning flat
bitmaps of rocks into heightfields.  The guy also had an image gallery
with pictures of an indoor swimming pool (POV-Ray generated).
Sorry, that's really all I have to go on... anybody know this site?
- Doug Eichenberg
  http://www.getinfo.net/douge
  dou### [at] nlsnet
Subject: Re: Anybody know this site?
Date: 11 Aug 2000 23:38:14
Message: <3994C6BC.284C0028@kivisalo.net>
I know this site. There is also that teapot picture from pov Hall of Fame.
http://www.kivisalo.net
K.K.
Date: 12 Aug 2000 04:45:14
Message: <8F8E60FAAseed7@204.213.191.228>
>Fame. http://www.kivisalo.net
I like your Level Connector.
It makes me wonder, would something like this also be possible in 3d-
space? A level_connect warp? It would be nice in combination with Chris'
object pattern and other colour list pigments.
Ingo
Date: 12 Aug 2000 08:37:33
Message: <39954523.5752D334@kivisalo.net>
> space?
I like to think this as a simple electrical potential, so it can
be extented to 3d. Time and memory consumption would be too high
with the iterative method currently used. FFT would be more efficient
way to solve the potential field. I have to think about this :)
Just as in 2d the input and solution would be discrete. In 3d
that would be discrete volumes of densities. I can see this
had media applications but not sure if it can be used for surface
generation, maybe with isosurface functions.
Can someone lend me a Cray for the 3D FFT calculations :)
K.K.
Date: 12 Aug 2000 10:38:18
Message: <3995615a$1@news.povray.org>
That's the one Kari!  (Nice site, BTW).  Thanks!
- Doug Eichenberg
  dou### [at] nlsnet
Date: 12 Aug 2000 11:36:45
Message: <chrishuff-3B5DCE.10375112082000@news.povray.org>
In article <39954523.5752D334@kivisalo.net>, Kari Kivisalo
This looks like it could be a useful enhancement for the proximity
pattern(it could solve the grainyness problem)...or something to be
applied to any pattern. Could you give more details on how you calculate
it? I didn't see an in-depth explanation on the site.
Date: 12 Aug 2000 12:49:12
Message: <3995801A.AC206C81@kivisalo.net>
Here is the theory on 2d electrical potential and how to obtain numerical
approximation using difference equations and iterations. This can be solved
with FFT also but I don't yet know how. Should be easy enough to find:
"solving poisson with fft". Numerical Recipes has nice code for 3D FFT
which calculates the solution in-place saving memory.
Laplace: u(xx) + u(yy) = 0
u(xx) = 2nd derivative of u over variable x
Here u is potential (hf height). x and y are hf coordinates.
Resulting difference formula in free areas (x,y) + 1 pixel boundary:
u(x+1,y) + u(x,y+1) + u(x-1,y) + u(x,y-1) = 4*u(x,y)
So basically the procedure is: Take surrounding 4 pixels and put
the average in the middle. Repeat for all free pixels (x,y). If
there are n free pixels the resulting linear system is n*5. I solve
this with Gauss-Seidel iteration.
More on this method in Advanced Engineering Mathematics by Kreyszig
in section Numerical methods for differential equations.
I sent this uncleaned code to the Terragen guy and he made it a new filter.
LevelConnector uses these pseudo functions to communicate with the
rest of the app.
  SetHeight(x, y, hv);
  hv=GetHeight(x, y);
  Sel=GetSelValue(x, y); // is pixel selected
  PixV=HVToFloat(hv);    // convert from internal type to float
  hv=FloatToHV(PixV);    // convert to internal type
//def for the compare func used by bsearch
typedef int (*fptr)(const void*, const void*);
int compare(const int *a,const int *b)
  return(*a - *b);
// The main calculations. Processes data in u[].
// Solves this Laplace's 2nd order differential
// equation using Gauss-Seidel iteration.
//   d2u   d2u
//   --- + --- = 0 + (force, not used)
//   dx2   dy2
// Can be solved by FFT also but this iterative method lets user control
// the accuracy of the solution. If all pixels are selected then this works
// like smooth with variable radius. Basically it just averages 4 adjacent
// pixels into the middle pixel :) Note however that one iteration pass uses
// uses 2 values per pixel already computed in that pass so it's a kind of
// cumulative smooth.
void SolveEquations(int **s, float *h, float *u, int Nodes, int maxiter)
  int i,c,dir=1,Node;
  float sum;
  for(i=0;i<maxiter;i++)
    {for(Node=(Nodes-1)*(1-dir)/2;dir*Node<=(Nodes-1)*(1+dir)/2;Node=Node+dir)
        { sum=h[Node];
          for(c=1;c<=s[Node][0];c++)
            sum=sum+u[s[Node][c]];
          u[Node]=0.25*sum;
      dir=-dir;  // toggle direction
// Prepares data for SolveEquations
void LevelConnector(int width,int height, int maxiter)
  int xo[4]={1,-1,0,0},yo[4]={0,0,1,-1};
  int c,Nodes=0,*NodeP,Node,PixN;
  int x,y,xt,yt,i,j,*Pos,**s;
  float *h,*u,Sel,PixV,k;
  // Count selected pixels
  for(y=0;y<height;y++)
    {for(x=0;x<width;x++)
       {if(GetSelValue(x, y) == SELECTED)
          Nodes++;
  u=(float *)malloc(Nodes*sizeof(float)); // This is the actual height data
  h=(float *)malloc(Nodes*sizeof(float)); // aux data for equations
  Pos=(int *)malloc(Nodes*sizeof(int));   // Stores pixel positions of nodes
  s=(int **)malloc(Nodes*sizeof(int *));  // aux data for equations
  // clear arrays
  for(Node=0;Node<Nodes;Node++)
    s[Node]=(int *)malloc(5*sizeof(int));
    if (s[Node] == NULL) {perror("memory error");exit(1);}
    for(j=0;j<5;j++)
      s[Node][j]=0;
    u[Node]=0;
    h[Node]=0;
    Pos[Node]=0;
  // Fill position table
  Node=0;PixN=0;
       {Sel=GetSelValue(x, y);
        if(Sel == SELECTED)
          {Pos[Node]=PixN;
           Node++;
        PixN++;
  // Make equations
  Node=0;PixN=0;
          {k=0;c=0;
	   for(i=0;i<4;i++)
             {yt=y+yo[i];
              xt=x+xo[i];
              if (yt == -1)      yt=height-1;
	      if (yt == height) yt=0;
	      if (xt == -1)      xt=width-1;
	      if (xt == width)   xt=0;
              hv=GetHeight(xt, yt);
              PixV=HVToFloat(hv);
              if(GetSelValue(xt, yt) != SELECTED)
                k=k+PixV;
              else
                {c++;
                 PixN=yt*width+xt;
	         NodeP=(int *)bsearch(&PixN,Pos,Nodes,sizeof(int),(fptr)compare);
                 if(NodeP == NULL)
                   {perror("error in bserch");
                    exit(1);
                 s[Node][c]=(int)(NodeP-Pos);
           hv=GetHeight(x, y);
           u[Node]=HVToFloat(hv);
	   h[Node]=k;
	   // h[Node]=k-force;  past experiment
	   s[Node][0]=c;
	   Node++;
  SolveEquations(s,h,u,Nodes,maxiter);
  free(h);
  // Write data in u[] back to hf
      free(s[Node]);
      hv=FloatToHV(u[Node]);
      x=Pos[Node]%width;
      y=Pos[Node]/width;
  free(s);
  free(Pos);
  free(u);
K.K.
Date: 12 Aug 2000 16:33:38
Message: <chrishuff-440A3B.15344512082000@news.povray.org>
In article <3995801A.AC206C81@kivisalo.net>, Kari Kivisalo
> numerical approximation using difference equations and iterations.
> This can be solved with FFT also but I don't yet know how. Should be
> easy enough to find: "solving poisson with fft". Numerical Recipes
> has nice code for 3D FFT which calculates the solution in-place
> saving memory.
Thanks...it looks like it will take a while to analyze this and convert
it to 3d, though. I guess it would help if I had some calculus...and
don't expect a FFT solving method from me. :-)
Date: 12 Aug 2000 17:23:51
Message: <3995c067@news.povray.org>
"Kari Kivisalo" <kar### [at] kivisalonet> wrote in message
news:3995801A.AC206C81@kivisalo.net...
solved
filter.
> rest of the app.
>   hv=GetHeight(x, y);
> file://def for the compare func used by bsearch
>   return(*a - *b);
> //   d2u   d2u
> //   dx2   dy2
works
uses
>   int i,c,dir=1,Node;
>   float sum;
>         { sum=h[Node];
>           u[Node]=0.25*sum;
>           Nodes++;
data
nodes
>   // clear arrays
>     for(j=0;j<5;j++)
>       s[Node][j]=0;
>     u[Node]=0;
>     h[Node]=0;
>     Pos[Node]=0;
>   Node=0;PixN=0;
>         if(Sel == SELECTED)
>           {Pos[Node]=PixN;
>            Node++;
>         PixN++;
>   // Make equations
>   Node=0;PixN=0;
>           {k=0;c=0;
>    for(i=0;i<4;i++)
>              {yt=y+yo[i];
>               xt=x+xo[i];
>               PixV=HVToFloat(hv);
>                 k=k+PixV;
>               else
>                 {c++;
>                  PixN=yt*width+xt;
>                  if(NodeP == NULL)
>                     exit(1);
>            hv=GetHeight(x, y);
>    h[Node]=k;
>    s[Node][0]=c;
>    Node++;
>   free(h);
>       free(s[Node]);
>       x=Pos[Node]%width;
>       y=Pos[Node]/width;
>   free(s);
>   free(Pos);
>   free(u);
> K.K.
   Aaaaaaaargh!!!  You've frightened the s**t out of me now
  Kari!!  Whats a man to do?? (Need new specs after that! Me 'eads gone all
dizzy!! ;o)
                                ~Steve~
    PS, how do I save an image as .jpg, *in POV-Ray*, to 'send' to you very
'NICE' people to perooooose over? Simple question, I know, but I'M sure that
you can handle it, Kari............thanx.
Date: 12 Aug 2000 17:45:09
Message: <chrishuff-CC5169.16461612082000@news.povray.org>
In article <3995c067@news.povray.org>, "25ct" <25c### [at] lineonenet> wrote:
> very 'NICE' people to perooooose over? Simple question, I know, but
> I'M sure that you can handle it, Kari............thanx.
You don't. You have to use an external program to convert an image
generated by POV(in PNG or TGA format, for example) to JPEG. The next
version may include JPEG *input*, but JPEG, as a "lossy" format, won't
be available for output.
Date: 12 Aug 2000 18:23:46
Message: <3995ce72@news.povray.org>
So what do I *do* If I haven't got PNG? or TGA?
  I've got Photo deluxe 2.0,(Hahaha!!) and PS 5 (LE, nice!). Deluxe can
convert an image to .jpeg, but it won't do it, with Pov.
   I am at a loss, so far!
                   ~Steve~     (What? Where? When? ;o)
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-CC5169.16461612082000@news.povray.org...
> Christopher James Huff - Personal e-mail: chr### [at] maccom
> TAG(Technical Assistance Group) e-mail: chr### [at] tagpovrayorg
> Personal Web page: http://homepage.mac.com/chrishuff/
> TAG Web page: http://tag.povray.org/
Date: 12 Aug 2000 18:42:45
Message: <chrishuff-73B1CD.17435312082000@news.povray.org>
In article <3995ce72@news.povray.org>, "25ct" <25c### [at] lineonenet> wrote:
What do you mean?
Are you trying to convert a .pov file? That won't work, you have to
render it with POV and convert the resulting image. POV-Ray can output
to many file formats, including TGA and PNG. The default settings place
the rendered image in the same folder the .pov file is in.
Date: 13 Aug 2000 03:48:05
Message: <399652b5@news.povray.org>
news:chrishuff-73B1CD.17435312082000@news.povray.org...
| What do you mean?
My guess is that (s)he is saying that nothing there is capable of opening a
Targa or Portable Network Graphics image.  But only because I'm not sure
about what either of those programs can open.  Somehow I'd bet Photoshop
could do it, just a hunch.
Date: 13 Aug 2000 03:59:49
Message: <3996558A.CDAA55FF@kivisalo.net>
> > u(xx) + u(yy) = 0
> it to 3d, though.
I think the equations  would just be
u(xx) + u(yy) + u(zz) = 0 and
u(x+1,y,z) + u(x,y+1,z) + u(x-1,y,z) + u(x,y-1,z) + u(x,y,z+1) + u(x,y,z-1) =
6*u(x,y,z)
I could convert my code quite easy to 3D for testing purposes but it would
require lots of RAM to run. Then I would write a macro that outputs an object/volume
as voxel image slice by slice as animation. What's the format of the pov
voxel image type (for input to pov)?
This setup would be enough to determine how useful Volume Connector :) vould be.
K.K.
Date: 13 Aug 2000 04:06:15
Message: <8F8F6FFC6seed7@204.213.191.228>
The density_file.
from the doc: "The df3 format consists of a 6 byte header of three 16-bit
integers with high order byte first. These three values give the x,y,z
size of the data in pixels (or more appropriately called voxels). This is
followed by x*y*z unsigned integer bytes of data. The data in the range of
0 to 255 is scaled into a float value in the range 0.0 to 1.0. It remains
at 0.0 for all areas beyond the unit cube. The pattern occupies the unit
cube regardless of the dimensions in voxels."
Ingo
Date: 13 Aug 2000 04:26:01
Message: <39965BAE.6C93E2CC@kivisalo.net>
Yes. If the volume contains just the object with potential 1 and the
remaining space is set free then every iteration pass would diffuse
the objects "electrical field" very smoothly around the object.
K.K.
Date: 13 Aug 2000 04:58:52
Message: <3996634c@news.povray.org>
> What do you mean?
Hi Chris, apologies, that was the beer talking last night ;o)
   In Pov, I can't see any clear option to turn an image into a JPEG image,
like you can in Photo Deluxe 2 or Photoshop 5.   However, I have now found
my image saved as a .bmp, in MS Paint??!! (how'd it get there?)
   After rendering, do the images save as .bmp's by default? And is it ok to
send to pov.images in this format?
    As i've said in .newusers, i'm 'puter illit. So finding my way around
mine is a nightmare sometimes. I've only had it 6 months :o(  but i'm
getting there :o)
                                  ~Steve~
Date: 13 Aug 2000 05:25:10
Message: <3996698C.FBA075CE@kivisalo.net>
In the winpov, yes.
> And is it ok to send to pov.images in this format?
jpg is the best format because you can choose between file size
and image quality. In photoshop open bmp, file/save a copy, choose jpg,
check preview, move the slider left until the image starts to look bad,
now save an post :)
K.K.
Date: 13 Aug 2000 06:14:45
Message: <39967515@news.povray.org>
That's brilliant!!  Thanks very much Kari.....  :o) :o) :o)
                                  ~Steve~
news:3996698C.FBA075CE@kivisalo.net...
> In the winpov, yes.
> now save an post :)
> K.K.
Date: 13 Aug 2000 09:50:50
Message: <9j9dpskbadaq99b7j75a7ilngf83t6f3e0@4ax.com>
  Hi, Steve. I suggest reading all of the messages in the
povray.announce.frequently-asked-questions group, specifically "Where
can I post my binary or text file?"
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 13 Aug 2000 10:06:44
Message: <3996ab74$1@news.povray.org>
"Alan Kong" <ako### [at] povrayNO-SPAMorg> wrote in message
news:9j9dpskbadaq99b7j75a7ilngf83t6f3e0@4ax.com...
to
       Thanks Alan. I have subscribed to it, but haven't got around to
reading the messages yet. Been busy with an image! (ref; pov.images)  ;o)
It's next on my list though.
                 ~Steve~
Date: 13 Aug 2000 12:00:25
Message: <chrishuff-55C3C2.11013413082000@news.povray.org>
In article <3996558A.CDAA55FF@kivisalo.net>, Kari Kivisalo
> u(x,y,z-1) = 6*u(x,y,z)
Yeah, but the problem is figuring out what that means. :-)
It looks simple, but I can't translate it into an algorithm, and I have
only a slight idea what u() is supposed to do.
> would require lots of RAM to run. Then I would write a macro that
> outputs an object/volume as voxel image slice by slice as animation.
> What's the format of the pov voxel image type (for input to pov)?
Does it require that the density field be converted to a voxel image? I
hope not...but if it requires multiple passes that can't be done at
once, I don't see a way around it.
Date: 13 Aug 2000 12:50:39
Message: <3996D1F6.24D7B16@kivisalo.net>
u is the density/potential at (x,y,z).
As I said before this algrithm is a numerical discrete approximation,
not analythical. The input and output are are voxel images just like
the 2d case works with 2d images. Only certain special cases of potential
fields can be solved analythically at any point. The whole volume must
be solved at once so it's impossible solve just one point at a time.
In povray terms this requires a pre-rendering pass to sample the volume
of interest at specified resolution and then solving the potential field
within that volume.
K.K.
Date: 13 Aug 2000 14:01:29
Message: <chrishuff-BAD5A3.13023513082000@news.povray.org>
In article <399### [at] kivisalonet>, Kari Kivisalo
Simply the field value? Then this is nothing more than a kind of 3D
convolution matrix...right? Basically a blurring operation.
Are you sure about this? It seems like some kind of recursive algorithm
could be used to do a similar effect, sampling at one distance,
subdividing and interpolating, sampling again, etc. I am going to have
to experiment with this...
It wouldn't be the same algorithm, but it should be similar in results.
> within that volume.
This could most easily be done in the parsing stage, and would probably
be a density_file pattern internally. However, you would have to specify
a resolution large enough, and it would consume a lot of memory. :-(
If this absolutely requires a voxel image, then might as well implement
it as a density_file feature, and add the ability to create a
density_file pattern from another pattern(like object). You could
already do so with a macro and eval_pattern() or eval_pigment(), but the
parse time would be long.
Date: 13 Aug 2000 16:40:40
Message: <399707DB.C0075861@kivisalo.net>
One iteration of the linear system is just a blur which can be seen
from the bevel mode example pictures. When the change between iterations
drops below tolerance that's the solution for the Laplace equation.
That math book I mentioned only spoke about methods using linear systems
of equations and iteration. There may be other numerical methods geared
towards applications other than electrical engineering. Look for them using
laplace, poisson , differential, numerical.
K.K.
